97 3.4 valve cover gaskets replacement Should I also replace...
Discussion in '1st Gen. Tacomas (1995-2004)' started by ironslippers, Jan 14, 2018.
  1. Jan 14, 2018 at 3:01 PM
    ironslippers
    ironslippers [OP] What? Me Worry?
    Colorado
    There is a stand alone throttle controller piece, a plunger type of thing with a black plastic cap at the top. There is a crack along the rim of the top. excuse me for not knowing the correct terminology? what's that called?
    There is a plastic wiring raceway along the top of the valve cover, the bolt tabs are broken off?
    Breather valve?
    I will reinstall the half moon pieces, inspect end plugs and replace the metal gaskets . I'd rather replace it now than disassemble again.
  2. Jan 15, 2018 at 6:26 AM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
