'97 Taco V6 4X4 5 speed R150F whining noise in 5th gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by leid, May 19, 2021.
  1. Jul 12, 2024 at 8:55 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    That sounds like a throw out bearing to me. I have the same exact issue and have just been living with it for a couple years. I do plan to fix it. New throw out bearing only runs about $40 last I checked, but unfortunately requires dropping the trans to replace
    Search YouTube for "Tacoma Throw Out Bearing Noise" and you'll be able to tell if that's the same thing you're experiencing.
    Black97v6MT[QUOTED] likes this.
  2. Jul 12, 2024 at 9:02 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    actually the throw out bearing is Also chattering away for the past couple of months LoL... but not at all funny since it was just replaced ~5 months ago
    But! that noise is Gone with just a slight depress on the pedal, pedal might need to be adjusted yet again?
    i can even hear the throwout bearing making noise in 1st and 2nd gear in motion if the RPMs are not high and/or other traffic noises to drown it out
    the mentioned concerning noise only goes away with full pedal down
    which could be the pilot bearing? IDK!?
    i have found the test for pilot bearing somewhere online need to find it again
    dropping the trans (again) is 6 to 9 shop hours :(
  3. Jul 12, 2024 at 9:05 AM
    Red_03Taco
    Jerad
    Hmm, that it is interesting. Mine is noticeable at idle only in neutral, but just a slight bit of pressure on the clutch pedal will stop the noise. Not sure if your symptoms indicate other issues like a pilot bearing too or poorly adjusted pedal. Maybe @gearcruncher could weigh in
  4. Jul 12, 2024 at 9:08 AM
    Black97v6MT
    iMA0
    tacoLand USA
    i still don't know What exactly stops rotating in there when the pedal is pushed all the way in?
    input shaft & bearing stop rotating or does it always rotate with the flywheel?
    the pedal did have to get re-adjusted because it would always flop back right near the end of the return stroke as soon as i took the foot off it would pop back and never did that before, it was always nice and smooth travel LoL
  5. Jul 12, 2024 at 3:19 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Preach! Hehe. When it's good it's great. And it's still good when it isn't great.
    leid[QUOTED][OP] likes this.
