'96 taco ,V6 runs rough until warm?
Discussion in 'Technical Chat' started by dustinJ, Feb 12, 2011.
  1. Feb 12, 2011 at 8:52 AM
    dustinJ
    dustinJ [OP] Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5. Stock, but not for long.
    None yet
    My mechanic told me over the phone that it could be the temp sensor that tells the motor how to run. It stumbles and idles very rough on cold start. After warming up it runs smooth as silk. Where is this thing located at? Can I change it out myself at home?
    96 v6 144xxx. 4x4
    Thanks
    dustin
  2. Feb 16, 2011 at 1:18 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    man I don't know where it is, and no one is answering so I'll throw in.. Check a book... maybe a parts site's exploded diagram. Might show you where it goes.
    and yes you can change it yourself at home.
    If it's the IAT sensor, look around the intake and its manifold. And I like the diagnosis. Though I don't know how prone they are to failure.
  3. Feb 16, 2011 at 6:08 AM
    dustinJ
    Dustin
    Amarillo tx
    None yet
    Thanks for your reply. He told me to drive it and that it may line out. I just thought I would go ahead and switch it out. This truck was beaten to death in the oil field for 144 thousand miles and not very well taken care of. Everything is caked up with oil and mud.
    Thanks again ill keep workin on it
  4. Feb 16, 2011 at 9:31 AM
    island808
    Jedediah
    hawaii
    You do a good tune up on it?
    Also, you might disconnect the battery and see if it resets something. The 4.0 is a newer generation sure, but it can get confused easily. Maybe the 3.4 is the same.
