99 tacoma 2.7 liter 3rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by montana1, Apr 18, 2015.
  1. Apr 18, 2015 at 2:33 PM
    montana1
    montana1 [OP] New Member
    I HAVE A 99 WITH A BAD ENGINE 2.7 3RZ FOUND A REALLY GOOD DEAL ON A 96 2.7
    3RZ ENGINE ARE THEY PLUG AND PLAY?
  2. Apr 18, 2015 at 6:46 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    Not plug and play, the heads are different i think- 96 takes a dizzy and the 99 has coil packs. I think the intakes are different as well- something about one having more ports than the other.
  3. Apr 19, 2015 at 8:49 AM
    montana1
    Thanks thats what I was afraid of.
  4. Apr 19, 2015 at 1:12 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    My '99 doesn't have coil packs.
  5. Apr 19, 2015 at 1:17 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    if your head was in good shape you could just slap it on the other block and that "should" take care of all the differences.
  6. Apr 19, 2015 at 5:20 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Mine does. 2 coils that service 4 cylinders. Are you confusing coil packs with COPs (Coil-On-Plugs) ?
  7. Apr 19, 2015 at 5:38 PM
    Brake Weight
    Yep. I never really considered that a coil pack setup because everything else I've had was either a distributor or COPs. Touché.
  8. Apr 20, 2015 at 7:43 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    One is a individual 8 port head and the next (or previous) incarnation was a Siamesed setup.
    I have the 8 port w dual coils.
    Correct if wrong, but so long as you have the same ignition setup, it should drop in regardless of the head. Research that out and make sure before dropping coin.
  9. Apr 20, 2015 at 6:21 PM
    knuckleduster271
    ohio
    98 sr5 xtra cab
    Pretty sure 95.5-96 have a hole for the distributor in the cylinder head where 97+ heads do not. I havnt looked closley, may have a plug covering the hple om later engines.
  10. Apr 20, 2015 at 7:31 PM
    CR, WA
    stock
    Dual coil bracket covers or rides on top of what looks like the dizzy mount pad.
