98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. Sep 1, 2017 at 5:13 PM
    #1321
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Crazy something so simple can make such a significant difference
    j0shu4[OP] likes this.
  2. Sep 1, 2017 at 5:15 PM
    #1322
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Yeah that's insane! Truck is running noticeably better.
    boostedka[QUOTED] likes this.
  3. Sep 1, 2017 at 5:23 PM
    #1323
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Well Ill have to take a look at mine then too lol, hasn't been changed in at least 100k, that and my upstream O2 sensor.. This build is beautiful, I seriously can not get over that hood, its so badass.
  4. Sep 1, 2017 at 5:24 PM
    #1324
    j0shu4
    Hey thx man I enjoy it. Yeah I'm going to post it in 1st gen too just so others know.
  5. Sep 1, 2017 at 6:28 PM
    #1325
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'll definitely give it a try. Burning up this summer :bananadead: in socal.
    Can't wait to start wrenching again.
    New fuel filter ftw.
    Torspd[QUOTED] likes this.
  6. Sep 2, 2017 at 7:17 AM
    #1326
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Think Cali is taking all of Texas' heat. Want some of our water too???
    MadTaco461[QUOTED] likes this.
  7. Sep 2, 2017 at 4:41 PM
    #1327
    j0shu4
    Lessened the heat soak going to the intake. Also wrapped the maf it may see cooler readings. Pretty much going to say this is mandatory. The charge pipes get SOOOOOOO hot from the engine bay. Header wrap is like $20 off ebay. Did this today lol considering I've had that header wrap for over 2 years now.
    because_wumbo-truck likes this.
  8. Sep 2, 2017 at 6:09 PM
    #1328
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did the same to mine with a lace up thermal wrap. Temporary-ish, for the same effort. I agree. Gets cooled down then heats back up in the bay.
  9. Sep 2, 2017 at 6:18 PM
    #1329
    j0shu4
    I cannot understate how smooth my afr's are now with that on. HUGE HUGE HUGE difference! It use to jump around on me quite a bit throughout the rpm range. Now pulls are super smooth afr wise. I'm steady between 11ish to 11.9ish depending on rpm. And I can pull after pull and it stays consistent at 11.5ish. That is INSANE again. Everyone that has a turbo has to do this I'm serious........the heat soak that it prevents is phenomenal. I noticed how hot my charge pipes were not just now but for a long time of monitoring them. And i mean very hot. I thought about wrapping them some time ago. I also saw someone did it recently. Again it is absolutely mandatory imo to do this. The heat soak it prevents is incredible.
    @GioGuitarDude have you done this? I know you measure your IAT's and I'd be curious to see if you do this the before and after.
    devinzz1 and Torspd[QUOTED] like this.
  10. Sep 2, 2017 at 6:22 PM
    #1330
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I like to look to race car builds, then builds which trickle down from there. Implement in some form what they do because they have studied the "why's". I will say that the common denominator between all race car builds is this: Heat abatement. Heat abatement. Heat abatement.
    jubei and j0shu4[OP] like this.
  11. Sep 2, 2017 at 6:27 PM
    #1331
    MadTaco461
    CA
    Kinda stock
    You'd probably like having a turbo blanket also. That turbo hot side gets hot.
  12. Sep 2, 2017 at 6:27 PM
    #1332
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Convection oven it is...
  13. Sep 2, 2017 at 6:29 PM
    #1333
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    PTP Turbo blanket. High quality construction amd made in Austin, Texas. :oldglory: (closest emoji to a Texas one. :rolleyes: )
  14. Sep 2, 2017 at 6:32 PM
    #1334
    j0shu4
    I had an eBay one that lasted for some time but eventually started burning. And I'm not talking about the brake in burn they get.......maybe a better one you think?
  15. Sep 2, 2017 at 6:32 PM
    #1335
    j0shu4
    This is a good blanket?
  16. Sep 2, 2017 at 6:39 PM
    #1336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very. Had a DEI one, and then the PTP one. PTP is all around better.
  17. Sep 2, 2017 at 7:06 PM
    #1337
    j0shu4
    Yeah that eBay thing eventually started burning. I'll try that ptp you guys suggested
  18. Sep 2, 2017 at 7:07 PM
    #1338
    MadTaco461
    CA
    Kinda stock
    For over the turbo you want a better one. I bought one for my truck on eBay but luckily it a super small company that makes them in the us. Really sad I have high quality parts over my eBay turbo.
  19. Sep 6, 2017 at 4:47 PM
    #1339
    j0shu4
    I seriously tried to jump her (and I've gotten all 4 off the ground in one of my previous vids). It's deceiving but this was really steep and too tight. E for effort at least. Next time I'm finding something suitable and ramping up to go big.......
    https://youtu.be/KmW7EnzMU7I
    MadTaco461, BYJOSHCOOK and boostedka like this.
  20. Sep 6, 2017 at 4:48 PM
    #1340
    ChadsPride
    Sponsored by TacomaWorld.com
    So in​
