96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Feb 23, 2016 at 1:30 PM
    #661
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Why not get the Cx manifold? The stock is so tiny and restrictive.
  2. Feb 23, 2016 at 2:13 PM
    #662
    shimstak
    shimstak Member
    2001 Tundra TRD 3.4 5-speed
    I was going to. I thought "awesome, a bolt on solution", but I've reconsidered for a number of reasons:
    1. While the CX manifold is obviously less restrictive, the most restrictive cross section of either setup is the T3 flange. I have owned cars with much smaller manifolds (in terms of volume and min x-section) that saw much higher flow, pressure and temperature conditions than this setup ever will. My Saab Viggen, a 2.3L 4 cylinder reliably (60k miles) ran 30psi boost for 360lb-ft at the wheels. That is a high boost pressure for that torque number, which is characteristic of those cars with the stock turbo. That creates some impressive heat and pressure in the exhaust manifold, but by opening up the turbine flow- swapping for a bigger wheel/housing combo, the HP/TQ goes up with less boost. The manifold was not the restriction in that situation. My goals for this project are somewhere around 280lb-ft at the wheels, but honestly, if it's limited to ~240 at the expense of reliablity/complexity I'll be perfectly happy with that. It won't take 30psi- we're talking less than 30% of that.
    2. I don't want to run an external wastegate. Overkill, plus the cost, complexity, and limited fine tuning options at these low boost levels make it more trouble than benefit for me. You guys who go for more power are in a different situation with that.
    3. I have resources to do the fab for these kinds of projects, and I like the flexibility that gives me.
    4. I'm a little concerned about the longevity of the CX parts. If I spend $700, and it cracks and I'm constantly repairing it, I'm pissed. However if I have to touch up my welds on a bastardization like this, it's easier on my head.
    5. I have reason to believe that this can approach can last a while. I know a guy who did something similar on a T100 and used it for a tow vehicle for his race car all around the US. Something like 100k miles. Granted, the T100 has a cast iron manifold, which is different, but I'd argue that the longevity might be in my favor with the steel mani.
    6. Money. I'll be into this project for under $1000. :D
  3. Feb 23, 2016 at 2:22 PM
    #663
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I would rather have a brand new manifold then the stock one that can crack under normal use. How do you know its not going to rust a hole in it soon?
  4. Feb 23, 2016 at 2:25 PM
    #664
    shimstak
    shimstak Member
    I don't know that it wont, but the truck is rust free, including it's original exhaust system.
    I know I'm taking a chance. I'll post up if there's a problem.
  5. Feb 23, 2016 at 2:29 PM
    #665
    gray223
    SE Missouri
    2014 Tundra Limited
    Yeah idk. I just feel like your already adding restriction to the exhaust via the turbo, and now your not helping relieve it with a better flowing manifold.
    But I don't know enough to effectively speak on this matter
  6. Feb 23, 2016 at 10:08 PM
    #666
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    You can weld regular steel with stainless steel rods/wire... I do it all the time. Believe me, your welds *will* see holes eventually unless you over-do the crap out of them. I went through that myself with the rear mount. I'm not trying to discourage you from attempting to fab up your stock exhaust, but for $400 you can get the CX headers with no downpipe that is completely bolt on and ready to go with way more flow. Even the worst batch of CX headers aren't going to crack a mile above sea level and pushing 240-280 WHP... not even close. The torque I gained just going from NA stock exhaust to NA CX exhaust with cat and muffler (charge pipes not hooked up) made a noticeable difference.
    The only way I would ever even think about justifying using the stock headers is for a well thought-out rear mount setup.
  7. Feb 24, 2016 at 8:13 AM
    #667
    shimstak
    shimstak Member
    I hear ya, and I understand people's concerns. If it fails, I'll post pics and buy some CX headers. :1up:
  8. Feb 24, 2016 at 8:56 AM
    #668
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You want an oil pan (1st gen Tacoma) with a CXRacing return bung welded in it by any chance? It takes a large return line to fit over it.
    By the way, make sure you have your return line fitted before you weld the flange to align the turbo so the return line is as straight up and down as possible.
  9. Feb 24, 2016 at 9:11 AM
    #669
    shimstak
    shimstak Member
    Thanks for the offer on the pan. I did mine already using a -12AN to 3/4NPT that I bored out on the lathe to around 17mm ID. It's not the full 19mm ID that Holset wants, but it's bigger than the -10AN line that most are running with the HX and HY turbos. The return line has a really clean straight shot into the pan- vertical for the first 14" or so, then gently curving into the -12AN fitting. I'll be sure to clock the turbo CHRA so the oil outlet sits at 6 o'clock.
    What size is the oil feed fitting on the block? The one just in front of the oil filter? The internet says both 1/8" and 1/4" NPT in the various build threads I've seen. That looks like a bitch to reach...
