96 tacoma strange starting problem help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by wireman24, Mar 8, 2010.
  1. Mar 8, 2010 at 2:13 PM
    wireman24
    wireman24 [OP] Member
    Twice now when I have tried to start my truck it starts up very ruff. When it did finally start I thought I could still hear the starter trying to turn over even though I had let go of the key. I then shut it off and pulled the key out and the truck was still trying to turn over all by it's self. I then stuck the key back in and gave it a turn and it started fine. This has happened twice now in the last 2 months. Other then these two times the truck has been running perfect.
    What do you think this is?
    I am thinking a bad starter maybe?
    How hard is it to change a starter on a 96 Tacoma?
  2. Mar 9, 2010 at 6:06 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    check the starter contacts. 4 cylinder is easier to change than v6 but not to hard.
