96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. May 21, 2015 at 8:22 PM
    #401
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Hellz yeah SS arc weld will hold up! I have welded so much of my stuff including my mini bikes and my exhaust with my puny little 110v welder and SS rods and I am so very impressed to say the least. As long as you use the biggest rods that your welder is rated for, it will match tig work any day. And regarding grinding the inner header slag... go for it dude. It definetely won't hurt anything.
  2. May 21, 2015 at 8:27 PM
    #402
    GioGuitarDude
    Gio
    Cold air intake
    image.jpg image.jpg image.jpg For those who aren't subscribed to Josh's thread, I replaced my wastegate bolts with 8mm hex head bolts (m8 1.25 thread x 50mm bolts) because these CX headers don't give any room for a standard socket to tighten down the passenger side wastegate screw while the headers and wastegate are already in the vehicle. The combination of hex bolts and ball head hex extended sockets make it way too simple to take the wastegate on and off.
  3. May 21, 2015 at 9:01 PM
    #403
    GioGuitarDude
    Gio
    Cold air intake
    And also an update on my wastegate vac line situation. I made a compromise with everyone's concern for my diagram's damage due to the force of intake vacuum and my stubbornness for runnin it post TB by throwing a check valve in there so that the WG only sees boost but at the same time opens up when I want it to. Turns out my wastegate has the tiniest little microscopic bit of space internally where the air can escape to and from (probably escaping out of the threads of a screw or something). It wasn't enough to throw off my AFRs or do anything that would even come close to affecting my check engine light or even boost gauge readings, but it is enough to let the boost pressure out of the wastegate that can't get passed the check valve now so that the wastegate closes when it's supposed to. *best of both worlds*
  4. May 24, 2015 at 5:47 AM
    #404
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Sounds like a great solution. Good job man. I'm going to check which bolts I have. I may already have hex head.
  5. May 24, 2015 at 7:51 PM
    #405
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I wouldn't run a check valve. If it fails you can overboost. If you see even a little on compression surge, you can get in a lot of trouble.
    Running post TB is not going to damage the WG. The reason you run it at the turbo vice anywhere else is you are trying to regulate the turbo's boost exactly. Boost at the Turbo and boost in your intake manifold is not equal.
  6. May 24, 2015 at 10:21 PM
    #406
    GioGuitarDude
    Gio
    Cold air intake
    I'm not worried about it. My eyes stay glued to the wideband and boost gauge anytime I'm in boost.
  7. May 24, 2015 at 11:04 PM
    #407
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Making me want turbo now..
  8. May 24, 2015 at 11:32 PM
    #408
    GioGuitarDude
    Gio
    Cold air intake
    It's pretty darn awesome.
  9. May 25, 2015 at 1:31 AM
    #409
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I'll just wait until i can drop a 2jz in her I guess...
  10. May 25, 2015 at 7:54 PM
    #410
    GioGuitarDude
    Gio
    Cold air intake
    That would probably be the best thing to do
  11. May 26, 2015 at 7:09 AM
    #411
    j0shu4
    Those engines are mad expensive, every part on them. No thanks. Would rather do a Lexus V8 or something.
  12. May 26, 2015 at 3:26 PM
    #412
    GioGuitarDude
    Gio
    Cold air intake
    So much support for them though. Yeah every part for them is expensive, but you can practically find every part you'd ever need at the dollar store (ok slightly exaggerated). It probably takes less time, hassle and money to get a 2jz to 600+ WHP than it does a 5vz. For 400 WHP and lower though, yeah 5vz all day.
  13. Jun 4, 2015 at 6:44 AM
    #413
    j0shu4
    Needing advice Gio....
    Wanting to tap into some sort of a throttle voltage that will allow my meth to be incrementally increased. So as I give it more gas, the methanol pump increases. Any suggestions?
    Oh, and my tires would break loose in second gear easily when boost hits.
  14. Jun 4, 2015 at 9:06 AM
    #414
    GioGuitarDude
    Gio
    Cold air intake
    The throttle position sensor reference wire's voltage goes up and down from 1~v to 5v depending on how open the TB is
  15. Jun 4, 2015 at 9:34 AM
    #415
    j0shu4
    yes, where is that at?
    That is exactly what I need
    Edit: directly across from tb linkage. 3 wires. Too easy. Thx.
  16. Jun 8, 2015 at 6:27 PM
    #416
    j0shu4
    Going to run off maf. What devils own suggested but I'm not sure which wire. I'm getting weird readings off all of the even when I Rev the engine.
    And we can hook up the obd2 adapter to yours too to see what's going on.
  17. Jun 8, 2015 at 9:55 PM
    #417
    GioGuitarDude
    Gio
    Cold air intake
    I can't afford to throw money at this truck till at least Friday. The sucker won't rev above 4k rpms and sounds like total crap. Sputters like porky pig on a bad day. I wouldn't even want to risk driving to your place. Gotta drive the 4Runner this week :cool:
    Knock sensor and wire $110
  18. Jun 11, 2015 at 11:12 AM
    #418
    j0shu4
    Is that what you need? Did yours just go out? Is that the only code you threw? Man. At least you have a backup vehicle. So happy I didn't blow my engine.......
    :kona:
  19. Jun 11, 2015 at 11:35 AM
    #419
    GioGuitarDude
    Gio
    Cold air intake
    Yeah. I have to take so much crap off the engine to get to the sensor and ain't nobody got time for that.
    I knew for your truck it was something simple. Even a wicked misfire at 4 psi would struggle to put a 5vzfe in the grave
  20. Jun 11, 2015 at 11:55 AM
    #420
    j0shu4
    Lmao!
    What do you need to take off?