  10. Feb 24, 2016 at 9:17 AM
    #670
    gray223
    SE Missouri
    2014 Tundra Limited
    In my list I have this goes into the block.
    http://m.ebay.com/itm/3-8-Male-x-1-...-Hex-Bushing-Fitting-/331021153861?nav=SEARCH
    Then a restrictor goes into it.
    http://m.ebay.com/itm/4AN-4AN-AN4-t...-OIL-RESTRICTOR-BLUE-/171625500114?nav=SEARCH
  11. Feb 24, 2016 at 9:21 AM
    #671
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The fitting to the block, located next to the oil pressure sensor is hard AF to reach. I believe its a 12mm allen wrench. I had trouble getting the allen to seat all the way and almost stripped it so make sure the allen goes in all the way (its pretty deep).
    To access it better, release the tensioner on the alternator, loosen the mounting bolt, and remove the belt. Have a second pair of hands to rotate the alt up and hold it out of the way (or just pull it out). Should be easy to reach at that point.
  12. Feb 24, 2016 at 9:29 AM
    #672
    shimstak
    shimstak Member
    Wow, I guess add 3/8" NPT to the list now too. I better pick up a few extra NPT bushings. Ace is the place...
    12mm socket head on the plug pretty much rules out 1/8" and 1/4" NPT.
    I'm running a -3AN line for the turbo, so no restrictor needed according to the DSM guys who use these turbos.
    I was hoping there was some trick that didn't involve moving the alternator. Oh well, not the big of a deal.
    User anothernord has a couple pics in the first page of his thread of the little bastard in question:
    https://www.tacomaworld.com/threads/holset-vgt-5vz-fe-turbo-build.403951/
    I'll route the line the same way he did.
  13. Feb 24, 2016 at 9:34 AM
    #673
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ Yes, that's the bolt I'm referring to in his build.
  14. Feb 24, 2016 at 1:10 PM
    #674
    GioGuitarDude
    Gio
    Cold air intake
    Idk if it helps, but I didn't have to touch the alternator at all, nor did I need any help for the oil feed. You also have way more room to work in than any of us tacoma guys. 3AN should be fine with no restrictor, but it all depends on the condition of the turbo and its seals. I choose to run a restrictor at the oil tap on the block to keep the pressure down within the feed line.
  15. Feb 24, 2016 at 3:08 PM
    #675
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Restrictor should be at the turbo, not at the block. If its at the block, it will take a while for the oil to reach the turbo when the line drains down from sitting undriven. You can also get uneven oil feed into the turbo itself. Not recommended at tall.
  16. Feb 24, 2016 at 3:32 PM
    #676
    gray223
    SE Missouri
    2014 Tundra Limited
    So should you just run a 3AN with no restrictor?
  17. Feb 24, 2016 at 3:52 PM
    #677
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You def need a restrictor. Too much oil and it will leak out of the turbo and it can slow the spool. Just have the restrictor as close to the turbo as possible, def not on the block. And its not a "you probably shouldn't" its a "you DEF shouldn't".
    Think about it. With the engine off, the entire line drains and when you restart it, the line has to fill up again but if the oil has to go through the restrictor, it will take some time to fill up that line. If the restrictor is at the turbo, the air in the line will pass through the restrictor much faster, allowing the line to fill up much faster and allowing oil to reach the turbo quicker. The turbo needs almost constant oil feed which is why its also advised to prime your oil filter every change (if you can - can't really with the stock oil filter position).
    gray223[QUOTED] likes this.
  18. Feb 24, 2016 at 9:40 PM
    #678
    GioGuitarDude
    Gio
    Cold air intake
    Lol I don't lose any oil at all in the feed line that isn't refilled the second the starter starts to turn the belts. I tested that with the 10 foot long rear mount feed line in my old setup with no dry starts. Heck, I even had a problem with that 10 foot long oil feed line pushing oil passed the turbo seals as the engine was cranking over and the accessory power for the oil return pump was cut off for a half a second. Even if it did take more time to fill the feed line, not even the most microscopic shred of damage could occure from a cold idling turbo spinning at 600 RPMs for a half of a second (or 5 revolutions) before the oil reached it. That's ridiculous on so many levels (no offense). 3/16" (an3) is so similar in size to 1/8" that there wouldn't be hardly a difference at all in oil feed. I run an aluminum inline oil cooler, and I don't like that cooler seeing the full oil pressure for darn good reasons. I've been boosting all over 2 states for over two years with absolutely no issues at all whatsoever. Oil pressure rises with RPMs, so there is no uneven oil feed. Most (all?) oil feed flanges have a built in 1/8" or smaller restrictors already, so a 3/16" restrictor at the block to slightly lower the pressure isn't hurting anything.
    Brice and gray223 like this.
  19. Feb 25, 2016 at 6:20 AM
    #679
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    That's not what I read. Ill try to find the build page. It was pretty insistent the restrictor was at the turbo :notsure:
  20. Feb 26, 2016 at 3:12 PM
    #680
    GioGuitarDude
    Gio
    Cold air intake
    I'm sure there are hundreds if not thousands of people who would not recommend a restrictor on the block, but when you look at the physics behind it, there is nothing wrong with it. The restrictor on the block is the same diameter as a 3an feed line with no restrictor at all. I have a 1/8" restrictor at the turbo flange which is not uncommon or looked down upon. My oil also fully reaches the turbo before the truck even fires up with the cranking of the belts. There is literally no issue at all whatsoever.
