97 Tacoma surges at a stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by justalilcrazy625, May 14, 2009.
  1. May 14, 2009 at 11:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you ever cleaned your MAF?
  2. May 14, 2009 at 11:10 AM
    justalilcrazy625
    justalilcrazy625 [OP] Got the yota feverrrr.
    Mooresville, NC
    '97 2.7L :)
    yupz. while I took the throttle body off and had part of the intake off I found that excuse to clean it. Cleaned the throttle body too, it was disgusting. But, being a northern truck and having that many miles on it and probably never being changed, it's expected I suppose.
  3. May 14, 2009 at 11:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you have the battery disconnected during all of this?
  4. May 14, 2009 at 11:13 AM
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    Yepper. Always when unplugging and messing with sensors & stuff. Plus the IAT wire bein messed up threw a code, so I kept it off for almost a week and it cleared the code.
  5. May 14, 2009 at 11:16 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Just curious... have you been in to have your frame inspection yet?
  6. May 14, 2009 at 11:20 AM
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    Not on this truck. But I had a 98 x-cab that they bought back for $12k, 140k miles, it was in excellent condition except the frame. I'm still kicking myself for not swapping motors into my tacoma, hahh.
    The frame on this truck is surprisingly good for the amount of miles it has on it and the fact that it's been a Northern truck for its whole life, plus playin' in the mud and mud bogs...
  7. May 14, 2009 at 11:24 AM
    ST77
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    WOW! Good to hear it's clean... so many trucks from the northeast are failing the inspections... Just didn't want to see you go through all this hassle if the frame was about to fail. sounds like you are moving in the right directions! Good Luck!
  8. May 14, 2009 at 8:11 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    sometimes in my 99 if i have my a/c on and come to a stoplight, when the compressor kicks in, my truck kinda jumps forward if you dont have the brakes pressed down hard......probably not your problem, but i thought i would throw in my .02
  9. May 15, 2009 at 11:50 AM
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    I don't have ac. Well, the truck is equipped with it but it's never worked sinceI had it. I'm gonna check the vacuum and see where that leads us
  10. May 15, 2009 at 3:21 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    that would definetly not be your problem then. hope you find out the cause soon. keep on keeping on:)
  11. May 15, 2009 at 5:19 PM
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    I don't want to start a new thread, but the truck won't idle when it's cold, I have to turn the idle up for it to actually idle. and when it warms up and i'm able to turn it down it still idles at 2,000RPM
    I'm gettin' aggravated now, lol
  12. May 15, 2009 at 6:07 PM
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
  13. May 15, 2009 at 6:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    You found no vac leaks right?
  14. May 15, 2009 at 6:18 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    This really seems like a problem with you MAF. And which the surging, it seems like a rich issue. Do you throw any codes?
  15. May 15, 2009 at 6:18 PM
    #35
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    Hehe. You were just trying to make "small talk" albeit....and he had to come rain on your pickup line.
    LOL
  16. May 15, 2009 at 6:20 PM
    #36
    ccollison
    ccollison Member
    battle ground Wa.
    08 dbl cab 4x4 sport
    GRILL CRAFT MESH GRILL, FLOWMASTER DUAL EXHAUST, WEATHERTECH FLOORMATS TRD INTAKE, PIONEER Z3 WITH NAV
    try a pcv valve
  17. May 15, 2009 at 6:25 PM
    #37
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    no vacuum leaks, fixed the exhaust, shes idling around 1500 now, it used to go up to about 1200RMPS until it warmed up and bouce back down to 7-800RMPS after warmup.
    No codes, MAF cleaned like 3 times
  18. May 15, 2009 at 6:27 PM
    #38
    dually
    dually Low and slow
    Thats normal than. Its going to idle high until it reaches around.. 140-180deg, then lower the idle.
    I wouldnt cbe worried, mine idles around 1200rpm ALL THE TIME! LOL
  19. May 15, 2009 at 6:29 PM
    #39
    justalilcrazy625
    Mooresville, NC
    '97 2.7L :)
    That would drive me crazy. lol I'm a perfectionist when it comes to my vehicles and I'm not happy unless everything is running smooth and no bumps in the road, lol
  20. May 15, 2009 at 6:32 PM
    #40
    dually
    dually Low and slow
    You would hate my build then... LOL
