97 engine swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpamMan, Jul 1, 2020.
  1. Jul 1, 2020 at 9:27 AM
    SpamMan
    SpamMan [OP] Member
    97 Tacoma 2.4 2wd
    I was wondering if i could swap out my 97's 2rzfe for a 22re when the time comes, any thoughts or info?
  2. Jul 1, 2020 at 9:53 AM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    You can do anything with enough time and a welder... but why?
  3. Jul 1, 2020 at 10:48 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    The 22RE outputs 105 HP and 136 lb⋅ft of torque at 2,800 rpm.
    The 2RZ-FE outputs 142 HP and 160 lb⋅ft of torque at 4,000 rpm.
    Not only is it a MASSIVE downgrade, you'd need to swap the computer, engines harness, dash harness, amongst other thing. If you're swapping engines because your stock one is blown, put in a 3RZ-FE. It's a bored out version of the 2RZ-FE. They're basically identical, you might be able to get away with a new computer and re-pinning some connectors.
    Abeyancer and Black DOG Lila like this.
  4. Jul 1, 2020 at 11:16 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I get it.... the 22re has cheaper replacement parts and have a fantastic track record of being abused in those older trucks
    But I know from helping a buddy swap a 3rz to replace his 22re in an older pickup that you have to completely redo your exhaust system, the 22re comes out driver side and the 3rz/2rz come out the passenger
  5. Jul 1, 2020 at 11:33 AM
    SpamMan
    SpamMan [OP] Member
    97 Tacoma 2.4 2wd
    Its more so that im broke and my buddy currently has an 89 he wants to sell and im wondering if it would be a good stowaway motor in case my goes seeing as how im at 362k in it. Im aware of the downgrade, its a future plan thought
  6. Jul 1, 2020 at 11:36 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Why not just buy the 89 and drive it...then just rebuild yours as you can?
  7. Jul 1, 2020 at 11:41 AM
    0xDEADBEEF
    You'll spend more time and money making it fit than you would to grab another 2rz or 3rz and put that in.
    CrustyTaco, Wyoming09 and ToyoTaco25 like this.
  8. Jul 1, 2020 at 12:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I agree. Putting in that older motor is not worth it at all. Save up to rebuild the existing motor, or buy a good used one.
  9. Jul 1, 2020 at 12:55 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Even if you were given the 22RE
    The interesting thing the Tacoma fuel tank is on the left so your exhaust most likely will drop down make a 90 degree turn go to the right side make another 90 degree turn and go out the right side
    Trouble shooting your wiring issues with the OBI system would drive me crazy .
    Not only that the merging of the Engine Harness to the cab harness will be interesting .
    Do the engine mounts need moved ?? Is the block the same length from the engine mounts to the bell housing ??
    Now where in to driveshafts to long to short
    Really get the same engine save lots of frustration .
    If you were not broke and this was one of those because I can projects completely different story
  10. Jul 2, 2020 at 8:43 AM
    SpamMan
    SpamMan [OP] Member
    97 Tacoma 2.4 2wd
    Cause its an automatic transmission and its definitely going out.
    Thanks foe the input everybody. Im glad i asked yall first! Maybe ill buy the 89 and do a tranny swap.
    ToyoTaco25[QUOTED] and Wyoming09 like this.
