96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Dec 17, 2015 at 1:26 PM
    #541
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I wish you did too :p
    I wouldn't bother with that in Cali though. Maybe a SC.
  2. Dec 17, 2015 at 1:27 PM
    #542
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have TRD sc urd 7th and 2.1 pulley...it's pretty sweet. Looking for a stock intake box to get rid of the lame one lol hard to find
  3. Dec 17, 2015 at 1:48 PM
    #543
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    What kind of air filter are you using on the turbo
  4. Dec 17, 2015 at 2:32 PM
    #544
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  5. Dec 17, 2015 at 2:33 PM
    #545
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I have a stock box with deck plate mod. One of the vacuum fittings is broke and its a bit dirty but still working order. Got an aFe drop in filter too if you are interested.
  6. Dec 17, 2015 at 2:35 PM
    #546
    anthony250f
    Anthony
    San Diego, CA
    Pm me a price man.
    There's only one vac fitting on the box right?
  7. Dec 17, 2015 at 6:54 PM
    #547
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its not on the box itself its on one of the resonator boxes. My wife is delivering tonight or tomorrow but Ill try to get it packaged next week and will PM you an offer. I'm thinking $100 shipped for both?
  8. Dec 17, 2015 at 6:58 PM
    #548
    anthony250f
    Anthony
    San Diego, CA
    What year is it from??
  9. Dec 17, 2015 at 7:46 PM
    #549
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  10. Dec 17, 2015 at 9:04 PM
    #550
    anthony250f
    Anthony
    San Diego, CA
    I need 95-98...just found one..thanks tho!
  11. Dec 25, 2015 at 1:52 PM
    #551
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    I have to do my emissions. Where do you get 1 gal denatured alcohol? And 1 gal to a full tank? I'm worried about the bigger injectors and piggyback. Did you disconnect your charge pipes? And if so would that totally jack the readings or even work with my piggyback?
    Merry Christmas to you buddy! Hope Santa brought you something.
  12. Dec 25, 2015 at 4:42 PM
    #552
    GioGuitarDude
    Gio
    Cold air intake
    Home Depot in the paint section. 1 gallon to a half tank of 91 octane is sufficient to pass (or a quart of DA to a quarter tank). You should disconnect your charge pipes (hook it up cold air intake style) and drive around to see if your wideband reads kinda weird. You really don't need denatured alcohol if you aren't running rich.
    Merry Christmas to you too bud!
    j0shu4[QUOTED] likes this.
  13. Dec 25, 2015 at 5:29 PM
    #553
    j0shu4
    Will do. Thanks
  14. Dec 25, 2015 at 5:56 PM
    #554
    GioGuitarDude
    Gio
    Cold air intake
    Your injectors and piggyback are tuned based on manifold pressure/vac, so I don't think running without boost is going to negatively effect anything.
  15. Jan 10, 2016 at 9:27 AM
    #555
    j0shu4
    I'm excited buddy for LT! Hope all is well on your end. Have to get a bunch of us together this summer.
  16. Jan 10, 2016 at 11:41 AM
    #556
    GioGuitarDude
    Gio
    Cold air intake
    Yeah bud let's make it a plan! Good luck with the LT.
  17. Jan 27, 2016 at 9:39 AM
    #557
    j0shu4
    Tried my emissions without the denatured. I disconnected the charge pipes. Didn't pass. He said it was close. Putting in 2 gallons on den.alcohol. I have a full tank. I'm nervous man, this sucks. Do you think the denatured will make it super clean?
  18. Jan 27, 2016 at 9:40 AM
    #558
    anthony250f
    Anthony
    San Diego, CA
    Should do it
    j0shu4 likes this.
  19. Jan 27, 2016 at 10:14 AM
    #559
    j0shu4
    I just realized I left my methanol injection on to. I wonder if that made it better or worse?
  20. Jan 27, 2016 at 11:49 AM
    #560
    j0shu4
    Well. I passed. Put two gallons in to my fuel tank. Made a huge difference in the readings plus I turned the meth off. Rehooked up my charge pipes and am good to go for another two years. I'll know what I need to do for next time. I just want to burn up some of this gas so it doesn't mess up any rubber lines in the system and get it to just regular 91 octane.
