97, 2.4L Base Cab - Mushy Brakes on first Pump; firm on 2nd Pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by HairBear, Jan 27, 2017.
  1. Jan 27, 2017 at 10:55 AM
    HairBear
    HairBear [OP] Well-Known Member
    1997 2.4L Tacoma 2wd
    None
    1997, 2.4L Base: I just put new brake pads on, but this problem was there before the new pads/shoes. First pump on brake pedal gives a lot of travel although it does brake well. The 2nd pump on the brake pedal reduces the travel significantly.
    I put new pads and shoes on and bled the lines in the right order. During bleeding there were no air bubbles or spitting/sputtering. I drained a little over half the capacity of the reservoir during bleeding.
    Why is it acting like that? Should I replace the master cylinder?
  2. Jan 27, 2017 at 10:56 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Try bleeding it again. Sounds like still some air trapped in the system. If that doesn't help, THEN think about a new Master Cylinder.
    ClevSix and HairBear[OP] like this.
  3. Jan 27, 2017 at 12:17 PM
    HairBear
    None
    Thank you Skrain. Will do.
  4. Jan 27, 2017 at 2:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is there a particular reason you bled them after you put on new pads? You shouldn't have to do that just for new pads.
    But yeah, you probably have some air in the system. You might have sucked in some air from the master cylinder when bleeding. That can happen if you let the fluid level get too low in the reservoir.
  5. Jan 27, 2017 at 4:31 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    He had the issue before the hardware swap, thus the reason for wanting to bleed, trying to ditch the mushy pedal issue...
  6. Jan 28, 2017 at 8:37 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    When I learned about brakes (back in the olden days), what you are describing was an indication of air in the lines. Do a complete bleed to get rid of it and make sure to keep the MC topped off.
  7. Feb 3, 2017 at 12:17 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Bleed all four wheels. RR,LR,RF,LF. If there is no change. The new pads may not be "Bedded in" yet.
    It's normal for them to feel mushy for the first 5 applications or so.
    Mush Mouse likes this.
  8. Feb 3, 2017 at 2:51 PM
    HairBear
    None
    Thank you all for the replies. Your help is appreciated.
    Haven't bled them yet. Maybe in the morning.
    I only took the reservoir down half way, so I don't think I sucked air in last time.
    I am going to push more fluid through this time. Will watch reservoir closely.
    Are there any other possible causes for the mush? Only happens on first pedal push second push has much less travel; more like it should be.
  9. Feb 3, 2017 at 3:09 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Check rear adjustment.
  10. Feb 3, 2017 at 4:21 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Could it be a bad seal in the slave cylinder allowing fluid past it? Seems I did a repair a few years ago on a corolla like that. Toyota makes an OEM seal kit for the slaves, IIRC. that way you keep the higher quality slave. Easy to rebuild as well.
  11. Feb 4, 2017 at 6:06 PM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Like 10m said, carefully adjust the rear brakes.
  12. Feb 4, 2017 at 7:53 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Do a hard look around the master to is if you are leaking any fluid. Also look at all the wheel cylinders for fluid leaks. If you can't find any, then like they said above, check inside the rear hubs. It sounds like something is not right on the rear. Oh,,,,could be a bad hose, expanding on the first pump and then on the second pump you get pressure. Have someone push the pedal and you look at the hoses to see if they expand.
  13. Feb 20, 2017 at 10:19 AM
    HairBear
    None
    Many thanks to everyone for the help.
    I thoroughly bled them and I still have mush. I will try adjusting the rear brakes next. Note: I found the l hydraulic load adjuster and bled it last as per Haynes.
    Also, I read about pedal travel to point of solid resistance. 3.5" as per Haynes seems like a lot. Must admit though I do not completely understand. But I think new and correctly installed brakes should have little travel and be firm.
    Please respond with any suggestions or advice.
    Again, many thanks for your help.
  14. Feb 23, 2017 at 10:56 AM
    HairBear
    None
    10MGM you had it right the first time. I adjusted rear brakes today and the mush is gone. Pedal travel is normal and braking is improved. Looks like I should have adjusted them while changing pads. Derp!
    Thanks to all who pitched in.
  15. Feb 23, 2017 at 10:59 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    I have the same issue as you, how exactly did you adjust the rear brakes?
  16. Feb 23, 2017 at 12:51 PM
    HairBear
    None
    I took the drums off the rear brakes and adjusted to where the drums were moderately difficult to put on. While I was at it I cleaned the pads and hardware with brake cleaner.
