98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Jan 2, 2018 at 3:11 PM
    #1321
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    I don't know how big that winch is but the radiator isn't really the issue it's the grill that's usually in the way. Or the mounts for the hood lever would be an issue before the radiator
    madmax700r[QUOTED] likes this.
  2. Jan 2, 2018 at 6:25 PM
    #1322
    TacRo517
    TacRo517 Well-Known Member
    Quinn
    LeadVegas Colorado
    99 Tacoma
    Too much to list....
    1999 on the way to New Years date
    Chipskip and jgill21 like this.
  3. Jan 2, 2018 at 8:34 PM
    #1323
    madmax700r
    madmax700r Well-Known Member
    Washington
    98 4bt swapped on tons and 43’s
    That’s true but I could always go hood pins. But my warn 8274 is 16.5" side to side X 8.5" wide X 15" Tall. Just not sure if it will Fit in that bumper cause I like it’s layout.
  4. Jan 2, 2018 at 9:02 PM
    #1324
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    I can take some meaurments in the morning and let you know if it'll fit or not.
  5. Jan 2, 2018 at 9:44 PM
    #1325
    madmax700r
    Washington
    That would be awesome! Thank you
  6. Jan 8, 2018 at 4:44 AM
    #1326
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Yes 01-04 Weathertechs fit. I'm running them, not a perfect fit but fairly close
  7. Jan 8, 2018 at 10:27 AM
    #1327
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Thanks I couldn't find an exact answer (I almost pm'd you) so I ended up complaining to Amazon and they finally shipped out the correct set of huskies and gave me a 30 dollar credit for the trouble.
    jgill21 and BYJOSHCOOK[QUOTED] like this.
  8. Jan 10, 2018 at 2:06 PM
    #1328
    Tacoma1776
    Tacoma1776 Member
    2000 Tacoma
    what size lift ?
  9. Jan 10, 2018 at 2:07 PM
    #1329
    Tacoma1776
    Tacoma1776 Member
    2000 Tacoma
    Lift ?
  10. Jan 10, 2018 at 6:27 PM
    #1330
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Another guy on here said he removed all the wiring from the plastic controller box and moved the wiring into his engine bay.
  11. Jan 10, 2018 at 6:40 PM
    #1331
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    I have to small of a brain for that hahaha. I'm just trying to stop my truck from leaking water. That's a good idea though since the wiring won't be exposed at all
    Dalandser[QUOTED] likes this.
  12. Jan 10, 2018 at 6:50 PM
    #1332
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Leaking coolant?
  13. Jan 10, 2018 at 8:40 PM
    #1333
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    No after tubbing the firewall I have some small leaked still that I’m tracking down.
  14. Jan 10, 2018 at 8:43 PM
    #1334
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What side?
    https://www.tacomaworld.com/threads/the-infamous-passenger-side-leak.415269/
    Could be related to tubbing - who knows if all that beating (or cutting if you're more of a technician than a caveman) could have pressed apart some sheet metal - non likely as much as the leaking coming from your newly joined firewall parts. I read about a guy using gutter sealer and he said it worked well...
  15. Jan 10, 2018 at 8:57 PM
    #1335
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    It looks like it’s coming from the bottom of where I tubbed that was the hardest part for me to weld since it was so dark. I’ll try that gutter sealant I read about that being really good as well.
  16. Jan 11, 2018 at 6:00 AM
    #1336
    BYJOSHCOOK
    Josh
    Check Out My Builds
    About 2.5" I'd say :notsure:
    I've got Kings so I can adjust them to any lift I want that's in the range
  17. Jan 12, 2018 at 1:51 PM
    #1337
    stecow
    stecow Member
    1998 Red Tacoma SR5 4X4
    This is my baby, 1998 3.4 SR5 4x4
  18. Jan 12, 2018 at 2:20 PM
    #1338
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports Mid Travel LCA, Fox 2.0, All-Pro Exp Leafs, 285/75/17 BFG KO2s
    4.0?
  19. Jan 12, 2018 at 3:07 PM
    #1339
    stecow
    stecow Member
    Um yeah, amateur hour. Its not a 4.0L, its a 3.4, my bad. When I first got it I must've read the specs too quickly and thought it said 4.0L
    GEENYUSS[QUOTED] likes this.
  20. Jan 12, 2018 at 7:52 PM
    #1340
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    That would be a sweet engine swap. 4.0L into a 1st gen :)
    stecow and GEENYUSS[QUOTED] like this.
