98 3.4l Tacoma Fuel Filter Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by haneth, Mar 3, 2012.
  1. Mar 3, 2012 at 3:51 PM
    haneth
    haneth [OP] Member
    I got lassoed into changing the fuel filter on my girlfriend's truck (a guy's gotta do...) and am assuming that this link works with her model:
    http://www.customtacos.com/tech/index.php?article=175
    If this is the case, I am having a helluva time finding that fuel filter relay to disconnect. Any tips? I found the filter itself, but I need to purge the system, apparently...
    Thanks!
  2. Mar 3, 2012 at 4:02 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I disconnected the battery and cracked the gas cap when I did mine. (I didn't even look for a fuel filter relay.) I suffered no "injury from gasoline under pressure" and my truck's running just fine... ;)
    The biggest hassle in the whole job was getting the new filter properly aligned and tightened (in spite of the fixed/rigid lines). FWIW, I installed a WIX 33319 filter.
  3. Mar 3, 2012 at 4:30 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Remember the gas is on the tank side, so you want to start by removing the front (towards the front bumper) first, then the back. There are really only a few hand wrenches you'll need. Nothing special. Put a cresent wrench on the front side, and use an open end wrench to unscrew while holding the cresent wrench. Do the same for the rear, re-install. Put a drip pan underneath you, it's not going to spill everywhere should only be a few drops. Last if you open the gas cap BEFORE you start that will relieve some of the pressure. Overall about a 15-30 min job.
  4. Mar 3, 2012 at 5:08 PM
    haneth
    haneth [OP] Member
    Thanks guys. Mission accomplished!
    Unfortunately, that didn't stop the slight stuttering it was starting to due under acceleration...any ideas there?
  5. Mar 3, 2012 at 5:18 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    the filter had no gas, it had to be pushed thru the system. When I changed mine, I didnt disconnect the fuel pump relay..
  6. Mar 3, 2012 at 5:20 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Try the cheap thing first, add a can of fuel treatment. Second, when was the timing belt and idler last replaced, do you know? If it is the idler, the engine will smooth out and come up on power as it approaches 2000 RPM pulling away from a stop.
  7. Mar 3, 2012 at 6:42 PM
    haneth
    haneth [OP] Member
    Timing belt done recently. Not sure about the idler. The higher the rpms, the more chattery it becomes. Hard acceleration causes stuttering.
    I have seafoam-can I just put the recommended amount in the tank? Will I need to replace the fuel filter again? I guess I could throw the old one on it for the fuel treatment.
  8. Mar 3, 2012 at 7:30 PM
    wolftree
    Rick
    Ohio
    I am assuming when you said fuel pump, you meant filter. No, you do not need to change back to the old filter. Add your sea foam or other fuel treatment to a full tank of gas. Run that tank completely out before adding more fuel treatment to another full tank. Use only the amount recommended, do not double up thinking if one is good, two is better. Try this before moving on to other "fixes".
  9. Mar 3, 2012 at 8:33 PM
    haneth
    haneth [OP] Member
    Corrected my language. You were correct. And thanks for the advice. Let's hope it works.
    Oil change tomorrow.
  10. Mar 3, 2012 at 9:59 PM
    Norton
    I'm thinking standard tune-up stuff... When's the last time the plugs and air filter were changed?
  11. Mar 4, 2012 at 9:54 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    IMO I would add a full can to 1/2 tank of gas for better results, its more concentrated this way and more effective.
    Also its a good thing to seafoam the intake to clean the pistons and intake manifold as well.
    Spark plugs are normally standard ones so thay have a short life, I would change them, cheap and easy..people often overlook general maintenance.
  12. Mar 4, 2012 at 10:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I disconnected the battery when I did mine (and that was it).
    I did have to disconnect the hard fuel lines from the underside of the body on both sides to have enough movement to get the filter in/out.
    Easy job.
    Just make sure you catch the gas in a bucket, have a fire extinguisher handy, and you're not exposed to any ignition sources.
  13. Mar 4, 2012 at 11:37 AM
    wolftree
    Rick
    Ohio
    Speed Freek,
    Adding too much fuel treatment at one time is a good way to damage his oxygen sensors. I learned the hard way on this. I have never used Seafoam, so I do not know if it would be the same or not as other fuel treatments. I do agree about spark plugs and air filter being next on his list though.
