96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Nov 14, 2014 at 3:55 AM
    #201
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I have a Inconel exhaust duct here in my shop and from looking at it, looks to very difficult to weld.:notsure: I'm sure there are shops that have better processes to weld Inconel but for a company to produce headers for a limited amount of vehicles tells me that it would be very expensive.
  2. Nov 14, 2014 at 5:46 AM
    #202
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    I always thought ceramic coating was a good thing, but I guess not? Looks like I need to research the subject a little more.
  3. Nov 14, 2014 at 7:14 AM
    #203
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Less heat in the engine bay=more heat in the pipes=drastically reduced header life.
  4. Nov 14, 2014 at 7:24 AM
    #204
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I think torsp's said his headers are made of this material. Either way, while the stainless steal is very economical and good non-enthusiast material for headers its not the best for high heat.
    The coating IS GOOD to keep the heat contained. The issue is all that heat would be concentrated in your headers causing them to reach extreme temps. Its not gareunteed but the stainless steal can eventually fatigue and crack from all that heat.
    If you keep boost low and dont race it, you should be ok, however you generally won't need to bother with the heat sheilding either :notsure:. I don't plan on wraping or coating mine.
  5. Nov 14, 2014 at 7:26 AM
    #205
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    This is the short version :p
    Good news is the "log style" headers (used by CxRacing) tend to be able to handle the heat and presure better than the "tube style" headers at the cost of performance.
  6. Nov 15, 2014 at 9:09 AM
    #206
    GioGuitarDude
    Gio
    Cold air intake
    Honestly none of that really applies here since the final boost pressure is going to be pretty low for all of us and SS is easy to weld in the event of a crack or fracture. Our trucks stay a lot cooler than most vehicles under the hood so I'm just not interested in wrapping the exhaust for that reason. I can gain that 5 HP elsewhere.
  7. Nov 15, 2014 at 11:03 AM
    #207
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    I was more interested in reducing under hood temps, so I'm not scorching everything. Definitely doing a turbo blanket as well.
  8. Nov 15, 2014 at 10:42 PM
    #208
    GioGuitarDude
    Gio
    Cold air intake
    I wouldn't worry about it if I were you. Honestly if I ever wrapped anything it would be the post IC charge pipes to better insulate the cold air inside and MAYBE the downpipe immediately after the turbo only down about a foot just so I don't burn myself when working around the passenger side spark plugs or TB. Everything you don't want to be fried right by the headers were made to get a little fried.
  9. Nov 18, 2014 at 7:22 AM
    #209
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    So how much have you driven with the turbo? Any difference in gas mileage?
  10. Nov 19, 2014 at 3:47 AM
    #210
    GioGuitarDude
    Gio
    Cold air intake
    No not really any overall difference. Driving to work in the morning takes up most of the gas consumption and then every other time driving I get good mileage (even more so than stock). If I make an effort to drive normal, it will surpass stock mileage because the pistons don't have to work so hard to pull air into the other cylinders. 20+ mpg city is definetely doable if you are willing to take it easy.
    I installed the rear mount pretty much around 12 months ago and proper front mount in late August/early October.
    EDIT: I should probably elaborate... I mean the addiction of hearing that wastegate open and being sucked into your seat makes it hard to be able to see an overall difference in MPG.
  11. Nov 22, 2014 at 9:05 PM
    #211
    GioGuitarDude
    Gio
    Cold air intake
    Hey guys check out my very temporary $1.99 7th injector! AFR at full boost is exactly 12 so it's nice for those planned highway merges until tax season. Don't judge bros!
    Look, I don't even have to take my hand off the shifter to engage it :D
  12. Nov 22, 2014 at 9:30 PM
    #212
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    Lol, whaaaaaat.
  13. Nov 23, 2014 at 6:48 AM
    #213
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Wha?!?!
    I thought you had the URD injector plate?
  14. Nov 23, 2014 at 8:34 AM
    #214
    GioGuitarDude
    Gio
    Cold air intake
    I do... but not the Benjamin's to get the controller just yet.
  15. Nov 23, 2014 at 4:30 PM
    #215
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  16. Nov 23, 2014 at 9:34 PM
    #216
    GioGuitarDude
    Gio
    Cold air intake
  17. Nov 24, 2014 at 7:45 AM
    #217
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Gotcha. See,I wait until I have EVERYTHING before I install :p
    Hopefully Ill be able to get the pan in this week.
  18. Nov 24, 2014 at 11:39 AM
    #218
    GioGuitarDude
    Gio
    Cold air intake
    That boost bug bit me hard man. Really hard. There's no way I could have waited to install everything lol.
    So what's up with your front shaft? Bolts stuck?
  19. Nov 24, 2014 at 1:53 PM
    #219
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Got the bolts off and working to pull out the diff. The issue was the 1/2" drive socket wasnt' fitting snugly with the bolts and I was starting to strip one. I used a 3/8" socket with an adapter and a swivel to get the breaker bar in there and they weren't too much trouble.
  20. Nov 24, 2014 at 2:10 PM
    #220
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    You have a second set of hands helping you out removing that front diff, or are you going at it alone?
