96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. May 11, 2015 at 9:43 AM
    #381
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I think it'll be fine
  2. May 11, 2015 at 9:51 AM
    #382
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    And that little $20 horn is awesome. I put it in, very easy to do. It can fit where the existing horn was. Sounds awesome. Like a Ferrari horn, haha.
  3. May 11, 2015 at 10:54 AM
    #383
    GioGuitarDude
    Gio
    Cold air intake
    Lol Ive had mine for like 6 years and still haven installed it
  4. May 11, 2015 at 2:55 PM
    #384
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Gio, how did you connect your FPR? May be having issues with mine.
  5. May 12, 2015 at 5:07 AM
    #385
    GioGuitarDude
    Gio
    Cold air intake
    I just went straight up to that nipple right above where the little FPR line comes out from under the upper intake mani. It should be the one right next to your MAF
  6. May 12, 2015 at 5:12 AM
    #386
    GioGuitarDude
    Gio
    Cold air intake
  7. May 12, 2015 at 6:06 AM
    #387
    j0shu4
    Did you move your Maf again? Looks like it's on your new 2.5" piping.....
  8. May 12, 2015 at 7:16 AM
    #388
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks!
  9. May 12, 2015 at 7:59 AM
    #389
    GioGuitarDude
    Gio
    Cold air intake
    No this is an old picture
  10. May 17, 2015 at 12:36 AM
    #390
    GioGuitarDude
    Gio
    Cold air intake
    Added some sideways shining LEDs to the sides of my ceiling trim. Looks like a limo inside now image.jpg image.jpg image.jpg
  11. May 17, 2015 at 5:39 AM
    #391
    j0shu4
    looks like you will be able to see inside there now. Haha.......the stock dome light leaves little to be desired.
  12. May 18, 2015 at 7:58 AM
    #392
    j0shu4
    Have you changed your valve cover gaskets?
  13. May 18, 2015 at 8:35 AM
    #393
    GioGuitarDude
    Gio
    Cold air intake
    The LED chip I put in the dome is plenty bright but I wanted a little more unidirectional light. I haven't changed the valve cover gaskets
  14. May 18, 2015 at 9:28 AM
    #394
    j0shu4
    Hey, your sure those autolite app3924 are good for our trucks? Amazon says it doesn't fit my vehicle when I ordered them, but that's what it would say too if I ordered 35" tires.
    Also, do you need boots or coils to go with the wire set?
    Figured I'd do it all if I'm taking the manifold off for valve covers. Mine are leaking badly.
  15. May 18, 2015 at 1:38 PM
    #395
    GioGuitarDude
    Gio
    Cold air intake
    Yup, those App3924 plugs fit perfectly. The wire kit should come with 3 driver side boots and your current passenger side coils and boots should be fine.
  16. May 18, 2015 at 1:54 PM
    #396
    j0shu4
  17. May 18, 2015 at 3:23 PM
    #397
    GioGuitarDude
    Gio
    Cold air intake
  18. May 18, 2015 at 6:35 PM
    #398
    j0shu4
    Good to go, boots and all......just need the plugs you recommended then...
  19. May 20, 2015 at 2:36 PM
    #399
    j0shu4
    20150513_195121.jpg 20150513_195052.jpg Gio. I was going to grind off some of the leftover slag inside my headers. It seems it may enhance the flow characteristics. I would only minorly grind it as there is a fine line between putting a hole in the weld and header. What do you think?
  20. May 21, 2015 at 1:28 PM
    #400
    j0shu4
    Also, if I ss rod my exhaust, will it not last as long as a tig? I was going to ss rod the steel for my bumpers too. How will that hold up you think ?
