'95 Tacoma won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by JaxFlJon, Nov 8, 2011.
  1. Nov 8, 2011 at 11:59 AM
    JaxFlJon
    JaxFlJon [OP] Member
    Ok so let me try and describe whats going on.
    I have a 1995 Tacoma 2.4L 5 speed. One day I drove through some deepish water in a parking lot and my truck stalled out. Parked it and 3 hours or so later I went out and started it up, ran a little rough and the check engine light came on. Drove it around for about 3 months no problems really except that I would get some hesitation with acceleration. Parked it for 5 days. Came out to start the truck to go to work and it acted like it wanted to start for maybe two turns then the engine would just turn over. It wasn't the usual sound that you would get when starting the engine.
    Changed the cap/rotor/plugs/battery/computer behind the glove box.
    pulled the starter and had that tested good.
    No dice.
    Had spark, and the plugs smell like gas something fierce
    Any ideas?
    Can you take a computer to a dealership to have the codes pulled?
    Thanks for any help
  2. Nov 8, 2011 at 12:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    autozone will pull the codes for free. I would start there.
  3. Nov 8, 2011 at 12:05 PM
    JaxFlJon
    If I bring just the computer (not in the truck) they would be able to pull codes?
  4. Nov 8, 2011 at 12:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well they need an OBDII port to plug into. Not sure if that is possible with just the computer.
  5. Nov 8, 2011 at 12:09 PM
    JaxFlJon
    Do they have an option to take it home to use? Don't really want to tow my truck there
  6. Nov 8, 2011 at 12:10 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    wait Im not sure if your '95 has OBD II. Can someone else confirm this?
    You might have to get the dealer involved if it is OBD I.
  7. Nov 8, 2011 at 12:13 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    you can buy a code reader, it's always useful to have. they have some fairly cheap ones that just read codes. your '95 is obd-1. just make sure you buy one with the correct adapter.
  8. Nov 8, 2011 at 12:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    ok there you go.
    I would call autozone and see if you can rent one though if you don't want to buy.
  9. Nov 8, 2011 at 12:25 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
  10. Nov 8, 2011 at 1:33 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You should be able to just jumper TE1 and E1 on the test connector in the engine compartment and with ignition sw on, not trying to start just on and read the number of flashes of the check engine light. The light will blink the first number then pause then blink the second number then it will start over again. Only code 1 will blink continously. Code 1 means no malfunctions. Code 25, 26 and 27 are oxygen sensor related problems. The test connector was near the battery on my 93.
  11. Nov 8, 2011 at 3:14 PM
    JaxFlJon
    Thanks for the tip
  12. Nov 10, 2011 at 11:34 AM
    JaxFlJon
    Couldn't figure it out on my own so I took the truck to the stealership.
    They said it had low compression which was caused by a blown head gasket which I can't figure out because it wasn't overheating, smoking, or had any fluids mixing???
  13. Nov 10, 2011 at 11:43 AM
    JaxFlJon
    Anyone know what the compression numbers are supposed to be for a 2.4L engine?
