96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Oct 2, 2015 at 9:21 AM
    #501
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Well I've gathered most of the info i need here and on other places across the internet but i'm pretty sure i'm just gonna be oil cooling.
  2. Oct 2, 2015 at 9:28 AM
    #502
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hey I think i wanna have my oil cooler just like you did yours do you think you could send me a parts link or something? lol because why do something new if its not needed :D
  3. Oct 2, 2015 at 10:01 AM
    #503
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Is it something hard to setup? I think last time I looked it up I couldn't find any water cooled setups on the 5vz
  4. Oct 2, 2015 at 12:34 PM
    #504
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Very easy. You can tap into the heater lines or do what I did. I took the line that runs from your block (in the back by the firewall) to your throttle body and ran that to the turbo, and from the Turbo to the TB. I also mounted a cooler so its actually from the block to cooler to turbo to TB.
  5. Oct 2, 2015 at 12:37 PM
    #505
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    I like the cooler part. Where did you mount it? I'm just off tb like you said to do, didn't know you had a cooler too.
  6. Oct 2, 2015 at 12:42 PM
    #506
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I had to mount it way low on my radiator. Its not too big but Im sure it helps.
  7. Oct 2, 2015 at 1:27 PM
    #507
    gray223
    SE Missouri
    2014 Tundra Limited
    Sounds simple. Now only if I could find a used water cooled turbo...
  8. Oct 2, 2015 at 1:36 PM
    #508
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Yeah, but look at all the repairs and upgrades that have to be done with all of those tacos over 400 HP.
  9. Oct 2, 2015 at 1:37 PM
    #509
    Brice
    Brice Turbo Member
    Brice
    Texas
    True just ask Torspd lol
  10. Oct 2, 2015 at 1:43 PM
    #510
    GioGuitarDude
    Gio
    Cold air intake
    It was just a cheap 1/4" in and out barbed cooler from ebay. I put a restrictor in the engine block where you get the oil from, so that the pressure to the cooler matches the pressure to the turbo. The oil pressure from the block gets pretty high, and I don't know if I'd trust a cheap aluminum oil cooler to hold up without a restrictor
  11. Oct 2, 2015 at 1:48 PM
    #511
    j0shu4
    Brice likes this.
  12. Oct 2, 2015 at 1:52 PM
    #512
    Brice
    Brice Turbo Member
    Brice
    Texas
    What kind of connectors and hoses did you use?
  13. Oct 2, 2015 at 7:01 PM
    #513
    Brice
    Brice Turbo Member
    Brice
    Texas
  14. Oct 2, 2015 at 8:57 PM
    #514
    GioGuitarDude
    Gio
    Cold air intake
  15. Oct 2, 2015 at 9:13 PM
    #515
    Brice
    Brice Turbo Member
    Brice
    Texas
    Dude thank you so much
  16. Oct 3, 2015 at 9:17 AM
    #516
    GioGuitarDude
    Gio
    Cold air intake
    Sure. Then you need to cut a hole in your oil pan and weld your an10 male bung in.
    http://m.ebay.com/itm/Turbo-Oil-Dra...T4-T3-T4-AN-AN-10-10-/121748476988?nav=SEARCH
    ^ an10 return flange
    http://m.ebay.com/itm/10-AN-Stainle...Silver-Sold-Per-Foot-/181659925441?nav=SEARCH
    ^an10 hose
    http://m.ebay.com/itm/AN10-AN-10-10...el-Weld-Bung-Fitting-/261414468259?nav=SEARCH
    ^the an10 bung that you weld in to your pan
    http://m.ebay.com/itm/AN10-AN-10-10...ing-Hose-End-Adaptor-/271833276527?nav=SEARCH
    ^ two fittings to connect the hose to the turbo and pan
  17. Oct 3, 2015 at 9:33 AM
    #517
    j0shu4
    Oh, that's the best part. ^^^^^^^^ Getting the oil pan off and on. (Not really)
    Lmao
  18. Oct 3, 2015 at 10:32 AM
    #518
    Brice
    Brice Turbo Member
    Brice
    Texas
    Eh Idk it shouldnt be too hard my truck is a Prerunner
  19. Oct 3, 2015 at 8:02 PM
    #519
    GioGuitarDude
    Gio
    Cold air intake
    Yeah it might not be that bad... you better thank 8lb 6oz baby Jesus for not having an ungodly awkward and heavy front dif to take almost completely out lol
    Brice[QUOTED] and j0shu4 like this.
  20. Oct 3, 2015 at 8:16 PM
    #520
    Brice
    Brice Turbo Member
    Brice
    Texas
    lol So last night around 4:30 i was curious as to how much my turbo setup will cost and i came up with about 2800 This is including a tune and exhaust install (which ill have done regardless), Also this is without me scrounging for prices..So idk but 2800 ish for 300whp vs 3000 for maybe 200whp (supercharger). So i gues HP/per dollar is still better with the CX kit. Also will i need two O2 sensors if i wanna read AFR's?
