98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Jun 8, 2015 at 6:39 PM
    #221
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude....the wheels are the same...on both turbos...
  2. Jun 8, 2015 at 6:46 PM
    #222
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Yes. I actually would have gone with that but wanted the direct vband to downpipe connection to avoid clearance issues against the firewall. Just sayin, smaller wheels spool faster too.
  3. Jun 8, 2015 at 6:49 PM
    #223
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know smaller wheels sling faster. But the tighter exhaust housing on the same turbo would make it even faster. That was my point.
    And it's avalible.
    Id be willing to bet cxracing can make it v band too. But who knows.
  4. Jun 8, 2015 at 6:53 PM
    #224
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  5. Jun 8, 2015 at 7:14 PM
    #225
    Blackdawg
    Monte
    Wyoming/St. Louis
  6. Jun 9, 2015 at 11:10 AM
    #226
    j0shu4
    Got to send my methanol controller back in for repair/replace. Under warranty. Kept pumping nonstop for some reason??? Might have hooked it up wrong. All turbo lines are leak free. Having overflow diff oil coming out of the front passenger side axle I pulled. Prolly filled it up too high.
  7. Jun 9, 2015 at 11:14 AM
    #227
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Have to blow up the auto first. Why do you think I got a turbo in the first place?
    unstpible likes this.
  8. Jun 9, 2015 at 1:35 PM
    #228
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Bummer...
    Get that hesetation figured out?
  9. Jun 9, 2015 at 3:40 PM
    #229
    j0shu4
    No ecu is super pissed when I go into wot.
  10. Jun 9, 2015 at 6:31 PM
    #230
    j0shu4
    Cx racing's customer service has impressed me personally. To each his own. I broke a vband, called in, and was sent two almost immediately to my door. They swapped out my charge pipes even though I had cut one of them. And took back my turbo for another one like 3 months later. I respected them, and got the same back. Yes, you may have to call several times, they are busy doing their jobs too. Anyway, just my FYI on CX.
  11. Jun 9, 2015 at 7:53 PM
    #231
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ace is very good. I had to deal with one guy that really pissed me off though. Ace got me straitened out, def grade A service.
  12. Jun 11, 2015 at 8:56 AM
    #232
    j0shu4
    Got new plugs and wires. Truck stalled out on freeway. Previous owner had 80k on plugs. Truck is running now. Putting in aem fic 6 today. Getting a bov, 8psi spring, fuel pressure regulator, and 440cc injectors unless someone really recommends bigger 550 ones. Also putting in walbro 255 soon.
  13. Jun 15, 2015 at 7:01 AM
    #233
    j0shu4
    Bought 440cc injectors, $189 shipped. You need to upgrade your fuel pressure regulator along with the rest of the fuel system. The stock fpr is tiny and will restrict the delivery of fuel. Fpr's are only $25 on ebay. Putting in the walbro 255lph high pressure pump soon. I decided to have the piggyback installed by someone who has done many of the aem fic installs. Gave me a good price on an install and tune.
  14. Jun 15, 2015 at 8:02 AM
    #234
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No need to change the Toyota's FPR. They are the same FPR used on the Supra and deliver pretty good numbers.
  15. Jun 15, 2015 at 9:07 AM
    #235
    GioGuitarDude
    Gio
    Cold air intake
    Yeah I have heard of very few people who had problems with their stock FPR in high(ish) boost conditions. I wouldn't mess with it.
  16. Jun 15, 2015 at 10:10 AM
    #236
    j0shu4
    The thing seems tiny.
    :notsure:
    The guys that race all kinds of stuff at bandamier recommend it. Already on its way. Im not disagreeing with your findings either way.
  17. Jun 15, 2015 at 12:22 PM
    #237
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Toyota's FPR is very good. Careful you don't get one that is worse.
  18. Jun 15, 2015 at 9:21 PM
    #238
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I wouldn't touch it. Gadget says to leave it.
    Unless you are going for 15+psi in which case you have a hell of a lot more to worry about then the fpr.
  19. Jun 17, 2015 at 12:15 PM
    #239
    j0shu4
    What needs to be built on ours? Top end, bottom end, or both.......and yes, I want to booooost.....
  20. Jun 17, 2015 at 12:22 PM
    #240
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    For the bottom end, crank, con rods, and pistons are all cast IIRC. You can get a Forged crank from the 3Z-FE IIRC (Camry 3.0L engine). Still a very stout engine but to get serious power, lower needs to be built. Def want stronger head bolts.
    Top end is 100% designed for low end torque (hence the low redline). The 5VZ is an overbore design (bigger bore than stroke) so it should be capable of much more RPM's, however, power is restricted primarily bythe cam's/valves. A built top end will net much more top end power right off the bat NA or not. The intake runners are also designed for low end torque. A better designed intake with shorter runners will help top end power.
