98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Oct 24, 2015 at 8:39 AM
    #601
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    No, Gio has the port fueler. I only have 440 primaries.
  2. Oct 24, 2015 at 5:03 PM
    #602
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Gotcha.
  3. Oct 24, 2015 at 8:57 PM
    #603
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Soooo did they fix your tune yet?
  4. Oct 25, 2015 at 7:21 AM
    #604
    j0shu4
    No, I'll hear back beginning of next week from them. I'm really hoping they get the maps good and tune the ebc as best they can to minimize lag.
  5. Oct 26, 2015 at 8:58 AM
    #605
    j0shu4
    Tuner called and said the plugs were super fouled.......too much fuel maybe....? Duh.....and said it threw a cam sensor code and may have to replace the cam sensor if the cel doesn't go away.
    Any suggestions?
  6. Oct 26, 2015 at 2:53 PM
    #606
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Might be your issue. Fowled plugs will drip instead of spray so fuel won't burn too well which would cause your AFR's to read so low. I would have them hydrostatically cleaned by a proper dealership (don't have your tuner due them unless he can do it in house; he'll probably outsource it).
    Not sure what to say about your crank sensor...
  7. Oct 27, 2015 at 6:39 AM
    #607
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    9:1 will certainly foul them up. Lean it out to low 11's and it will definitely help. Also prevent fuel wash-out of the oil on the cylinder walls.
    The cam sensor is old. Coul be bad. Might not be. That can be tested with an Ohm meter.
  8. Oct 29, 2015 at 2:23 PM
    #608
    j0shu4
    This is getting ridiculous. Tuner shop called and said my fuel pump went out (walbro 255) that I put in maybe 3 months ago. Probably why my afr's went down to 9 and such. I know they do go out. How much hp will the stock pump handle? Any suggestions? I will most likely pay for them to install another, at least it will be warrantied.
  9. Oct 29, 2015 at 2:28 PM
    #609
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I dont think the stock pump will handle it...I have a 190 and its fine
  10. Oct 29, 2015 at 2:29 PM
    #610
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I doubt there is anything wrong with your pump. That sounds ridiculous. Should be warrantied if it did go bad.
  11. Oct 29, 2015 at 2:31 PM
    #611
    j0shu4
    I put it in myself, I bought it in march. Summit says no, call walbro. Walbro said send it in. I can't wait for walbro to figure out what they want to do.....
  12. Oct 29, 2015 at 2:32 PM
    #612
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You can run the stock pump just fine but keep off the boost. From your dyno, should be easy to do.
    But I doubt the pump is bad. If it were bad, your AFR's would be higher. Might be a bad FPR?
  13. Oct 29, 2015 at 3:19 PM
    #613
    RedLantern
    Honolulu, Hi
    If you choose to change your pump just go with a denso. I installed one that the supras use I believe it's like 300-315lph. My kit came with the 255 walbro but I got rid of it cause of how many I've read of them going out.
    j0shu4[OP] likes this.
  14. Oct 29, 2015 at 8:23 PM
    #614
    j0shu4
    Right on, thanks guys.....I'll see what goes on with things tomorrow.
  15. Oct 30, 2015 at 2:18 AM
    #615
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Are you confusing spark plugs with fuel injectors?
  16. Oct 30, 2015 at 6:14 AM
    #616
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No but I meant to say injectors. Fouled injectors won't atomize the fuel very well and it will "drip" instead of spray. Fuel doesn't burn when its a liquid and will just be passed through and metered by the AFR sensor as supper rich.
    Very common for diesels. If you see a smoking diesel, chances are it has fouled plugs that aren't atomizing the fuel very well.
  17. Oct 30, 2015 at 7:02 AM
    #617
    anthony250f
    Anthony
    San Diego, CA
    Diesels don't have spark
    Plugs, unless you meant fouled glow plugs?
  18. Oct 30, 2015 at 7:17 AM
    #618
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Injectors. Fouled injectors.
    Injectors are designed to atomize the fuel when they fire. If the get fouled or dirty in anyway, the fuel spray won't atomize very well and liquid fuel (un-atomized fuel) doesn't burn. Hence the super low AFR's OP was getting.
    But all of that is irrelevant b/c I just re-read this page and realized that he was talking spark plugs. I don't know where I got injectors...
    -1 internet point for me I guess.
  19. Oct 30, 2015 at 4:34 PM
    #619
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Yeah the pump cannot be the problem. They are probably scratching their heads at the craziness one has to endure to properly tune bigger injectors on a Tacoma. Josh, since you are getting tuned with bigger injectors (I forgot to tell you sooner), make sure you have them hook the FPR hose up back to a boostless and vacuumless reference like it is stock. Fuel pressure won't be an issue with the bigger pump and a tune. The point of hooking up the FPR hose to a boost ref is to increase fuel pressure under forced induction systems with a *stock* fueling system. 9 psi isn't healthy for that FPR to see longevity wise.
    And I hope you don't have the same issue I did... all of that nonsense started with that darn cam sensor
  20. Oct 30, 2015 at 9:30 PM
    #620
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If your pump had gone out..the truck wouldn't even run. You'd be off the charts lean.
