98 5 speed manual rolls while parked in gear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StaticFilter, Jan 30, 2012.
  1. Jan 30, 2012 at 4:41 AM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    The last 2 times I've parked my truck in a steep driveway and put it in gear it's slowly rolled back several feet before i got back to it. My parking brake is shit so thats not an option what am I looking at? Bad clutch? Bad tranny?
  2. Jan 30, 2012 at 5:12 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    What gear was it in? Reverse is the lowest and least likely to move. Unless the clutch is shot (slipping) or the engine is light on compression there is not much you can do to keep it in place if the trans is broken it would be at the bottom of the hill. Fix the parking brake they work great when they are applied.
  3. Jan 30, 2012 at 9:35 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Was it just a ridiculously steep hill? I didn't think it would roll at all in 1st but mine will... and roll relatively fast. I was trying to push start it with absolutely no battery juice... and I mean absolutely none. I popped the clutch in first and it just kinda went put put put as the engine was turning without the fuel pump engaging or injectors or spark plugs firing. I figured the wheels would just lock but it will actually roll. I don't see how it would just roll a little though... Once it breaks the engine loose it should keep going. You sure it isn't physically sliding?
  4. Jan 30, 2012 at 9:41 AM
    fsusteve
    fsusteve Well-Known Member
    Naples, Fla
    Mine does it on a decent inlcine and I have a strong clutch and engine compression, I figure the 35's are just a little heavy for the driveline.
  5. Jan 30, 2012 at 7:44 PM
    StaticFilter
    Cedar Hills, UT
    I'm positive it's rolling, but only a little at a time. I don't know if i've tried Reverse, but first gear rolls, really slow, like the engine compression is TRYING to hold it back, but then it turns over, a few seconds later, it rolls more, again and again. I suppose I'll try reverse tomorrow. Would a tire shop be able to adjust the parking brake?
  6. Jan 30, 2012 at 7:50 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    how steep of a hill is this? sounds big
  7. Jan 30, 2012 at 7:53 PM
    StaticFilter
    Cedar Hills, UT
    I dunno, they are just driveways. 30-45 degrees?
  8. Jan 30, 2012 at 7:58 PM
    TACOMABOSS
    96 SR5 4x4
    45 is pretty steep. the parking brake adjustment is easy. but if its not the adjustment thats the issue i have no idea. to adjust it you just tighten the nuts under the frame. if you get under and look you will see it. its easy to spot
  9. Jan 30, 2012 at 8:10 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Put it in low range.
  10. Jan 30, 2012 at 8:31 PM
    lbhsbz
    lbhsbz Well-Known Member
    Ever heard of ring gaps? Pistons and cylinders don't seal 100%....especially under static conditions. It doesn't matter what gear it's in, it will leak down and your truck will move on any kind of a hill. Fix your parking brake or carry some wheel chocks?
  11. Jan 30, 2012 at 8:33 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    manual trans means you need a functioning parking brake on steep hills. Low range might work.
  12. Jan 30, 2012 at 8:37 PM
    lbhsbz
    You shouldn't ever need to adjust the nuts on the cables. Adjust the shoes themselves. If the drum and shoes aren't worn out and the shoes are adjusted properly, the brake should work fine. Properly adjusted, you should get about 4 or 5 clicks on the handle before you can't pull it up anymore
  13. Jan 30, 2012 at 8:44 PM
    STLharry
    Harry
    VT
    FSM says 12-18 clicks.
  14. Jan 30, 2012 at 8:51 PM
    lbhsbz
    Crap, I was thinking 4 runner with a lever, not a pull handle....handle should move about 3 inches
  15. Jan 31, 2012 at 4:46 AM
    StaticFilter
    Cedar Hills, UT
    Thanks guys, I'll look into the drum adjustment, just seems like this was never an issue before...
  16. Jan 31, 2012 at 6:05 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Adjust the rear brakes first then adjust the cable if it needs it. The type 1's were famous for the pivot rusting up where the cable attaches to the lever on the backing plate then the parking brake would not release some thing to check after you get the brake working.
  17. Jan 31, 2012 at 11:38 AM
    scotrinaf
    scotrinaf Well-Known Member
    Scott
    Blountville, TN
    04 PreRunner TRD SR5 4x2 2.7L
    Leer 100XQ, Yakima Roof Racks
    45 degrees? LOL Bristol Motor Speedway has a 38 degree bank that will nearly roll a car if it comes to a stop on the high side... hehehe Driveways are more like 5-10 degrees, maybe 15-20 in the mountains...
    Yes, any tire/brake shop should be able to adjust it.
  18. Jan 31, 2012 at 1:53 PM
    shampoop
    southwest WA
    lots of driveways around here are around 30 degrees. One of my neighbors driveways was probably 40-45 degrees before they dug it out and added another whole story to their house underneath what used to be ground level. It's still probably 15-20 degrees now.
  19. Jan 31, 2012 at 2:00 PM
    Silver02Taco
    Silver02Taco #DevilHornGang
    Will
    San Jose, Ca.
    2002 Xtra-Cab 4x4, V6, SR-5, TRD Off-Road
    Some Relentless Fab, some Bay Area Metal Fab, some Total Chaos Fab, some ADS, some King...
    With drum brakes in the rear, can't you put it in reverse - gas it - and hit the brakes hard and they self-adjust? I know it worked for my '93 2wd 'yota. :notsure:
  20. Jan 31, 2012 at 2:41 PM
    StaticFilter
    Cedar Hills, UT
    What the.... Anyone know if this would work? haha sounds easier than jacking it up, removing the wheel, tearing the drum apart, adjusting, putting it all back together...
    There are some steep ass driveways here, my sons daycare lady has one and my buddy has one, maybe not 45 degrees but very significant. I'll check with a protractor if i can remember to bring one home from work
