98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. May 25, 2015 at 3:07 PM
    #181
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Yup
  2. May 25, 2015 at 6:09 PM
    #182
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Got my new rims on with some used BFG mudders for now. I really like the 17" rim. Not too big, but a little more than stock.
  3. May 25, 2015 at 7:43 PM
    #183
    GioGuitarDude
    Gio
    Cold air intake
    Looks really good dude. Too big of tires and your truck won't be as fast :cool:
  4. May 26, 2015 at 4:32 AM
    #184
    j0shu4
    For sure, I am rethinking my tire choice. May not end up going with 35". These BFGs are just temp until I can afford new ones. I think I will settle with a 33" all terrain probably.
  5. May 26, 2015 at 5:22 AM
    #185
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  6. May 26, 2015 at 6:55 AM
    #186
    j0shu4
    Yeah, if I do go 35" I will regear to 5.29. The extra weight and rolling mass will always slow you down some. Like you said Chris, I'm hoping the gears would keep you close to stock speeds, plus the turbo should give it more than plenty "go juice."
  7. May 26, 2015 at 6:30 PM
    #187
    GioGuitarDude
    Gio
    Cold air intake
    What is your gear ratio now? I would argue that with the turbo, you wouldn't have to mess with gears regardless if you are rockin 33s or 35s.
    5.29 gearing, 35s, AND a turbo is a recipe for a busted up rear end. 4.10s and fully treaded BFG R A/T 31 10:50s (yeah yeah, I know) have served me amazingly not only on the street (speed wise [0-60 in 8 secs @ 5psi]) but in/on dang near every mountain range in colorado.
  8. May 29, 2015 at 7:48 AM
    #188
    j0shu4
    I want big tires so chevy and ford's don't laugh at me.
    Haha.....
    :pout:
  9. May 29, 2015 at 7:58 AM
    #189
    j0shu4
    Actually when I switched to these 9" wide rims and little bigger tires, my bae handles way......way better. The wider track width and more meat on the road keeps all those little (and some big) potholes from literally rocking my truck. I can imagine bigger tires (and a LT kit) will tremendously improve stock handling. For the $$$$ I should think so. Oil pan and turbo going on this weekend. You may have to give me some real time advice on things. Please, and thank you.........
  10. May 29, 2015 at 9:45 AM
    #190
    GioGuitarDude
    Gio
    Cold air intake
    Lol they won't be laughing when they're looking at your tailgate! I tell you what, these light little trucks can go more places than most v8 domestic trucks can, and with a turbo it's laughable. 5500 lb trucks with 350hp are easy pickens for a 3400 lb taco with a turbo
  11. May 29, 2015 at 11:03 AM
    #191
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Wouldn't say long travel makes handling better, but it's pretty cool
  12. May 29, 2015 at 11:47 AM
    #192
    j0shu4
    I'm just doing it (LT) because of the horsepower it adds, plus it makes my 3rd member thicker. (Um, that's a joke)
    Really, my assumation would be that it would depend on your shock spring rate and valving. I'm going lite, not jumping the thing pretty much ever. Also thinking there is no comparison to stock ride vs.an LT ride.
  13. May 30, 2015 at 10:15 PM
    #193
    GioGuitarDude
    Gio
    Cold air intake
  14. May 31, 2015 at 8:38 AM
    #194
    j0shu4
    Changing out my oil pan. Cannot drop the diff completely. I think I need to remove one of the axles to get it sideways enough. Oil pan is off. It won't come out without the differential almost completely out. Ugh. How can I pull one of these axles? Through the tire and hub I'm going to go.
  15. May 31, 2015 at 2:41 PM
    #195
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You need to pull both axels, put the drive shaft, and loosen the steering column to get the diff out.
  16. May 31, 2015 at 8:41 PM
    #196
    j0shu4
    Omg! I won't ever do that again. Got the diff back in. Only pulled 1 cv and didn't touch the steering rack.
    Omgggggg! Pain in the arse!
    Put the an12 oil drain on ready to mate to the turbo. Exhaust cut off per Mr. Gio, you rock for the help! Stock headers coming off soon.
  17. Jun 1, 2015 at 9:59 AM
    #197
    j0shu4
    Goodbye old stock exhaust system. You served the truck well for 17 years, and still would've kept going.
  18. Jun 1, 2015 at 11:48 AM
    #198
    GioGuitarDude
    Gio
    Cold air intake
    They grow up so fast :pout:
  19. Jun 2, 2015 at 8:10 PM
    #199
    j0shu4
    Plumbing these things is a pain in the ass! Wait, everything about this is a pain in the ass!
  20. Jun 3, 2015 at 5:02 AM
    #200
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Looks good. See if you can get the oil feed and oil drain to sit as perpendicular as possible, otherwise you will get oil leakage in the intake.
