96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Oct 3, 2015 at 8:51 PM
    #521
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hey arent these the same parts as the previous list?
  2. Oct 4, 2015 at 12:22 AM
    #522
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Nope. An4 (1/4") hose and and fittings for the oil feed, an10 (5/8") hose and fittings for the oil drain... and with specific turbo flanges.
  3. Oct 4, 2015 at 12:30 AM
    #523
    GioGuitarDude
    Gio
    Cold air intake
    Yeah no doubt. That's why the rest of us went turbo too.
    The AFRs are read by a single o2 sensor that comes with a wideband gauge. This plugs right into a bunghole (hehehe) that CX has conveniently welded into their downpipe.
    You will need to source a Toyota weld-in bung to install the post-cat o2 sensor though.
    http://m.ebay.com/itm/Steel-O2-Sens...Engines-7M-2JZ-7MGTE-/251895564575?nav=SEARCH
  4. Oct 4, 2015 at 7:32 PM
    #524
    Brice
    Brice Turbo Member
    Brice
    Texas
    Question. Now this may be pure ignorance but do i have to have a high pressure oil line into a GT35? If i do were could i intercept one? If i don't then do i just hook up two bungs one low to suck oil and one high to drain oil? Also Gio It looks like you only have one oil line to the turbo; am i seeing that correctly? Again Thanks.
    Edit: Ok so i hav figured out that i need a HP oil line and a LP oil line (into the oil pan) But were did you guys intercept your high pressure line? my plan was to just buy a relocation kit and T off from the clean oil out side.
    Lol ok so i figured out the whole oil thing....soooooo this whole comment is worthless XD
    j0shu4 and GioGuitarDude[OP] like this.
  5. Oct 7, 2015 at 4:50 AM
    #525
    GioGuitarDude
    Gio
    Cold air intake
    Sounds like me when I first started xD
  6. Oct 7, 2015 at 8:13 AM
    #526
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Yeah, right!
  7. Oct 7, 2015 at 3:20 PM
    #527
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Man we all went through that.
    I remember when I didn't vent the breather tube to atmosphere I thought I blew out all my oil seals.
  8. Oct 7, 2015 at 3:21 PM
    #528
    Brice
    Brice Turbo Member
    Brice
    Texas
    Lol noted. Where is the V6 oil breather?
  9. Nov 20, 2015 at 9:25 AM
    #529
    GioGuitarDude
    Gio
    Cold air intake
    Brice, j0shu4 and yota243 like this.
  10. Nov 20, 2015 at 10:07 AM
    #530
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    What rpm do you get full spool? Does your clutch hold in 4th gear boost?
  11. Nov 20, 2015 at 11:30 AM
    #531
    GioGuitarDude
    Gio
    Cold air intake
    Right before 3k.
    Clutch holds in all gears
  12. Nov 23, 2015 at 10:05 AM
    #532
    j0shu4
    Do you think I'll have any long term consequences from that hesitation/buck I'm getting. It happens pretty frequently and the afr will go from 15, 16 and drop a few points when it does. I think the ecu just gets pissed. It doesn't really bother me, just annoying. If I fluctuate the gas it doesn't do it. Only happens during regular city driving. ?????
  13. Nov 23, 2015 at 12:45 PM
    #533
    GioGuitarDude
    Gio
    Cold air intake
    I had that same problem when I had my supra MAF and 320cc injectors installed, but it only occurred until the truck warmed up completely. It went away completely when I cleaned my MAF really good and replaced my O2 sensors (I'm leaning toward the latter with you). I didn't have any O2 codes either. I wasn't passing emissions so I dumped a gallon of denatured alcohol in my tank and replaced my O2's... never had that problem again.
  14. Dec 15, 2015 at 2:36 PM
    #534
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    What are you running, ecu, injectors, fuel pump, with 5 psi?
  15. Dec 16, 2015 at 4:41 AM
    #535
    GioGuitarDude
    Gio
    Cold air intake
    Literally everything stock besides the 250 walbro pump and the turbo, but you can get away with using the stock pump for 5 psi
  16. Dec 16, 2015 at 7:12 AM
    #536
    gray223
    SE Missouri
    2014 Tundra Limited
    Sweet thanks. What are you afrs like running that?
    And did you need colder plugs?
  17. Dec 16, 2015 at 7:53 AM
    #537
    GioGuitarDude
    Gio
    Cold air intake
    I ran colder plugs for a while but they didn't last worth a darn. When you hook your fuel pressure regulator vacuum line to the manifold or charge pipes and allow it to see boost pressure, the boost pushes against the diaphragm in the fuel pressure regulator, effectively raising the fuel pressure according to what psi you are running. 6 psi is the max you would ever want to run on your stock injectors, but that little trick with the FPR vacuum hose allows you to get 11-12 AFR under open loop boost @ 4-6 psi. In a way it sucks though, because part-throttle closed loop boost has the tendency to run a little lean (13-15 AFR), so you need to constantly govern the throttle to keep it out of boost as much as possible until you decide to put the pedal to the floor and punch it. Proper tuning gets rid of that hassle.
  18. Dec 16, 2015 at 1:33 PM
    #538
    gray223
    SE Missouri
    2014 Tundra Limited
    OK I'll just stick with stock unless colder becomes needed. And I guess I will just have to keep a constant eye on my afr guage.
  19. Dec 17, 2015 at 4:57 AM
    #539
    GioGuitarDude
    Gio
    Cold air intake
    Yeah it's definitely not something you can't get used to.
  20. Dec 17, 2015 at 11:18 AM
    #540
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I wish I had a turbo /:
