96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Nov 13, 2014 at 7:26 AM
    #181
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    I can't remember... I know at one point I had to use a pretty hefty allen wrench for something, but don't remember what for.
  2. Nov 13, 2014 at 8:11 AM
    #182
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yeah, I think the back bolt is an allen... fml.
  3. Nov 13, 2014 at 11:05 AM
    #183
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Gio, you still running the 96 ECU btw?
  4. Nov 13, 2014 at 11:46 AM
    #184
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Nope. Had to swap mine out for a 98 4Runner ECU. The dif fill is a 10" allen hex key, is that what you're talking about?
  5. Nov 13, 2014 at 12:55 PM
    #185
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    I don't think he's referring to the diff plug. Although speaking of that, mine was pretty much stuck in place. Taking out the CV's and removing the diff pretty much dumped all the diff fluid on the floor. What a mess...
  6. Nov 13, 2014 at 1:45 PM
    #186
    GioGuitarDude
    Gio
    Cold air intake
    Ah yes... and smelly too. Sorry Chris I would check (don't remember) but it's like -1 degree with snow right now. Whatever you do make sure you loosen an axle too.
  7. Nov 13, 2014 at 2:00 PM
    #187
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Oh ok. It just hit me that the 96 ECU doesn't like boost and I couldn't remember if you swapped your's yet.
    Yeah, it looks like the rear bolt needs an allen key. And yeah, I plan to drain my fluid first ;)
    :jellydance: Why you on TW?! Go out and put your truck sideways :p
  8. Nov 13, 2014 at 2:05 PM
    #188
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    Will your drain plug come out? I ended up stripping the allen bolt on mine.
  9. Nov 13, 2014 at 2:24 PM
    #189
    GioGuitarDude
    Gio
    Cold air intake
    Lol yeah man for sure. I never drove the truck turboed with the proper ECU so I'm not sure if it would work or not.
    I heard a small percentage of 96s didn't mind boost
  10. Nov 13, 2014 at 2:27 PM
    #190
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The first time I changed fluid I couldnt get my fill plug out. I used some compressed air to freeze (the whole can) it and it came out pretty easy.
    Your 98 should work just fine with boost I would think :notsure:. If you get an AEM, make sure you have the right manual for the pin readout on your ECU.
  11. Nov 13, 2014 at 2:31 PM
    #191
    GioGuitarDude
    Gio
    Cold air intake
    Say what??? I used a monster crescent wrench and It came off like it was meant to be off lol. Maybe you can drill a hole in that stripped bolt and tap it to 1/4" NPT and re-plug it. That is if you absolutely can't remove it.
    Sounds like you haven't changed the fluids out in a while no?
  12. Nov 13, 2014 at 2:40 PM
    #192
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its not uncommon for the front drain plug to be stripped (http://www.tacomaworld.com/forum/1st-gen-tacomas/344220-stripped-front-diff-drain-plug-2.html)
    Im not sure why Toyota uses the allen bolt.
  13. Nov 13, 2014 at 2:40 PM
    #193
    GioGuitarDude
    Gio
    Cold air intake
    I meant I never drove it turboed with the stock ECU. The 98 ECU loves the boost believe me :D. The pins should be the same... if not Im sure I would have seen something go seriously wrong by now.
  14. Nov 13, 2014 at 2:47 PM
    #194
    GioGuitarDude
    Gio
    Cold air intake
  15. Nov 13, 2014 at 2:52 PM
    #195
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha! Not sure yet man. I jacked my truck up this passed weekend to swap the oil pans (just finished the oil return). I need to cut down the IC tubes then its just a matter of bolting on.
  16. Nov 13, 2014 at 3:01 PM
    #196
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    Yeah, why Toyota makes that fill plug an allen is beyond me. They should have just made it a regular hex head bolt like the rest.
    As soon as CX gets the damn thing back in stock I'm ordering the manifolds & downpipe. I've decided to get them ceramic coated, and then I'm going to wrap them to keep as much heat out of the engine bay as I can. I'm getting anxious to finally get my 4Runner turbo'd. I went backpacking last weekend with a couple of buddies from college, and to get there we traveled some mountainous highway, and it just reminded me of how lacking in power the 5vzfe is. I wound up just locking out overdrive to keep the damn thing from downshifting so much, lol.
  17. Nov 13, 2014 at 3:06 PM
    #197
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Careful, the material doesn't handle heat very well and will crack if you wrap and coat it. Its generally advised to keep stainless manifolds uncoated.
  18. Nov 13, 2014 at 3:34 PM
    #198
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    Hmmm... Maybe I won't do that then.
  19. Nov 13, 2014 at 4:59 PM
    #199
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  20. Nov 14, 2014 at 3:29 AM
    #200
    GioGuitarDude
    Gio
    Cold air intake
    Yeah I definetely wouldn't do that. Wrap the snail up in a blanket but I wouldn't recommend anything else.
