98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. May 4, 2016 at 4:52 AM
    #881
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    j0shu4[OP] likes this.
  2. May 4, 2016 at 7:57 AM
    #882
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Not sure what drive shaft you're using but the parallel input/output only applie to a one piece. If you have a double cardan you want pinion angles and shafts to be very close to the same. The majority of the angle should be across the DC joint.
  3. May 4, 2016 at 6:22 PM
    #883
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  4. May 4, 2016 at 9:13 PM
    #884
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Dude, he's got like 8 million posts in his build, plus I've read it front to back like 3 times. Lol. Hard to find stuff fast. Appreciate it though. Anthony is helping me out with a few things, measurements and such
    SilverGhost[QUOTED] likes this.
  5. May 4, 2016 at 9:25 PM
    #885
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You have a 1st gen which is double cardan joint. Parallel at ride height to a few degrees pointed down. I pointed mine down slightly to counter the torque when you accelerateIMG_20150425_100826.jpg
  6. May 4, 2016 at 9:31 PM
    #886
    j0shu4
    Kind of freaky looking at your baby like that. It's like a half truck. Only the frame past the cab, besides part of the fuel cell. DAY 1 BABY
    GF was a beast woman! Helped out quite a bit and I introduced her to the pleasures of grinding.
    WTF kind of vehicle is this?
  7. May 4, 2016 at 9:34 PM
    #887
    j0shu4
    Cool man. Still unsure though, but the consensus is pretty much straight on. I remember Jason kicked his up like a degree or 2.
  8. May 4, 2016 at 9:37 PM
    #888
    MadTaco461
    CA
    Kinda stock
    It would be down because when you accelerate the diff will rotate up and the whole thing will be closer to parallel. It won't vibe when you take off hard.
    Edit
    You can set straight and be fine too. This down is only 2 degrees I did. Helps with big power. Axle wrap like a mofo on a long travel truck
    DIRT YOTA and j0shu4[QUOTED][OP] like this.
  9. May 4, 2016 at 10:33 PM
    #889
    j0shu4
    So with my big turbo your saying down just tiny bit?
  10. May 5, 2016 at 6:57 AM
    #890
    MadTaco461
    CA
    Kinda stock
    Yup
    j0shu4[QUOTED][OP] likes this.
  11. May 7, 2016 at 6:05 PM
    #891
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Hey, just a thought, before you go jumping this, may want to re-enforce your turbo flange onto the frame of the truck. Lots of weight riding on your exhaust studs.
  12. May 7, 2016 at 9:04 PM
    #892
    j0shu4
    Thanks bro. Good heads up. Not ready for takeoff but getting closer daily.
  13. May 7, 2016 at 9:20 PM
    #893
    j0shu4
    Damn holy mother of work. And grinding sucks donkey balls, I mean not like I know, but probably something like that. You know, when you start out project, I say to myself, " I know something will go wrong." Because it always does. My new saying before I start, " I know 11 things are going to go wrong." Just helps with sanity. About 3 days of work into this and I'm ready to tack the perches and ds angle.
    Lots of rust. Thinking Toyota bullshitted us on the frame replacement. Since the beds off might as well clean it up. Just some random rust/cleanup shots.
    Where she's at so far.
  14. May 7, 2016 at 9:28 PM
    #894
    j0shu4
    So, off the top of my head.....had to open up the bash plate holes so the ubolts would go through, find correct ubolts, get upper shock tabs, mod the ..... out of the axle truss to accommodate the bash plates and ubolts. Ummmmm, modify the spring perches to fit the bash plates, ubolts, and t100 axle. Ummmm, prolly like 5 other things. All in all a good day. Lots of progress. Shocks and cycling tomorrow.
    Bigger holes on the left bash plate.
    Painted my calipers to match the fronts.
    SilverGhost likes this.
  15. May 7, 2016 at 9:29 PM
    #895
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You going to box that rear frame?
  16. May 7, 2016 at 9:32 PM
    #896
    j0shu4
    Yeah, I'm going to run a rectangular tube across the very back and I have the frame reinforcement plates to do the sides. I'm sort of stuck on how I want to carry a spare or possibly two. I just do not see myself EVER needing 2 spares.
  17. May 7, 2016 at 9:40 PM
    #897
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Run shocks off front
    I have zero axle wrap
    MadTaco461, 06HAOLE and j0shu4[OP] like this.
  18. May 7, 2016 at 9:51 PM
    #898
    j0shu4
    I've seen them ran both ways. Seems like out of 100 trucks, 50 are front and 50 are back. I really want to know what's best. If you say foward then I'm willing to go with that
  19. May 7, 2016 at 10:37 PM
    #899
    anthony250f
    Anthony
    San Diego, CA
    From what I've read going off the front helps to reduce axle wrap. A lot of it will have to do with your bed cage set up too. If you go off the back with the 3" tabs the bedcage is gonna be really far back or the shocks will be angled back
  20. May 17, 2016 at 9:03 AM
    #900
    j0shu4
    This rear LT and "bed cage," is way more involved than what I had imagined before I began. It looked relatively easy but there has been way more to figure out than what I planned for. Messed up the ds angle so I had to cut off and redo the perches. I set it without the ds on. Oops. So now it looks about right from stuff, to droop, to ride height. Got my shocks sweet spots measured and I'm about to tack up and build the bed cage. Here's some progress pics.
    Drive shaft full bump.
    Full bump, leaf pack removed
    Shock upper sweet spot