  14. Mar 4, 2012 at 1:21 PM
    Jenkinstall
    Jenkinstall Active Member
    Jennings
    Colimbia, sc
    00 SC 4Runner Sport Edition 4wd
    Suspension/Drivetrain: 4wd swapped, E locker in rear with 4.30 gears, tundra 5100 adj. bilstein shocks, Trd coils, ome 891 springs with tundra shocks in back. Addicted offroad front tube bumper with BashFab hoops and stingaaaa, BashFab rear tube bumper, 285/75/16 BFG K02, tacoma wheels, savage offroad trans and t case skids and homemade gas tank skid. Engine: 2nd gen TRD SC, URD 7th, 2.2, TRD T-stat, IK-22 Plugs, TRD boost gauge, AEM wideband, ISR mod, and more to come. Interior: Kenwood marine stereo with Bluetooth
    never add anything to your tank. it does not do a damn thing. find a shop who has the MotorVac Carbon Clean fuel system cleaner machine and get a fuel system cleaning and you will notice an extreme difference. those additives will screw up more stuff then fix. its a waste of money. there is no such thing as a mechanic in a bottle.
  15. Mar 6, 2012 at 8:35 AM
    haneth
    haneth [OP] Member
    Spark plugs done 2 years ago-over 30k put on the rig since then. Looks like that's where I'll start.
    I may hold off on the Seafoam-the last thing I want to do is mess up a bunch of sensors. Nay-sayer's comments making me nervous.
    If the plugs don't work, what's the next step?
    This truck needs some love.
  16. Mar 6, 2012 at 9:10 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  17. Mar 6, 2012 at 9:23 AM
    wolftree
    Rick
    Ohio
    haneth,
    I would try one can of fuel treatment in a full tank of fuel. You are correct about spark plugs. They are due I expect. I always changed mine around 25,000 miles. I changed coil packs every other spark plug change. Also change the PVC valve and air filter. Inspect the wires going to the coils/spark plugs. If you see cracks in the covering(rubber) consider replacing the coil packs. This is a little pricey ($70-80) but, easy to change. It would not surprise me that the coils are original, that is a lot of years, But hold off until you have done the other maintenance items first because of expense. Just take it one step at a time. As you said, it needs a lot of love.
    Is this truck 2 or 4 wheel drive? I know 4 wheel drive has 5 grese zerks on driveshafts, 3 on main, 2 on shaft to front axle. I do not know if or how many on 2 wheel drive.
  18. Mar 6, 2012 at 9:34 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    and i like to study a broad base of information, here are a few this one, the second post has alot of links
    http://forum.ih8mud.com/95-gen-toyota-trucks/341631-3rd-gen-4runner-faqs.html
    and this one, could help it seems like a little pain in the ass when its dying
    http://www.yotatech.com/f123/do-not...replacing-tps-throttle-position-sensor-91567/
    hope this helps, dont think anything could be wrong with the fuel pump, usually they just die, (at night on a dark road) and most fuel filters have a bypass on them so when they get full you just run the garbage through your engine, (and believe me no matter what they say, gas is full of shit) i have always changed mine once a year, its not hard and its not expensive.
    and I have been using seafom for almost 10 years with no trouble, I had a stang 4.6 and they just love to get clogged up, I did her once a year also, and when I got my truck, I did alittle at a time and drove her around, and I was fogging for bugs!!
    one thing i believe is alot of 4.6 owners started having bad carbon buildups after the gov. said everyone had to use 10% corn eth. and now they want to push it to 15% our motors really dont get hot enough to fully burn it, and you get carbon build-up in the motor.
  19. Mar 18, 2012 at 4:31 PM
    haneth
    haneth [OP] Member
    Ok. Seafoam in a full tank of gas (I know, I know. Probably a waste of time). New fuel filter and just changed the spark plugs. Still doing it. And by 'it', I mean that it pretty much stutters all the way up the rpm tree in every gear. It's not debilitating-I can get up hills, accelerate to speed, etc., but it is a definitive 'stutter'.
    Could it be some sort of vacuum hose?
    Any suggestions appreciated.
    PS-V-6 4x4
