98 Cardan joint issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98Toyboy, Dec 22, 2014.
  1. Dec 22, 2014 at 4:45 PM
    98Toyboy
    98Toyboy [OP] Member
    Central Canada
    98 Tacoma
    Newbie here, just found this site while researching my options...
    As obvious, I have a '98 Tacoma, 6 cyl, ext cab. While replacing my rear universal and hanger bearing I found some unwanted wear in my Cardan bearing, even thouth the two universals seem fine... I linked to a thread here about it, but when I went away to register, I lost it.
    I realize that I'll probably destroy the two universals getting to the centering bearing, so in essence, I am looking for both u-joints, and the center brg.
    Additionally, I have a '92 parts truck, and even though according to Toy, they are different part numbers, are they the same part... ie swappable?
    Any help is appreciated.
    thanx.
    T.
  2. Dec 22, 2014 at 5:55 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    This the thread? http://www.tacomaworld.com/forum/1st-gen-tacomas/273119-double-cardan-joint.html
    Start at post 7 and 10. Done correctly nothing gets destroyed.
    The real question is going to come down to why you think the centering ball is bad. It's an extremely durable part that with minimal attention will outlast the rest of the truck. Read the thread a couple of times and get back to me with any questions, preferably in the linked thread.
    As far as the 92 and swapping, there is a chance but you are entering the outer limits of the Toyota parts interchange world. Do not trust any parts house application guides. It will take a caliper and a complete tear down of both DC's to know for sure and it might end up being the front shaft (parts) from the 92 that fit your rear (if the 92 has a DC front shaft, I don't remember). I would not recommend swapping center balls from one DC to another. Just buy a new center ball "kit" with new ball, needle bearings and ball seal and there are 2 of those depending on shaft or "center pin" diameter.
    98Toyboy[OP] likes this.
