98 Tacoma 3.4 engine tick
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98 Tacoma 4x4, Jan 12, 2017.
  1. Sep 21, 2018 at 12:29 AM
    #81
    00trdSC
    00trdSC Member
    Denver
    2000 Tacoma 3.4 TRD Supercharger
    Supercharger 2nd gen, URD 7th Injector
    I just read through your thread. Your noise sounds very similar to an issue I had with a 2000 Tacoma 3.4.
    I was concerned it was a rod bearing gone, but no evidence of metal shavings in the oil. The suggestion came up maybe it was a stuck valve lifter, as my latest oil change had been close to 1000 miles after my regular interval, and the truck was 225k+ on the clock. It was recommended I treat this by changing the oil, shorting half a quart of engine oil and making up the difference with half a quart of tranny oil. Something about the different viscosities would help free the stuck lifter. Ran that for 500 miles with the tranny oil in the engine and then did a normal oil change, and the noise was gone.
    Did you ever figure out what your noise was?
  2. Sep 21, 2018 at 6:29 AM
    #82
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    The 3.4 has "shim over bucket" lifters. They're not hydraulic and therefore cannot "get stuck". The shims can be changed out for valve clearances, although this is very rare to ever require this. Just FYI
  3. Sep 21, 2018 at 9:40 AM
    #83
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    This is why I love the first gen forum.
    Lot of knowledge and people getting dirty.
