98-00 to 01-04 Front End Conversion Build & Write Up
Discussion in '1st Gen. Tacomas (1995-2004)' started by WildLand, Apr 1, 2015.
  1. Apr 9, 2015 at 7:12 PM
    #81
    WildLand
    WildLand [OP] Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I see I see.
    That reminds me, I should probably adjust my headlights!
  2. Apr 9, 2015 at 7:17 PM
    #82
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Soo there's nothing at all wrong with the emblem that I can see, haha, musta been confused with the one on my truck now ha, says pn75311-04020 on the back, mounts with 3 tiny screws at 10,2, and 6 o'clock., pm me your info and cell #if u want a pic of it
  3. Apr 9, 2015 at 7:21 PM
    #83
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Nice! Truck looks great!
  4. Apr 9, 2015 at 7:26 PM
    #84
    WildLand
    Josh
    NM
    16T4RSR54WD
    Haha perfect! PM sent
    Thanks man! Too excited :woot: I got that silver sample in the mail, way too dark. So I ordered the brushed aluminum sample and will see if that is closer
  5. Apr 9, 2015 at 7:28 PM
    #85
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Awesome, glad they sent out samples!
    Interested to see how the hood looks wrapped
  6. Apr 9, 2015 at 7:31 PM
    #86
    WildLand
    Josh
    NM
    16T4RSR54WD
    Ya me too. If this silver isn't nearly close then I may just paint it myself. Actually look for duplicolor locally that SAYS lunar mist. Not Amazon that says lunar mist and sends me sharpie silver metallic
  7. Apr 9, 2015 at 7:33 PM
    #87
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Yeah, you must have gotten something off. My duplicolor was a great match, i just needed more clear.
  8. Apr 9, 2015 at 8:10 PM
    #88
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Don't forget ours is custom faded :rofl:
  9. Apr 9, 2015 at 8:18 PM
    #89
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Glad those headlight brackets worked out
  10. Apr 9, 2015 at 8:24 PM
    #90
    WildLand
    Josh
    NM
    16T4RSR54WD
    Haha yeah seriously
    Thank you for recommending those. You're right, that is definitely the way to go. It would not work without them! And since you gave me the part number the dealership went from $37 each to $30 so saved my some money. Thanks again! +1 rep
  11. Apr 9, 2015 at 8:43 PM
    #91
    zeekevin
    San Diego
    If you buy parts from the dealer, you can always have them price match the online prices
  12. Apr 9, 2015 at 8:45 PM
    #92
    WildLand
    Josh
    NM
    16T4RSR54WD
    ... Damn, I wish I knew that. That was my first time at a dealership haha
  13. Apr 10, 2015 at 2:51 PM
    #93
    WildLand
    Josh
    NM
    16T4RSR54WD
    Finishing write up.
    Update. Remove old headlight brackets.
    There are 4 spot welds that hold the original headlights onto the core support. You will want to feel for the spot welds and drill them out. I just used a standard drill and bit.
    Next you will want to take off the 3 bolts that connect the fender to the front. One on top. One in front. And one on the side near the bumper. The black fender bracket will slide have to be put in place. I had to bend a piece - on the bottom near the front fender bolt. It bends toward the bolt and impedes on the connection between the fender and the core so I bent it the other way.
    Bolt up the bolts you took off and put the headlight in. There were some plastic pieces on the headlight that did not fit with where the fender connects in the front so I broke them off, they seemed to have no purpose.
    If you have any questions let me know! I probably forgot stuff
    j0shu4 likes this.
  14. Apr 10, 2015 at 4:08 PM
    #94
    WildLand
    Josh
    NM
    16T4RSR54WD
    PICTARS!!
    Painted bumper fillers white for now
  15. Apr 10, 2015 at 5:14 PM
    #95
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    No f'n way.. Wish I would have known that, good writeup btw.
  16. Apr 10, 2015 at 5:15 PM
    #96
    WildLand
    Josh
    NM
    16T4RSR54WD
    I know right?? I wish I knew that... Thanks! Glad you got this knowledge out of it haha
  17. Apr 10, 2015 at 6:24 PM
    #97
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    So do them Jerkies at the stealership charge you to look up a parr number!?!?
  18. Apr 10, 2015 at 6:31 PM
    #98
    WildLand
    Josh
    NM
    16T4RSR54WD
    Haha seems so! But no, he was trying to find the part and when I told him the part number it came up as $37 but he said since I had the part number then he would drop down to $30
  19. Apr 10, 2015 at 7:48 PM
    #99
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Nice job! looks OE bud, gotta sort out that bumper though
  20. Apr 10, 2015 at 7:58 PM
    #100
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks!
    Yeah I didn't want to deal with the bumper because there is so much more to go with that. We will see though
