96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. May 7, 2015 at 1:32 PM
    #361
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Not sure what you are trying to say.
    Exhaust leaking out is ok (unless you are from the EPA). Atmosphere leaking in is not. All I know is an open wastegate is better for performance than a closed loop wastegate. You just have to make sure you have a good quality wastegate that won't leak if you are open. If you are closed looped, a leaky wastegate should still be fixed, but at least you aren't screwing up your O2 sensor. Why I replaced the Cx wastegate with a Tial.
    Wastegate should be connected to the vacuum fitting on the turbo and only react to boost at the turbo. If you have a vacuum leak in the manifold, the turbo will continue to spin up as manifold pressure will be lower than boost pressure at the turbo itself. Its a safety thing. I don't think its a big issue when running 8 psi though. I don't know if vacuum will damage the wastegate but it def sees some vacuum, even at the turbo fitting.
  2. May 7, 2015 at 3:47 PM
    #362
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Lol I don't know how else to say it. On my truck, open wastegate in closed loop part throttle boost=poor(er) performance. Closed wastegate in closed loop part throttle boost=very smooth and no hesitation in timing. There is NO other explanation for this. It is 100% a timing issue. I'm well aware that a wastegate that is dumped back in creates more back pressure and resistance that lowers horsepower, but this has nothing to do with that.
  3. May 7, 2015 at 4:01 PM
    #363
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If open waste gate is an issue, you might have a leak. My CX leaked pretty bad. If the machining isn't perfect on the valve seat, it will leak which will cause your O2 to think you are too lean. The issue is (especially when at idle) you exhaust runs in pulses which would give you pulses of atmospheric air leaking into the exhaust and cause your ECU to go a bit wonkers.
    When my waste gate was leaking, I would get surges and falls during idle, low to mid range pulls were a bit shitty and not smooth at all, sometimes I'd get a surge or fall randomly as I started off form a stop. Replaced the wastegate and get great response again, good idle, and quicker boost.
    You may have a leaking wastegate.
  4. May 7, 2015 at 5:28 PM
    #364
    GioGuitarDude
    Gio
    Cold air intake
    That's the thing though... truck drives fantastic now... like better than ever. it would feel squirrelly regardless of where the vac line was hooked up if the squirrelliness was in fact due to a valve seat leak.
  5. May 7, 2015 at 6:55 PM
    #365
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not do to the vac line but the wastegate itself is leaking past the valve seat and into the down pipe. When the down pipe was open, you were probably sucking in air through the waste gate, into your exhaust, and screwing up your O2 sensor readings. When you close looped the wastegate, its still leaking, but now its not sucking in air from the atmosphere. But its still letting some exhaust gasses by which can slow down your turbo spool. Probably not by much :notsure:
  6. May 7, 2015 at 7:08 PM
    #366
    GioGuitarDude
    Gio
    Cold air intake
    No, my lag is non-existent. Full boost at 2300 RPMs. It is a timing issue when the wastegate opens in closed loop and ONLY when the wastegate opens in closed loop. It no longer opens in closed loop since I attatched the line to the mani so the weird timing retard no longer exists.
  7. May 8, 2015 at 5:11 AM
    #367
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Interesting :crazy:
  8. May 8, 2015 at 5:59 AM
    #368
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Why would there be vacuum at the turbo outlet and/or in the charge pipe? The vacuum is in the manifold, not in your charge pipe.
  9. May 8, 2015 at 6:18 AM
    #369
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Sure there will. Anywhere you have high velocity air or fluid rushing over a smaller opening, it will create a vacuum at that opening.
  10. May 8, 2015 at 9:14 AM
    #370
    GioGuitarDude
    Gio
    Cold air intake
    Yup.
  11. May 8, 2015 at 10:05 AM
    #371
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    OMG I'm cmn r u.....:jerkoff: Within the next couple weeks I will be among the few and proud.
  12. May 8, 2015 at 4:10 PM
    #372
    GioGuitarDude
    Gio
    Cold air intake
    Lol yeah dude it definetely gives you a chubby every time some guy in a v8 whatever thinks you're going to be slow and you end up waving at him in your rear view mirror... and you're probably going to be rockin at least 8 psi before I do. That is going to be rediculous haha
  13. May 9, 2015 at 4:05 AM
    #373
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    You'll never see 20 inHg worth of vacuum in the charge pipe like you'd see at the manifold during closed throttle. Hook your boost/vacuum gauge to the charge pipe and have a look.
  14. May 9, 2015 at 7:03 AM
    #374
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Boost gauge should be hooked up to your manifold, waste gate should be hooked up at the Turbo. Sure you can do it any way you like, that that's what's recommended :notsure:
  15. May 9, 2015 at 3:19 PM
    #375
    GioGuitarDude
    Gio
    Cold air intake
    It's also reccomended to tie your WG dump back into the exhaust.
    I can assure you guys that there are WAY more people running their WG from the manifold than there are guys running BG's from their charge pipes. My truck runs way better with the WG on the mani, so that's how I choose to have it... end of story.
  16. May 10, 2015 at 6:37 AM
    #376
    j0shu4
    Is there anything that I need to use threadlock on?
  17. May 10, 2015 at 6:41 AM
    #377
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Anything you don't plan on taking off. I bought a second nut for my V-band clamps to use as lock nut. I used high temp lock tight on exhaust head bolts IIRC.
  18. May 10, 2015 at 7:24 AM
    #378
    j0shu4
    Damn, that locktite is $25. Once again the $$$ fly away. Worth it though for some ultra secure headers.......
  19. May 10, 2015 at 9:47 AM
    #379
    GioGuitarDude
    Gio
    Cold air intake
    Yes it is very worth it... unless you feel like tightening down all the nuts every few months like I do (ugh)
  20. May 11, 2015 at 7:45 AM
    #380
    j0shu4
    Oh man, no thanks......Wondering if I should put it on the vbands too, or could that end up being dangerous if they need re tightened?
