96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Jan 28, 2016 at 4:03 AM
    #561
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Oh good man... sorry I didn't get back to you yesterday.... but glad you passed. That whole emissions crap is so annoying. I wish they would just hook up the OBDII port call it good like many other states. Did I mention that chipotle avocados grow better and healthier with more Co2 to utilize?:broccoli:
  2. Jan 28, 2016 at 2:13 PM
    #562
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Lmao. Dude, without the turbo hooked, my truck felt insanely slow. Hahah. I was like really, this is all you got?
  3. Jan 28, 2016 at 5:32 PM
    #563
    GioGuitarDude
    Gio
    Cold air intake
    Lol... so flippin lame> so I just failed my emissions test too. Thought I would be good with a half gal of alcohol to a half tank but I fell above the limit for every category. Hydrocarbon, co2 and NoX was barely, and I mean barely above the limit. Running high NoX can be caused partly from using denatured alcohol because of a lean condition, but I thought I'd be runnin more rich than anything. Oh well, I'm runnin 85 octane and NA until the next test on Monday after my new o2 sensor arrives. High on everything means a laggy o2 sensor, high hydrocarbon and co2 means rich, and high NoX means lean.
    Note to self and everyone else: stay the F#€% away from non-NKG o2 sensors. Those things should last more than 2 years.
  4. Jan 28, 2016 at 5:51 PM
    #564
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I would just say f that and move to a place with no emission test lol
  5. Jan 28, 2016 at 7:19 PM
    #565
    GioGuitarDude
    Gio
    Cold air intake
    Na dude, I love CO too much. We were supposed to get rid of this emissions BS years ago, but the tree huggers fought tooth and nail to keep it.
    I also made the dumb mistake of resetting the ECU right before I went which renders the IM monitors incomplete so it has to re-learn and re-tune itself for maximum efficiency. I've been getting a slow o2 sensor response code for the last month which I should have fixed...but oh well. I know I'll pass on Monday.
  6. Jan 28, 2016 at 7:20 PM
    #566
    gray223
    SE Missouri
    2014 Tundra Limited
    I see, pot heads don't want you to kill there plants:p
  7. Jan 28, 2016 at 8:59 PM
    #567
    j0shu4
    Use one full gallon per 1/2 tank. I used 2 gal (full tank) in mine but want it out asap. I've heard it can mess up any rubber lines. Not sure if there are a lot of those or no on our trucks. You'll get it next time.
  8. Jan 31, 2016 at 7:45 PM
    #568
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hey man I got a question. Would I have to upgrade my injectors if i'm only running 5 psi? I saw some guys who didn't and where just fine...All I really want is a little extra kick lol. Also what are you using for your pressurized oil source?
  9. Jan 31, 2016 at 7:54 PM
    #569
    gray223
    SE Missouri
    2014 Tundra Limited
    I was told no. you just hook the fpr up to a boost reference and the stock system will produce 10-11 afr at wot. And there is a spot in the block you can tap into for oil. Not sure exactly were it is though
    j0shu4 likes this.
  10. Jan 31, 2016 at 7:56 PM
    #570
    Brice
    Brice Turbo Member
    Brice
    Texas
    oh ok well that sounds all good (though it would be more complicated or something lol) ...now to find that oil tap g spot......
    lol so that way I don't have to buy an oil cooler adapter sandwich...:D
  11. Jan 31, 2016 at 7:58 PM
    #571
    gray223
    SE Missouri
    2014 Tundra Limited
    here is a list i compiled with link to parts and prices for almost everything you need.
  12. Feb 1, 2016 at 2:02 PM
    #572
    Brice
    Brice Turbo Member
    Brice
    Texas
    -Turbocharging a tacoma list o things
    -highflow 3inch catalytic converter -$86.00
    -4AN Oil cooler x1 -$50.00
    -4AN pressurized oil line x6ft -$41.70
    -4AN 90 degree connectors x4 -$21.68
    -4AN turbo oil feed flange 4AN -$11.95
    -10AN return oil line x4ft -$16.84
    -10AN stainless 10AN return bung x1 -$14.98
    -10AN turbo oil drain -$9.99
    -CXracing turbo kit -$1488.00
    -Toyota weld on O2 sensor bung kit (LCE) -$12.95
    -Vband flange and v band 3inch -$20
    -New muffler -$?
    -cone filter and prefilter -$60~
    -Tial 5psi sprung wastegate -$239.50
    -2.75 inch to 2.5inch charge pipe adapter for MAF ---can I use a stock maf?
    Total $2084.09~
    Also where is that spot on the block for a pressurized oil source?
    Have I missed anything? This list is of course with just 5psi of boost
    I figured I'd run this past you sense you had already made one hehe
  13. Feb 1, 2016 at 4:29 PM
    #573
    gray223
    SE Missouri
    2014 Tundra Limited
    I would suggest not buying the actual cx kit. The turbo that comes with it is to big. You will not get as much power in the driving rpm range. Unless your looking for top end performance only.
    Buy different v bands. Don't use the cx ones.
    And you don't have an intercooler.
    And our going to need all new 3" exhaust
    As far as I know stock maf will work
    I also don't know where the oil feed in the block is.
    j0shu4 likes this.
  14. Feb 1, 2016 at 4:34 PM
    #574
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hmm the kit has an intercooler?? well at least on the website it says it does...
    The exhaust should be no big deal...
    and v bands aren't crazy expensive so that should be no big deal either haha
    EDIT:well I guess that smaller turbo wont be to much more...
  15. Feb 1, 2016 at 4:51 PM
    #575
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The IC in the kit is big and the mounting puts it way low so don't plan on offroading with it.
    As far as the oil feed, is a port right next to the oil pressure sensor. Its stuck good so be careful you don't do what I did and strip it (its a hex bolt).
  16. Feb 1, 2016 at 4:53 PM
    #576
    Brice
    Brice Turbo Member
    Brice
    Texas
    Oh ok sweet man thank you! oh and thank you too gray:D well im on a limited budget so where i can save im gonna so a smaller IC isn't a bad idea...
  17. Feb 1, 2016 at 5:02 PM
    #577
    Brice
    Brice Turbo Member
    Brice
    Texas
    hmm well actually I'd prefer a bigger turbo simply because I like WOT and the noises it makes plus i dont really wanna be on boost to often with where i live...
  18. Feb 1, 2016 at 7:06 PM
    #578
    gray223
    SE Missouri
    2014 Tundra Limited
    V band clamp are like 20 dollars... a piece
    This is stupid. You want to have an efficient turbo not one that makes cool noises. Yeah can it make more power in the long run, sure but that means having to upgrade a bunch of other crap as well. If you don't want to be in boost often keep your foot off the gas pedal. And seriously how often are you in WOT? I think you would be disappointed in the results the bigger turbo gives you.
  19. Feb 1, 2016 at 7:09 PM
    #579
    gray223
    SE Missouri
    2014 Tundra Limited
    If your on limited budget then don't buy the whole kit cause you won't use most of the stuff. Just buy the headers and down pipe and try to see if cx will exclude the v bands and see if you can get a discount from that. One thing I learned from researching all this stuff is it isn't exactly a "limited budget" kid of deal, not if your doing it right.
    j0shu4 likes this.
  20. Feb 1, 2016 at 7:10 PM
    #580
    Brice
    Brice Turbo Member
    Brice
    Texas
    lol obviously I'm not only concerned with cool noises just being light hearted is all:D Also its not like the larger turbo will be detrimental to anything either, and I do find myself at 5/8ths and 3/4 throttle quite a bit...What would the larger turbo spool at anyways? Also whats wrong with the v bands cx sends?
