96 T100 turn key...silence.
Discussion in 'Toyota Trucks & SUVs' started by jessea1a, Nov 16, 2011.
  1. Nov 16, 2011 at 12:25 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Did you test the new starter before you installed it? New/rebuilt does not always mean good. I would pull the starter and use jumper cables from another battery/vehicle to the ground and the solenoid and see if it spins.
    Also, you said you replaced fuses. What circuits were the fuses to?
  2. Nov 17, 2011 at 12:56 PM
    jessea1a
    jessea1a [OP] Shoeless
    Jesse
    Port Angeles, WA
    '96 T100 SR5 3.4L V6 4x4
    Painted wheels, emblems, bumpers, and mirror backs black.
    Did not test the new starter but we know it receives power. That being said could it still receive power yet the solenoid be bad?
    The fuses replaced were:
    EFI 15 A: multiport fuel injection system/sequential multiport fuel injection system/electronically controlled automatic transmission system
    AM2 30 A: starting system, all components in "ENGINE", "IGN", "WIPER", "GAUGES", "RADIO", "CIG" and "TURN".
  3. Nov 18, 2011 at 5:33 AM
    wolftree
    Rick
    Ohio
    Yes, it is very possible that the new starter is bad. When you take your battery and alternater in to be tested, take the new as well as old starter if you still have it and have them tested as well.
    I would also verify with the multimeter that the fuses you replaced are good using the "Ohms" scale on meter. You should get "0" ohms when testing them.
  4. Nov 22, 2011 at 11:42 AM
    jessea1a
    Jesse
    Port Angeles, WA
    So the new starter is fine. Hooked it up to cables and the solenoid clicks. Testing a different battery this evening.
