96 2.7 falls flat on its face.
Discussion in '4 Cylinder' started by fordrngr, May 31, 2011.
  1. May 31, 2011 at 3:09 PM
    fordrngr
    fordrngr [OP] New Member
    My dad has a 1996 Tacoma ext. cab 2.7L 4x4 with a manual trans and transfer case an 195k miles. Within the last 6 months it has had new spark plugs, wires, cap, rotor, air filter, and fuel filter.
    The issue that he's having is that occasionally if falls flat on its face. Usually it only happens in first gear. And when it falls on it's face if you push the clutch in it will rev freely. However when it's under load it acts like it isn't getting enough fuel.
    Any ideas?
    Thanks,
    Bill
  2. May 31, 2011 at 6:14 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Clean MAF, and check the throttle positions sensor with an ohm meter. It should have a steady change in resistance, no dead spots or jerky readings.
