98 TRD 3.4L Turbo , Methanol , LT
Discussion in '1st Gen. Builds (1995-2004)' started by j0shu4, Mar 16, 2015.
  1. May 16, 2015 at 9:33 AM
    #161
    j0shu4
    j0shu4 [OP] 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Proud of my methanol tank. Found a grand Cherokee washer fluid tank for $5 at the salvage yard. Painted it flat black, installed a ss float sensor, and tapped it for the meth line. Holds 1 gallon. Left a little of the plastic natural to see the fluid level. Its going in my passenger side bed box with the pump.
  2. May 16, 2015 at 12:29 PM
    #162
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    You dog!!!! You stole my subwoofer idea but I never made time to do it. Lol looks sweet dude. I'll have some led lighting updates tonight to post. When is the oil pan w/ bung going in?
  3. May 16, 2015 at 2:27 PM
    #163
    j0shu4
    Within the next 2 weeks. Then it'll be go time.....haha. who's idea? I've had those up there for 6 months.....Custom fitted. But I did invent the fender well turn signals. J/K. Lol.
  4. May 16, 2015 at 7:42 PM
    #164
    GioGuitarDude
    Gio
    Cold air intake
    Are those woofers 8's?
  5. May 16, 2015 at 8:31 PM
    #165
    j0shu4
    No, shallow mount 12's
  6. May 17, 2015 at 12:32 AM
    #166
    GioGuitarDude
    Gio
    Cold air intake
    All about dat bass
  7. May 17, 2015 at 6:03 PM
    #167
    j0shu4
    Installed the methanol system!
  8. May 18, 2015 at 8:37 AM
    #168
    GioGuitarDude
    Gio
    Cold air intake
    Looks clean. Are you runnin more than one reservoir?
    EDIT: NVM, one gallon is plenty. Did you pick up a fail safe for your meth system?
  9. May 18, 2015 at 8:45 AM
    #169
    j0shu4
    No failsafe yet. AEM has one for $267. More money I dont have. Would like one eventually. Trying to find one from somewhere else too.
  10. May 20, 2015 at 9:16 AM
    #170
    j0shu4
    Not the tuffest rims but it's mostly a dd. Planning on 35"s with bilsteins until I can afford LT. Can't wait to get these on......
  11. May 21, 2015 at 8:07 PM
    #171
    GioGuitarDude
    Gio
    Cold air intake
    image.jpg image.jpg Those look epic! Hey Josh, I highly recommend you use allen head bolts for your wastegate so you can actually torque them down to an adequate ft/lb. a regular socket will NOT fit the passenger side bolt, so it will either stay kinda loose or strip. Harbor freight sells a SWEET ball/swivel extended head hex ratchet set that makes taking the WG on and off a total breeze while in the truck. I just replaced my bolts today (M8 1.25 thread x50mm long) and if there was a leak, it's definetely not there now. Notice on the top picture how a section of the CX headers is almost completely obstructing the bolt head.image.jpg
  12. May 24, 2015 at 5:53 AM
    #172
    j0shu4
    Yeah, I see that. Looks like neither a socket nor a wrench can get in there.
    When I go to mount the waste gate on to the header it seems like there's a big gap in between the turbo and wastegate? here are some images so you can see what I'm talking about. on the wastegate it sticks out. the flanges don't sit flush. I'm wondering if yours is like this too and you just use the copper gasket to fill in that gap?
  13. May 24, 2015 at 9:44 AM
    #173
    GioGuitarDude
    Gio
    Cold air intake
    Huh?? Where is that gap comming from? Is it an uneven flange surface or the valve seat ring for the wastegate? On my wastegate, the ring makes the wastegate stick out about 1/8" but when you tighten down the bolts, the wastegate spring starts to depress and it ends up perfectly flush.
    EDIT: I just zoomed in to your pic, and yeah, that gap will go away when you tighten it down.
  14. May 24, 2015 at 9:51 AM
    #174
    j0shu4
    Yeah, it's the ring.......I see, it's OK then. Thanks bro! Didn't realize that gets depressed with the spring.
  15. May 24, 2015 at 7:46 PM
    #175
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You have to tighten the bolts very evenly or you can torque the valve seat. Also, dont connect it to the headers before install. It won't fit into the engine bay.
  16. May 24, 2015 at 10:24 PM
    #176
    GioGuitarDude
    Gio
    Cold air intake
    I put mine in with the wastegate already attached and I didn't have to touch my power steering at all either :notsure:
  17. May 24, 2015 at 10:49 PM
    #177
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    nother turbo build:popcorn:
  18. May 25, 2015 at 7:02 AM
    #178
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I couldn't fit mine. Had to take it off and reinstall the hard way :(
    As the above pics, hex bolts are your friends. You can't get a socket on a bolt head and forget about using a wrench.
  19. May 25, 2015 at 10:43 AM
    #179
    j0shu4
    What end goes to the dump tube off the wastegate? Wanted to be sure but my guess is the spring, shaft, and valve end butt up against the turbo side. Is this correct? That way all the hot gas presses onto the plunger.
  20. May 25, 2015 at 3:05 PM
    #180
    GioGuitarDude
    Gio
    Cold air intake
    It goes exactly like the pic you posted above, with the ring and valve up against the header WG flange
