98' Taco 2WD Wheel Spacer ?
Discussion in '5 Lug' started by Apfrank2008, Dec 21, 2010.
  1. Dec 21, 2010 at 2:38 PM
    Apfrank2008
    Apfrank2008 [OP] Member
    98 Taco 2WD 2.4L Reg Cab
    Can anyone recommend me a place to purchase 2" wheel spacers for the rear that'll fit a 98' 2WD Taco? I can't seem to find any websites for my vehicle that list spacers. I don't want junk either, i'd like to do it the right way.
  2. Jan 5, 2011 at 5:11 PM
    Apfrank2008
    BUMP, still haven't found anything that I trust.
  3. Jan 5, 2011 at 5:22 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
  4. Jan 5, 2011 at 5:28 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I don't think your going to have much luck on that. I am not trying to be a smart ass by saying this, but doing it the right way would be to get the right rims for your truck.:)
  5. Jan 5, 2011 at 5:45 PM
    Apfrank2008
    Agreed, but, when I put the 3" spindle lift on the front of my truck, it never said anywhere in the description that it was manufactured with a 2" offset. Needless to say after I got it installed I noticed it and didn't feel like making a big deal out of it because it was such a pain in my ass to install. So, this is my only option unfortunately. I have the correct wheels for my truck by the way, OEM. I know allpro has hub-centric spacers but nothing available for a 5 lug wheel. Spidertrax has a hub-centric 5 lug spacer but not available for a 98 2WD Taco. The 2WD is really killing me on this spacer hunt.
  6. Jan 10, 2011 at 12:27 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    http://www.ezaccessory.com/
    Check these guys out and give them a call. I've never bought anything through them, but looks like you can get something custom. You probably need to run hub-centric adapters and ask them if their hardware is grade 8.
    A little side note to help you out with preventing future issues. Check the bedsides for clearance. 2" is a big difference in the rear. I'd recheck your tire width in the front and back. I don't think lift spindles kick out each side 2". It might be just 1.25" If you don't mind me asking, why don't you like the slight offset up front?
  7. Jan 10, 2011 at 3:14 PM
    Apfrank2008
    You're probably right about the 2", I forgot that my aftermarket wheels had a lot of backspacing and they were extremely wide which probably made the spacing seem a lot worse than it really was. I just put my OEM wheels back on with some snow tires that are stock size and it doesn't seem as extreme. I'll take some pics tomorrow so you can see for yourself. I've always been a fan of things matching so thats why the offset up front bugged me. It was a eyesore staring down the side of my truck and seeing the difference in width. Also, I purchased a bullbar/skidplate for my 98 and was wondering since the taco in your picture looks around the age of mine and has a bullbar/skidplate if the front bumper was a b**** to remove or not. Also, what did you do with your bumper mounted turn signals?
    Edit: just found these spacers, anyone think i'll have problems mounting these on my 98' Taco 2WD? http://www.andysautosport.com/toyota/1995_2004_tacoma/wheels/wheel_spacers/ichiba/ichi00000439.html
    They say they are hubcentric and my bolt pattern is 5x115mm, these say they are 5x114.3 which i'm assuming will fit.
  8. Jan 11, 2011 at 12:56 AM
    MadTaco461
    CA
    Kinda stock
    I couldn't tell you if the front bumper is a pain to remove. Can't be too bad. Mine front bumper is custom. For blinkers, I have a tab welded on and a DOT approved halogen blinker that I spliced into the main wires. It didn't make the crazy fast blinker thing you see on cheap civics trying to do LEDs blinkers. Do a search on here, all the first gen bumpers are the same mounting for the most part. Those look like the right type of spacers. Just measure to check your offset just in case. HAHA don't think there is a fix for my offset until I switch my axle out for a ford 9 inch. Yes our lug pattern is 5x114.3mm or 5x4.5"
  9. Jan 19, 2011 at 12:56 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    You can get 5 lug spacers off ebay. Just make sure you get the correct bolt pattern, 6061 billet aluminum and that the center bore is large enough. I recommend 1.25 or 1.5 spacers at the most. Don't forget loctite blue.
  10. Jan 19, 2011 at 2:44 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    ^x2 there are plenty of spacers for 5x114.3 but for anything very wide I'd use extended
    Studs
  11. Jan 19, 2011 at 3:08 PM
    Trifenix
    so cal
    99 LT 5 lug Taco
    ^2 u dont need extended studs if you get the adapters. they bolt on and are not just thick spacers.
