96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Feb 1, 2016 at 7:14 PM
    #581
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Well if I was going to spend all this money and time I think I would want it to produce power for the truck under semi-normal driving conditions, not just when I am gunning it.
  2. Feb 1, 2016 at 7:17 PM
    #582
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Right...hmmm
  3. Feb 1, 2016 at 7:19 PM
    #583
    gray223
    SE Missouri
    2014 Tundra Limited
    You can do your own research but the turbo I had on my list was the size that Torspd recommended for the 3.4.
  4. Feb 1, 2016 at 7:23 PM
    #584
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yeah he recommended the same for me to a while back. I just want this to be under $3000 so it can remain competitive with the s/c. While the s/c makes less HP its a very good kit and is very complete right away, unlike turbocharging but if I can save say $300-400 dollars Turbo-ing is more worth it to me. Also does the smaller turbo have to be watercooled?
  5. Feb 1, 2016 at 7:30 PM
    #585
    gray223
    SE Missouri
    2014 Tundra Limited
    My list added up is $2454, this doesnt include the oil feed or return hardware and lines, or any vaccum lines, or a new header gasket from toyota. This price also includes an AEM wideband and intercooler pipes and connectors, both you didnt have.
  6. Feb 1, 2016 at 7:32 PM
    #586
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yeah i was missing some things...lol But im gonna use your list and see what I can save on. Also would using a glowshift be ok as well? Pardon my ignorance but what would the catch can be used for? #totalnewb
  7. Feb 1, 2016 at 7:35 PM
    #587
    gray223
    SE Missouri
    2014 Tundra Limited
    Idk. But since it is pretty important to have accurate readings from an afr, you know so you don't blow it up, I went with an AEM one in my list. It even has a fail safe.
  8. Feb 1, 2016 at 7:36 PM
    #588
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hmm yeah idk either...cause yuh know never done this before..but didnt OP use a glowshift?
  9. Feb 2, 2016 at 6:37 AM
    #589
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Don't; you'll never reach its max potential unless you build your motor's top end at least and raise its RPM's from 5.5k to 6k+. Also, you'll get massive lag and driving it would be pretty much like driving stock unless you glue the gas to the floor.
    My turbo is smaller than the kit and I probably start boosting at about 2.5k rpm's. Its way too big for me.
    The Cx bands are shit, flimsy, and use nylon lock nuts ( :confused: ). In case you don't get the connection, the nylon will melt as your exhaust heats up :facepalm:
  10. Feb 2, 2016 at 7:55 AM
    #590
    Brice
    Brice Turbo Member
    Brice
    Texas
    lmao wow thats pretty funny that they'd do that :rofl:. The more i sit and the think the more im convinced to just do the smaller turbo and only buy the headers and down pipe... Hey gray included a oil catch can in that list...what for?
  11. Feb 2, 2016 at 8:58 AM
    #591
    gray223
    SE Missouri
    2014 Tundra Limited
    When you go forced induction you have more blow by (more crap getting pushed past the piston rings during combustion).
    But I think know I'm just going to go with an cobalt air oil separator. There only like 30 dollars and do the same thing. But Idk if it will hold up to boost pressure....
  12. Feb 2, 2016 at 9:12 AM
    #592
    Brice
    Brice Turbo Member
    Brice
    Texas
    Oh so its just to hookup to the valve cover then I guess?
  13. Feb 2, 2016 at 11:43 AM
    #593
    gray223
    SE Missouri
    2014 Tundra Limited
    It goes, pcv>Catch can>intake
  14. Feb 2, 2016 at 11:58 AM
    #594
    Brice
    Brice Turbo Member
    Brice
    Texas
    Right ok that makes sense. To catch blow by... welp better add that to the list...:D
  15. Feb 2, 2016 at 12:10 PM
    #595
    gray223
    SE Missouri
    2014 Tundra Limited
    Yeah I stead of the blow by going back in the intake it goes in the catch can and your intake stays cleaner, in theory. I'm curious as to if it will be okay to use on a turbo system...
  16. Feb 2, 2016 at 12:16 PM
    #596
    Brice
    Brice Turbo Member
    Brice
    Texas
    Well it should be I mean MCM runs one on super gramps which sees waaaaaaaaaaaaaaaaaaaaaaaay more than 5 psi but i would recommend a baffled one just to reduce inevitable turbulence with boost- I went and researched a bit so I'm by no means an expert just drawing some conclusions :) Im looking into what mishimoto offers atm...
    EDIT: nvm they cost real non ebay grade money :D
  17. Feb 2, 2016 at 12:29 PM
    #597
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    The cx bands will work. Just DO NOT over tighten them because the bolt will snap. But buy a couple extra in case one or two break. Just buy the cx headers. I have a GT30 bb, billet wheel turbo that I love but I think the gt35 is too big. It will work fine but most recommend a smaller one. CX sells smaller turbos too.
  18. Feb 2, 2016 at 12:32 PM
    #598
    j0shu4
    Just buy an ebay intercooler to your liking. Make sure it's bar and plate. Almost all intercooler are the same. Fuck mishimoto and their $500 (same shit) aluminum intercoolers qhen you can get oNE for $90. Also get a tial or precision wastegate. Accept nothing else for your wg.
  19. Feb 2, 2016 at 12:37 PM
    #599
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yeah im putting the list together right now and im just gonna get the little IC in grays list and only buy the headers and downpipe along with the smaller turbo.
  20. Feb 2, 2016 at 12:38 PM
    #600
    j0shu4
    A catch can is not necessary
