98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Nov 12, 2015 at 4:27 PM
    #681
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Can you post a link to the instructions?
  2. Nov 12, 2015 at 4:33 PM
    #682
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
  3. Nov 12, 2015 at 7:44 PM
    #683
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Sounds good. Looks like it spools pretty well. The boost plot is pretty flattened out from how they plotted it.
  4. Nov 12, 2015 at 7:58 PM
    #684
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Your biggest issue is the turbo is too big. If you had a smaller turbo it would fit the motor much better. Looking at compressor maps, a 50mm inducer is best on the turbine with a 70ishmm on the turbine. .58 or lower than .60 A/R on the turbine with a T3 housing.
    Have max boost at 2200-2500 with that turbo..before an EBC..
  5. Nov 13, 2015 at 7:59 AM
    #685
    j0shu4
    People have run bigger turbos on 4 cylinder engines. On a 3.4L I feel it is fine for me. I am happy with how it stands. Yes, you are and have been correct about the smaller turbo spooling faster and quite possibly being better suited. I additionally have availability for more power down the line which I may end up doing. More exhaust flow = bigger turbo in my book. Id love to get a standalone, bigger injectors, and build the top end to push 500hp. Then a smaller turbo would be lacking. I am more than happy with how it drives right now, and that is what is important to me.
    I think too if I can even fine tune this ebc for more immediate power. If I floor it in first gear without even dropping the clutch I am spinning the tires for days.
  6. Nov 13, 2015 at 8:15 AM
    #686
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Going to have to build the bottom end as well to reach 500hp. I think 400 is about the limit the bottom end can take but I think at your current tune, you are already there if you can open up the top end a bit with new cams.
    I would get a second 5VZ and build it on the side if I were you. Depending on my employment in the future, I'm looking to either build a second 5VZ or drop 25k in a diesel conversion.
  7. Nov 13, 2015 at 8:17 AM
    #687
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I used the GT3076R on my girlfriend's 2.0 Genesis Coup. Spooled very quickly once I dialed in the start boost, on her Greddy Profec BII boost controller. Otherwise it was quite laggy.
    You engine has quite a bit more litre. You're golden. Just need to get the B.C. dialed in.
    Plus you still have room to grow on this turbo.
    j0shu4[OP] likes this.
  8. Nov 13, 2015 at 9:17 AM
    #688
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is your wastegate spring psi?
  9. Nov 13, 2015 at 9:24 AM
    #689
    j0shu4
    Pretty sure it's 7 (tial), I'm running around 12psi. I want to video another hard pull and see exactly where everything's at. Thanks for your above comment too. Reinforces what I've been thinking from the get-go of this turbo build.
  10. Nov 13, 2015 at 9:31 AM
    #690
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know what you're doing. ;) :thumbsup:
    Where do you have the "spring pressure" set to for the solenoid?
  11. Nov 13, 2015 at 9:35 AM
    #691
    j0shu4
    I'll have to look. Pretty sure it's set super low. Like 1.8 or something. The lower I go the higher the psi. Also it will flash a % with a number in boost. Like 14%. And sometimes it will start clicking too. After work I'll go home and take some pics or get readings. Plus take a couple boost vids to watch the gauges.
  12. Nov 13, 2015 at 12:14 PM
    #692
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Hey TC, sick truck dude, where are you at in CO? If you're looking for hands for the LT install I might be willing to chip in. I'm very curious of the quality of that Solo kit. The kit looks amazing but I haven't seen many on the forums, let alone any reviews. I'm kinda on the fence between it and the MCM kit. And just for the record, I have no experience with these kits what-so-even and am kind of a novice in general to 4x4 modifications.
  13. Nov 13, 2015 at 1:05 PM
    #693
    j0shu4
    Thanks man. Tons of work to get it there. Builds dont happen overnight. I'm in South Metro area. Yeah, I've never done an ifs setup before either. Only full axles. I can't say I wouldn't mind help either.
  14. Nov 13, 2015 at 3:33 PM
    #694
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Wish I could come help with the LT install bud but you know where I am with my build. Busy busy busy.
  15. Nov 13, 2015 at 7:25 PM
    #695
    j0shu4
    Thx man. At least I have an engine. Haha. Did you stick weld your gussets?
  16. Nov 13, 2015 at 7:42 PM
    #696
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yes. Everything is stick welded except the spindles. Insain Fab Tig those for me.
  17. Nov 14, 2015 at 5:23 AM
    #697
    j0shu4
    Good to hear because that's my plan. I'll just make absolute sure the welds are good. No popcorn mounting things. Wouldn't do that anyway but I just need to ensure they are right and take my time with them.
  18. Nov 14, 2015 at 5:46 AM
    #698
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    You dudes need a mig welder.
    Even a smaller miller/lincoln 140 with gas will weld .120-.1875 thick no problem.
  19. Nov 14, 2015 at 6:36 AM
    #699
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yes I do.
  20. Nov 14, 2015 at 8:06 AM
    #700
    j0shu4
    My stick is 220V. Yes, I wish I had a mig though too.
