96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Feb 2, 2016 at 12:41 PM
    #601
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Yeah this is true
  2. Feb 2, 2016 at 12:44 PM
    #602
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    While it isn't necessary it does help keep stuff clean...idk if i'll run one or not though.
  3. Feb 2, 2016 at 12:47 PM
    #603
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Sometimes the extra combustibles without the cc on can increase/aid combustion
  4. Feb 2, 2016 at 12:51 PM
    #604
    Brice
    Brice Turbo Member
    Brice
    Texas
    While in some cases that's true, oil actually lowers gasolines octane rating when combusting, atleast from what I've read.
  5. Feb 2, 2016 at 1:26 PM
    #605
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I disagree. If you keep the PCV system stock, when you are running boost, the pressure forces the PCV closed, disallowing the crank pressure from venting off, possibly blowing your seals.
    At the very least, you need to rough the PCV dump to pre turbo but if you are dumping oily shit pre turbo you can gum up your turbo. And depending on where you position your MAF, you will gum that up too.
    Technically you can run without a catch can but its not recommended.
  6. Feb 2, 2016 at 1:29 PM
    #606
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yeah exactly what you said is what I was thinking the only reason I wouldn't run one I guess is if I end up not having money for it...but even then I'd just save up and put one on. Also is the pressurized oil source right below the oil filter? That hex bolt? I'm about to go look and see but i was just curious. Doesn't the 5VZFE have two valve cover "breathers"? doesn't this mean you would need a 4 port oil catch can?
  7. Feb 2, 2016 at 4:01 PM
    #607
    Brice
    Brice Turbo Member
    Brice
    Texas
    So I uh just went and totaled up the cost and well uh its basically $3000...well $2925.17... I mean I could look for better prices but man at that price a s/c comes with a much better kit...although gives less HP
  8. Feb 2, 2016 at 4:05 PM
    #608
    gray223
    SE Missouri
    2014 Tundra Limited
    One is the valve cover has the pcv the other provides fresh air for the pcv.
  9. Feb 2, 2016 at 4:07 PM
    #609
    Brice
    Brice Turbo Member
    Brice
    Texas
    But doesn't the catch can have to be connected to both?
  10. Feb 2, 2016 at 4:09 PM
    #610
    gray223
    SE Missouri
    2014 Tundra Limited
    No it wouldnt have to be. Idk about in a turbo setup.
    This is how a pcv works. Fresh air comes in on the left, picks up the blow by and then it's feed into the intake. The actual valve is on the right in this pic.
  11. Feb 2, 2016 at 4:11 PM
    #611
    Brice
    Brice Turbo Member
    Brice
    Texas
    Ah ok a picture something my dumb self can understand. So if i understand this correctly I would install the catch can on the right side?
  12. Feb 2, 2016 at 4:13 PM
    #612
    gray223
    SE Missouri
    2014 Tundra Limited
    Yes. It would attach between the pcv valve and the intake.
  13. Feb 2, 2016 at 4:16 PM
    #613
    gray223
    SE Missouri
    2014 Tundra Limited
    This is the 5vz fresh air tube for the pcv system. It would be the hose on the left of the previous diagram.
    Its the one with oil on it.
  14. Feb 2, 2016 at 4:36 PM
    #614
    Brice
    Brice Turbo Member
    Brice
    Texas
    Thanks
  15. Feb 2, 2016 at 5:16 PM
    #615
    gray223
    SE Missouri
    2014 Tundra Limited
    I meant left... not right
  16. Feb 2, 2016 at 6:03 PM
    #616
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    What I did for the vent on the rear of the driver side was put an autozone filter on it but it kept venting the crap into my engine bay and into my vents so I put a one way check valve so air can only go in. I then ran the PCV to a vented catch can.
  17. Feb 2, 2016 at 7:26 PM
    #617
    gray223
    SE Missouri
    2014 Tundra Limited
    Only problem with this is if the pcv valve fails, gets stuck closed, your screwed cause it has no we're to go.
  18. Feb 2, 2016 at 7:52 PM
    #618
    Brice
    Brice Turbo Member
    Brice
    Texas
    Welp no turbo for me I was just informed by my parents that this truck is a waste of time and money and that I need a newer better vehicle... Anyway thanks for the information guys sorry to waste your time.
  19. Feb 2, 2016 at 8:19 PM
    #619
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    PCV might get clogged but that's a long way off. I doubt it would clog so bad that the seals would blow out before the clog does. Besides, proper maintenance should prevent that.
    j0shu4 likes this.
  20. Feb 2, 2016 at 8:43 PM
    #620
    gray223
    SE Missouri
    2014 Tundra Limited
    Yeah that's true.
