95 Tacoma won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Js101, Dec 29, 2016.
  1. Dec 29, 2016 at 5:29 PM
    Js101
    Js101 [OP] New Member
    Jared
    95 Toyota tacoma
    Ok I'm new here. But I'm at my wits end on this 1.
    I have a 95 Tacoma with a 3RZ engine, the cam shaft bearing went out so I swapped motors. It had an after market security system on it so it wouldn't crank. I removed the security system and it started as ran great. Killed and started it 10 more times worked perfect. Went to take it home it wouldn't start. Started reading on here it has no spark and not fueling. I read the crank shaft sensor going bad would cause that, I changed that sensor it's the same thing. Any suggesting would be great
  2. Dec 29, 2016 at 5:36 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Double checked all fuses? Try and swap the EFI fuse with a different circuit's fuse of equivalent amps.
  3. Dec 29, 2016 at 5:41 PM
    Js101
    Jared
    95 Toyota tacoma
    All fuses are good
  4. Dec 29, 2016 at 6:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Check all your grounds carefully, the ones on the intake plenum especially
  5. Dec 29, 2016 at 6:40 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    The ground on my intake was loose after I removed it to performed a compression test. Sometimes it wouldn't start, sometimes it would run then die. Once we found the loose ground, she was back up and running.
    There are a couple grounds on the engine, I know the intake and I saw one on the back end of the motor against the front of the cab. Maybe there are more?
  6. Dec 29, 2016 at 6:43 PM
    Speedytech7
    There's one big one near the bottom of the engine to the left of the starter if you're looking in from the wheel well. There's probably more but you'll need a wiring diagram to definitively find them all.
    jjsul[QUOTED] likes this.
  7. Dec 30, 2016 at 10:56 AM
    Js101
    Jared
    95 Toyota tacoma
    Checked all the grounds they are good. I have a check engine light on when the key is pulled out?
  8. Dec 30, 2016 at 11:24 AM
    Speedytech7
    something is screwy with the wiring if you have a check engine light while the key is out. see if there are any exposed wires or shorts to ground at the diagnostic port that is screwed to the intake plenum
  9. Dec 30, 2016 at 12:36 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    I had a similar CEL when my ground wasn't secure. My temperature gauge also spikes without the key on. Sounds electrical!
  10. Dec 30, 2016 at 8:47 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    engine to body ground hooked up? Battery to body ground also.
    Speedytech7 likes this.
