96 tacoma rear diff help
Discussion in '1st Gen. Tacomas (1995-2004)' started by SiriusC1024, Jun 19, 2012.
  1. Jun 19, 2012 at 2:40 PM
    SiriusC1024
    SiriusC1024 [OP] New Member
    Braxton
    Terre Haute, IN
    1996 Tacoma 4x4
    Hello, I am new to this forum. The problem that brought me here is with the rear diff of my truck, and no one seems to have the answer.
    A bolt backed out of the ring gear and got caught between the ring gear and pinion, shearing some teeth. I can't find the replacement parts, nor can I find a junked tacoma within 200 miles of where I live.
    However, there are plenty of T100's. So what I am wondering is if anybody knows if I can directly swap the diff from a T100 into my tacoma? I know that they both use the 8.4 ring and the driveshaft will bolt up. Will the axle splines from my tacoma fit? Thank you.
  2. Jun 19, 2012 at 3:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i think as long as they are the same ratio as your front diff then yea it should work. Would almost just be easier to swap in a new axle if you pull it from a T100.
    Or you could just take this opportunity to put in some Yukon 4.56s or 4.88 gears..
  3. Jun 19, 2012 at 3:55 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
  4. Jun 19, 2012 at 3:56 PM
    SiriusC1024
    Braxton
    Terre Haute, IN
    1996 Tacoma 4x4
    Ok I was thinking about doing like you said and put the whole axle in from a T100, but isn't the wheel spacing different by 2" on the two trucks. That wouldn't have any affect on handling?
    And my truck is a dd and repairing it is urgent, so I don't think I'll go the new gearing route just yet ;)
  5. Jun 19, 2012 at 3:58 PM
    SiriusC1024
    Braxton
    Terre Haute, IN
    1996 Tacoma 4x4
    Thank you (post #3). I saw that site, but I didn't want to pull the trigger without some confirmation. Looks like my truck will be back on the road tomorrow hopefully.
  6. Jun 19, 2012 at 4:05 PM
    Slodgetto
    Silas
    Yeah..... I say just swap the 3rd. The t100 axles are about 67" wide whereas Tacoma axles are only about 60"!!! :laugh: (BTW, all that info is in the link I posted as well... ) ;)
  7. Jun 19, 2012 at 4:06 PM
    Slodgetto
    Silas
    oh ok, gotcha... :thumbsup: Good luck!
  8. Jun 19, 2012 at 4:12 PM
    SiriusC1024
    Braxton
    Terre Haute, IN
    1996 Tacoma 4x4
    Thanks guys. I'll update tomorrow to let you know how it goes.
  9. Jun 19, 2012 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oooo..maybe ill swap one back there why i go LT up front :p
  10. Jun 19, 2012 at 8:11 PM
    Slodgetto
    Silas
    Heck yeah, they're PERFECT for that!
  11. Jun 19, 2012 at 8:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Then id need bed sides tho i bet..hmmm..would still be cool tho :p haha
