96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Sep 29, 2015 at 6:43 PM
    #461
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hmm just found 8 400cc's for a lexus 1UZ but apparently they are interchangeable plus i get two backups! lol $360 for that set
  2. Sep 29, 2015 at 6:59 PM
    #462
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I've probably spent the least out of anyone on tacomaworld to boost my truck. Im only using like $2000 on my truck right now of what I bought for this project.
    $400 used garret turbo
    $200 fabricated intake parts
    $600 headers
    $200 cat, muffler and pipe(s) w/ o2 bungs
    $180 wastegate
    $250 on all the miscellaneous bolts, oil lines, fittings, clamps, gaskets, check valves ect...
    $150 glowshift wideband AFR gauge
    $25 harbor freight boost gauge.
    Of course I have $1000+ worth of crap I didn't use (or haven't used yet) in a box in the garage :)
  3. Sep 29, 2015 at 7:01 PM
    #463
    GioGuitarDude
    Gio
    Cold air intake
    If they are flow tested and cleaned then I would snag those up in a heartbeat.
    400cc injectors are going to limit you to about 350 hp at maximum duty cycle... maybe a little more.
    EDIT: just calculated it and 300 HP is the highest recommended power you should get out of 400cc injectors.
    500cc will get you up to about 400 HP at the crank.
  4. Sep 29, 2015 at 7:31 PM
    #464
    Brice
    Brice Turbo Member
    Brice
    Texas
    Lol maybe i should find some 500's then because i want at least 300 to the wheels if i can i think a stock block can handle that.
  5. Sep 29, 2015 at 7:33 PM
    #465
    GioGuitarDude
    Gio
    Cold air intake
    Oh yeah... the stock block and heads can handle 350 to the wheels all day if it's tuned right and cooled right.
  6. Sep 29, 2015 at 7:38 PM
    #466
    Brice
    Brice Turbo Member
    Brice
    Texas
  7. Sep 29, 2015 at 7:49 PM
    #467
    GioGuitarDude
    Gio
    Cold air intake
  8. Sep 29, 2015 at 7:51 PM
    #468
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hmm so i just watched what they do to their injectors and how they clean and test them and they seem legit i just don't know if i should wait...
  9. Sep 29, 2015 at 7:54 PM
    #469
    GioGuitarDude
    Gio
    Cold air intake
    Wait for what?
  10. Sep 29, 2015 at 7:56 PM
    #470
    Brice
    Brice Turbo Member
    Brice
    Texas
    oops lol i made a thread asking these questions somewhere else and i said i was gonna wait till around christmas to do this forgot this was a different thread XD.
  11. Sep 29, 2015 at 8:00 PM
    #471
    GioGuitarDude
    Gio
    Cold air intake
    Oh lol.
  12. Sep 30, 2015 at 9:34 PM
    #472
    GioGuitarDude
    Gio
    Cold air intake
    My truck is runnin again yay! The timing was 45 degrees advanced (like wtf?). Surprised it even made it to the mechanics house lol.
    The last guy who touched the timing belt stripped the crap out of the hydraulic tensioner, so that sucker was a little cock-eyed. Scary stuff
    j0shu4 likes this.
  13. Oct 1, 2015 at 3:14 PM
    #473
    Brice
    Brice Turbo Member
    Brice
    Texas
    Lol thats pretty far off lmao. Hey so are you gonna run your MAF before or after the bov?
  14. Oct 1, 2015 at 6:33 PM
    #474
    GioGuitarDude
    Gio
    Cold air intake
    No BOV for me... but it's supposed to go before the MAF so that the air that has already been measured can't escape anywhere and cause the truck to run rich
  15. Oct 1, 2015 at 7:02 PM
    #475
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    How much power can you make from stock injectors?
  16. Oct 1, 2015 at 7:04 PM
    #476
    Brice
    Brice Turbo Member
    Brice
    Texas
    Cool thanks man, i just wanna know what to do before i get all the stuff together.
  17. Oct 1, 2015 at 7:05 PM
    #477
    Brice
    Brice Turbo Member
    Brice
    Texas
    Maybe 200 to the wheels maybe after that it starts to lean really badly i'm gonna go with 550cc injectors
  18. Oct 1, 2015 at 7:09 PM
    #478
    gray223
    SE Missouri
    2014 Tundra Limited
    Isn't it alot harder to tune with bigger injectors? If I went turbo I just was going to do idk like 5-8 lbs of boost, run a turbo a little bit on the small side. Just would want something reliable with not quite as many headaches as alot of these guys are running into. Don't want tons of power, or need it. But I like the ability a turbo has to make power, and its more efficient.
  19. Oct 1, 2015 at 7:15 PM
    #479
    Brice
    Brice Turbo Member
    Brice
    Texas
    Well i hear that its harder but it just depends on what you consider hard...I mean you could do 380cc's and replace all your primarys that's the better idea instead of adding 6 extra ones and you could probably get away with that, but you need to use an injector calculator to make sure the ones you pick don't reach more than 80% of there duty cycle. Here's a calculator- https://www.rceng.com/technical.aspx#Fuel_Injector_Worksheet_
  20. Oct 1, 2015 at 7:18 PM
    #480
    GioGuitarDude
    Gio
    Cold air intake
    Actually they can handle up to about 260 WHP but that is way over 80% duty cycle. I bet I'm right in between 240 and 250 with 5 psi. I don't lean out at all whatsoever at 5psi.
