98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Sep 23, 2015 at 7:54 AM
    #461
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    That works too. But if its your flange, will have to do an exhaust leak. Im guessing 1st: Flange and 2nd: BOV
  2. Sep 23, 2015 at 8:09 AM
    #462
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    The bov was cheap. $40 ebay thingy. It worked good for a month or so, and still releases. Maybe it cant handle boost pressure and had cheap seals. Might have just gave out too. Didn't think about that. That would make sense for the reason that only when boost builds does it make noise. No other time. Not even revving the engine high. Only when psi starts registering.
  3. Sep 23, 2015 at 8:16 AM
    #463
    j0shu4
    Once I have this taken care of this I was going to put in my bigger injectors and fic6. I thought about taking the truck to a tuner shop and getting a good whole system tune and 3 dyno runs. It's $1k. Ouch. Is it worth it or can I easily tune everything my self on a laptop. I have no idea what to do but maybe the software makes it easy.
  4. Sep 23, 2015 at 8:22 AM
    #464
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    May the boost be with you
    j0shu4[OP] likes this.
  5. Sep 23, 2015 at 9:10 AM
    #465
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Is the "manifold up pipe" not the intake manifold?
    *EDIT: oh duh, you guys are talking about the exhaust flange. Nevermind.
    That in mind, there is pressure constantly between the turbo and the engine in the exhaust, so I doubt that it would make noise only at and above 0 psi on the boost gauge.
    I had a couple boost leaks that I had to fix, one was a tiny hole in a coupling and the other was a leaky upper intake manifold gasket (the oem one that consists of two pieces of sheet metal). I filled the hole on the coupling and that got rid of the majority of the noise, but after I took out the stock intake gasket and replaced it with a bead of silicone, it never made a noise again. I've never heard of an exhaust leak squealing like a slipping serpentine belt. My squeal started at exactly 0-1 psi as well.
    Josh, you don't need load to build boost. Your size of turbo should give you positive boost just by manually turning the throttle cable /blade quickly under the hood while you're standing there... mine does.
  6. Sep 23, 2015 at 11:44 AM
    #466
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If you are running bigger injectors, you might want to have a professional do the tuning. $1k is steep. Around here its about $4-500.
    Which is why I'm thinking BOV. But it could still be the exhaust flange. Yes, there is generally a pos pressure at most times, but it might take a certain pressure to cause the air leak :notsure:
  7. Sep 23, 2015 at 11:44 AM
    #467
    j0shu4
    No, it doesn't touch into the boost area at all even when I redline it without load on it. Im seeing that this thing could be anywhere in the engine bay. Never thought the manifold gasket would be a place to look.
    Interesting yours started at 0-1 psi too
    Yeah, I'm going to bring it to a professional tuner. I'd be there for months trying to get a good tune. Haha.
  8. Sep 23, 2015 at 12:27 PM
    #468
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, tuning larger primaries on the 5VZ isn't easy. Have Gadget's phone number on hand (URD) as he knows more about tuning the 5VZ than most.
  9. Sep 27, 2015 at 3:57 PM
    #469
    j0shu4
    Bringing her to the pros tomorrow. Like you said Chris getting a diagnostic. While I'm at it they are hopefully going to put in the 420 injectors, boomslang, aem fic-6, valve cover seals while they are down there, tune the fic, and do some dyno runs. If and when all is said and done, I will post the dyno runs.
    Even though it's turbo boosted........
    Then it will be off to the races on installing the LT kit up front first. I want to make sure that all my engine stuff is squared away before I move on to anything else.
  10. Sep 27, 2015 at 4:00 PM
    #470
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    ^^^ Nice! I would be interested in see the dyno numbers.
  11. Sep 28, 2015 at 1:07 AM
    #471
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I want to see that Solo kit go on. If those boxed 4x4 spindles dont look right, I am ready to put them on my truck:)
    Dalandser likes this.
  12. Sep 28, 2015 at 8:16 AM
    #472
    j0shu4
    Me too. I'm concerned because of the magnitude of the project and a whole crap ton of parts going on and off. Will be an adventure!
  13. Sep 28, 2015 at 10:13 AM
    #473
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Love the glass, following.
  14. Sep 28, 2015 at 9:01 PM
    #474
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Just saw your thread now...Good stuff going on with your build! Im digging it :headbang: hopefully you get that leak figured out. you have any sound clips of how that squealing noise sounds like?
  15. Sep 29, 2015 at 6:45 AM
    #475
    j0shu4
    Sweeeet. No sound clips, it's at the dyno tuners prolly all this week.
  16. Sep 29, 2015 at 7:37 AM
    #476
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Where did you take it?
  17. Sep 29, 2015 at 8:11 AM
    #477
    j0shu4
    Rather not say for now......:spy:, I already don't like leaving my vehicle with strangers. And it feels like something is missing when I go home. Trust me when I say I will keep you in the loop.
  18. Sep 29, 2015 at 1:04 PM
    #478
    GioGuitarDude
    Gio
    Cold air intake
    Lol
  19. Sep 29, 2015 at 2:57 PM
    #479
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Curious how your tuning goes. Any type of power goals you are looking to hit?
  20. Sep 29, 2015 at 3:26 PM
    #480
    j0shu4
    Not sure man. I was thinking 300hp and maybe more torque. I'm going to have it tuned for 10psi with the piggyback and maybe more if i throw in the meth. Another member on here is running 17psi with just meth (25-27 gph dual nozzles). So I just want a good solid power tune to start off and maybe work up from wherever. Eventually I'd like 400ft lbs and call it good. I've seen it done relatively easily, dynoed out.
    I talked to the tuner shop and we came to an agreement. Most of this stuff I can do myself, however, at this point I have done sooooh much work on her in the last year it's not even funny, that I'm willing to let someone else do it. Plus I have no idea how to do fuel trim, air, etc. maps with a piggyback. With that being said, I am getting the 42lb injectors put in. While the plenum is off replacing my valve cover seals (leaking bad), all the accompanying rubber seals, and spark plugs. The fic is getting installed. My LCE clutch and flywheel will be put on. And I will be getting a full dyno tune to include my methanol, ebc, and failsafe. Finally dyno runs......on a freshly tuned dyno (dyno is getting tuned this week, ill be the first one on it after the tune)......and the numbers say.....
    06HAOLE likes this.
