98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Oct 20, 2015 at 2:05 PM
    #561
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yeah, you should cap the MAF def. Also does the ecu cut fuel or timing? In your situation make sure you're not pinging or something and its cutting your timing.
  2. Oct 20, 2015 at 2:09 PM
    #562
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Pretty sure it just cuts fuel.
  3. Oct 20, 2015 at 2:35 PM
    #563
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    any CEL while it's cutting out or after?
    have you done any data logging while you are doing these runs? the AEM will do that, limited time to internal memory or can output to your laptop for more and longer data logs.
  4. Oct 20, 2015 at 3:06 PM
    #564
    j0shu4
    No cel. Not sure how to do the computer tuning. Why I paid for it...... :tinfoilhat: I know I could but how much time would I have to invest. Easy enough to download the software and plug it in, after that I'm not sure how user friendly it becomes?
    I have a laptop too.
  5. Oct 20, 2015 at 3:18 PM
    #565
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You logging on your FIC? Might help you troubleshoot. If you get a OBD reader and logging software you can get fuel trims, etc...
    j0shu4[OP] likes this.
  6. Oct 20, 2015 at 3:19 PM
    #566
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    lots of info from aem on youtube about setting up base maps and tuning. it helps to have someone else either drive or tune for you. I'm not a fan of dyno tuning, road tuning is what you have to live with day to day. You're not a drag racer just looking for WOT for 1/4 mile.
  7. Oct 20, 2015 at 3:20 PM
    #567
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its hard to road tune legally or safely.... With a mustang dyno, you can dial in tunes very accurately if you know what you are doing.
  8. Oct 20, 2015 at 3:46 PM
    #568
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not where I live...lol :D
    Of course...closest Dyno is like..8 hours away..
    StAndrew[QUOTED] and j0shu4[OP] like this.
  9. Oct 21, 2015 at 7:06 AM
    #569
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    When you bought your Solo Motorsports fabbed 4x4 spindle, did you get the lower uniball conversion upgrade as well? I have been looking at those 4x4 fabbed spindles lately.
  10. Oct 21, 2015 at 9:12 AM
    #570
    j0shu4
    Yeah I did. And the heimed steering upgrade. Hopefully getting it all on soon. I'm excited. And a little nervous until it is on and everything works. Mostly worried about welding on the gussets. (Cam and bucket) I'm waiting on brake lines right now......they forgot to send em with the kit. No biggie.
    06HAOLE likes this.
  11. Oct 21, 2015 at 8:03 PM
    #571
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I would offer to come weld for ya but the stick welder I have is junk and it's hard to have clean beads on short passes.
  12. Oct 21, 2015 at 8:34 PM
    #572
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    :cheers: Sounds familiar...
  13. Oct 22, 2015 at 4:54 AM
    #573
    j0shu4
    I'm pretty stuck with stick now unless someone can tell me what gas I need and rods. I have a tig too, just need to learn how to do it. Should take about 30 minutes right?
    My stick welder is a 220v 3 in 1. Has plasma too. Unfortunately I am still barely learning to stick.
  14. Oct 22, 2015 at 5:16 AM
    #574
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shoulda just got a mig. It's easier then all three haha
  15. Oct 22, 2015 at 5:35 AM
    #575
    j0shu4
    I know man, shit we do sometimes? Pisses me off too I didnt. :notsure:
    Could try and sell the 3 in 1 i have and pic up a mig, but I see $500 going out the door real fast again. After bottle and wire.....either that, or the guy that tig'ed my exhaust, I pay to show me how....? He said he'd think about it. There are definately worse things in life so I'm not complaining.
  16. Oct 22, 2015 at 6:23 AM
    #576
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Youtube has great instructional videos for TIG welding.
  17. Oct 22, 2015 at 6:23 AM
    #577
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    if only there were some virtual place where you could just enter a question and get an answer, and inside that place there should be a location of nothing but videos and you could find one that should you how to do stuff.
    tor beat me, gonna blame the turbos
    Torspd likes this.
  18. Oct 22, 2015 at 12:53 PM
    #578
    GioGuitarDude
    Gio
    Cold air intake
    Sarcasm detection...... BEEP BEEP BEEP!!!! :D
  19. Oct 22, 2015 at 12:56 PM
    #579
    yota243
    E.J.
    north Alabama
    there is also an entired thread devoted to nothing but welding on TW titled "anything welding" most of the ppl on there seem intellegent and could prolly answer your questions (no sarcasm)
  20. Oct 22, 2015 at 2:19 PM
    #580
    GioGuitarDude
    Gio
    Cold air intake
    In my experience, the brand of rods and/or wire you use is the single most important factor. I did my whole exhaust with some expensive stainless steel rods I got on eBay. Not only was it super easy to do but there are no leaks at all whatsoever. When I helped Josh out with his welding, we were using small rods of his and some way cheaper SS rods I got on eBay also. That was not fun. I would trust my life on these and recommend them to anyone for auto/exhaust work. http://m.ebay.com/itm/ZENA-3-32-NO-Gas-Stainless-Steel-Arc-Welding-Rods-/331410744398?nav=SEARCH
