96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Oct 1, 2015 at 7:28 PM
    #481
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    How much more torque over stock you think?
  2. Oct 1, 2015 at 7:33 PM
    #482
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Yeah I was gonna shoot for 8 and see how a custom tune treats me...idk i dont wanna go over 300 to the wheels because thats already 340-350 at the crank..I think...
  3. Oct 1, 2015 at 7:34 PM
    #483
    Brice
    Brice Turbo Member
    Brice
    Texas
    lol its already torquey but idk i wanna guess 300 tq at 260 hp
  4. Oct 1, 2015 at 8:23 PM
    #484
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Yup, that sounds about right. My 5psi vs stock is already a night and day difference. It's so good that I haven't had enough desire to hook up my extra injectors and turn up the boost. I would be more than happy at 8-10 psi with a solid tune and 300~ ponies at the wheels. You won't get anything to last long term above 12 psi.
    Brice[QUOTED] likes this.
  5. Oct 1, 2015 at 8:25 PM
    #485
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You guys make me miss my boost right now.
  6. Oct 1, 2015 at 8:27 PM
    #486
    Brice
    Brice Turbo Member
    Brice
    Texas
    Thats what I hear XD The guys a Custom Tacos try to convince each other 400 is safe for the stock block lol.
  7. Oct 1, 2015 at 8:27 PM
    #487
    Brice
    Brice Turbo Member
    Brice
    Texas
    What did you do with it?
  8. Oct 1, 2015 at 8:30 PM
    #488
    MadTaco461
    CA
    Kinda stock
    Just temporary took it off for emission testing. Plus the motor needs a little love if I want to tune it more aggressively.
  9. Oct 1, 2015 at 8:37 PM
    #489
    GioGuitarDude
    Gio
    Cold air intake
    Do they look under the hood?
  10. Oct 1, 2015 at 8:43 PM
    #490
    MadTaco461
    CA
    Kinda stock
    Yeah it's socal. It's pretty rough. They do a full visual under the hood. If it is aftermarket you need a carb #. The ecu needs to have all codes checked in and they stick a stiffer up the tail pipe. I guess they maybe got rid of the dyno run this year. I'll find out.
  11. Oct 1, 2015 at 8:44 PM
    #491
    GioGuitarDude
    Gio
    Cold air intake
    No way lol. Even if you build up the engine with forged internals, the tranny, driveshaft, axles, and all the seals go out quick pushing 400+ HP. Much more than 300 WHP in these trucks is total overkill for a light truck. 8 is the magic number IMO (psi)
  12. Oct 1, 2015 at 8:50 PM
    #492
    GioGuitarDude
    Gio
    Cold air intake
    Social? That's straight up nazi style... but it is Cali after all.
    I wonder if you could sneak a rear mount turbo through a Cali test... You could probably just temporarily unhook the intake and put the stock duct and filter back on to make it look stock under the hood.
  13. Oct 1, 2015 at 9:28 PM
    #493
    MadTaco461
    CA
    Kinda stock
    You don't want to chance that. You can get flagged to go to a state referee. That is an even stricter inspection. So if you can rip everything off that is what you need to do. I had to put a good amount of thought into my kit to make it all plug and play quickly.
  14. Oct 1, 2015 at 10:41 PM
    #494
    gray223
    SE Missouri
    2014 Tundra Limited
    Is anybody here running a water cooled setup? Or is it all oil cooled turbos?
  15. Oct 2, 2015 at 7:14 AM
    #495
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I'm water cooling mine.
  16. Oct 2, 2015 at 7:58 AM
    #496
    MadTaco461
    CA
    Kinda stock
    My next one going in is water cooled.
  17. Oct 2, 2015 at 8:06 AM
    #497
    Brice
    Brice Turbo Member
    Brice
    Texas
    Idk what I'm doing...
  18. Oct 2, 2015 at 8:11 AM
    #498
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    The record is 1700hp in the 5vzfe.
  19. Oct 2, 2015 at 8:12 AM
    #499
    j0shu4
    Mine too. Not necessary but takes off heat soak, no turbo timer.
  20. Oct 2, 2015 at 8:13 AM
    #500
    j0shu4
    You really need to pick our minds if you really want to do this.
