96 5vz xcab 4x4 TACO TURBO BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by GioGuitarDude, Aug 25, 2014.
  1. Oct 5, 2014 at 6:52 PM
    #101
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    The exhaust manifold studs within the engine block stayed put while I loosened the outer nuts but a couple of the stock crossover pipe/downpipe studs screwed out with the nut because they were seized together. Not sure why CX says some "have" to come out because they don't... And they definitely won't for you if you allow WD40 to penetrate the stud-nut barrier for like 12 hours.
    And I definetely would come hang out and help out if you lived in CO dude
  2. Oct 6, 2014 at 8:13 AM
    #102
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im just gonna dunk the whole engine bay in a bath of pentrating oil b/f I start :p
  3. Oct 6, 2014 at 1:45 PM
    #103
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    I've been hitting the studs/nuts with PB Blaster at night once the motor cools down. Been doing this for a while now. Putting a straw on the can of PB Blaster is very helpful. I put a wrench on a couple of the studs and was able to loosen them without issue. Hopefully they're all that way.
  4. Oct 6, 2014 at 5:40 PM
    #104
    GioGuitarDude
    Gio
    Cold air intake
    I'm sure you guys won't have a problem. After all my truck is older than allayalls and has more miles (im guessing)
  5. Oct 7, 2014 at 8:00 AM
    #105
    GioGuitarDude
    Gio
    Cold air intake
    I think it's time for a new fuel pump. At high speeds sometimes the truck boggs down for a second or two then goes back to normal. This is a classic sign of a fuel pump that needs to be replaced soon. Oh well, I was going to swap it out with a 255 walbro anyway. Another hundred bucks gone...
  6. Oct 7, 2014 at 9:33 AM
    #106
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  7. Oct 7, 2014 at 2:34 PM
    #107
    GioGuitarDude
    Gio
    Cold air intake
  8. Oct 7, 2014 at 3:26 PM
    #108
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Im positive the Felco will :notsure:
    Im positive you can MAKE the Walbro fit... :p
  9. Oct 7, 2014 at 5:27 PM
    #109
    GioGuitarDude
    Gio
    Cold air intake
    Hmmmmm.....
  10. Oct 7, 2014 at 5:52 PM
    #110
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    This on should fit. I know for a fact that all walbro 255 pumps physically fit, the issue is in the wiring. At the very worst, you might have to solder some new wiring (two wires). It took me 5 min to do once the old pump was out.
  11. Oct 8, 2014 at 3:52 AM
    #111
    GioGuitarDude
    Gio
    Cold air intake
    Oh that's not a big deal. Thanks
  12. Oct 8, 2014 at 8:17 AM
    #112
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No, its easy.
    Dont drop your tank. Just unbolt your bed on one side and loosen the bolts on the other and prop it up with a 2x4.
  13. Oct 8, 2014 at 9:00 AM
    #113
    GioGuitarDude
    Gio
    Cold air intake
    I was afraid someone would tell me to do that lol. Guess I gotta get all my crap out of the bed. I'm hoping my fuel pump will last me till I get back from hunting because I have like no money till the Friday that I head up.
  14. Oct 8, 2014 at 9:04 AM
    #114
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You have a manual boost controller yet? Just turn your boost way down and you dont have to worry about fuel pressure.
  15. Oct 8, 2014 at 10:50 AM
    #115
    GioGuitarDude
    Gio
    Cold air intake
    Na the wastegate spring is 4-5 psi.
  16. Oct 8, 2014 at 11:12 AM
    #116
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Should get one, good thing to have. Can adjust all the way down to your spring rate but no lower IIRC.
    I got this one: http://www.amazon.com/NXS-Motorspor...91846&sr=8-2&keywords=manual+boost+controller
    Had some reviews where the ball would rust a bit and get stuck shut so I took it apart and used some all-purpose silicon grease to coat everything. Not sure yet where Im going to mount it but I want it in the cab where I can tune it without having to open the hood all the time.
  17. Oct 8, 2014 at 11:36 AM
    #117
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    it can be adjusted all the way DOWN to the spring rate? how can you get more boost than what the spring is rated for? will it not open once you hit that psi? sorry if thats a dumb question just curios
  18. Oct 8, 2014 at 11:58 AM
    #118
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    When the valve is fully open, the manifold pressure applies directly to the spring. When your manifold reaches 8psi, its enough to compress the spring and open the valve.
    In laymens terms, the controller reduces how much pressure is transfered from the manifold to the spring. Example: at 8 psi, the controller only lets 5psi through to the spring. You manifold pressure will have to be greater than 8 for enough pressure to get through the controller to compress the spring.
    Basically, you can't make less than the spring rate in boost.
  19. Oct 8, 2014 at 12:09 PM
    #119
    yota243
    E.J.
    north Alabama
    i still dont follow. if ur spring is rated at 5 psi your WG will not be open at 4 psi right? also anything over 5 psi would cause the valve to be open. it seems to me that the mechanical factor would be the the maximum and any additional controller would only operate up to that point, at which the spring rate would override any settings that were higher than said spring rate. im not questioning you because i am very green at this. i just need it explained in a bit more detail if posible
  20. Oct 8, 2014 at 2:20 PM
    #120
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The waste gate spring operates off of manifold pressure. If you hook up the manifold directly to the waste gate, the pressure in the manifold and pressure acting on the spring are the same. When the manifold pressure equals 5psi, 5psi of pressure is also acting on the spring. For an 8 pound spring, it will require 8 pounds of manifold pressure before it compresses and opens the waste gate. As the waste gate is open, the exhaust is directed away from the turbo so as to not build any additional boost.
    What the controller does is "intercept" the manifold pressure and reduces it. So if you have 8 psi of manifold pressure and the controller reduces it to 5 psi before it reaches the waste gate, the valve won't open and the turbo will continue to build boost. It will build boost until the boost passing through the controller (reducer) finally reaches 8 psi. At that point, manifold pressure would be greater than 8psi.
    So the controller can only reduce pressure acting on the spring and therefore can't reduce boost less than what the spring is rated. The only way to reduce boost less than the spring rating is with an active pump that increases the pressure that is acting on the spring (takes the manifold pressure and increases it before sending it to the spring). I don't know if these exist :notsure:
