99 Tacoma 4x4 remove front differential carrier
Discussion in '1st Gen. Tacomas (1995-2004)' started by kdwellssr, Dec 10, 2019.
  1. Dec 10, 2019 at 6:47 AM
    kdwellssr
    kdwellssr [OP] Well-Known Member
    Kelly
    Arkansas
    99 Tacoma ext cab 4x4 v6 automatic
    30.5 tires, Nerf bars, Brush guard, Trailer tow kit
    I have taken off the CV axles and the front carrier mounts. Removed the vacuum lines and electrical plug. Removed the rear mount nut. Yes I did remove the front drive shaft bolts. How do I get the unit out. The stud that the rear nut is fastened to is holding it. When I rock it the carrier contacts the engine and will not pull out. I removed the a bout 12 years ago but don't remember how I got it out. Anyone know what I'm not doing?
  2. Dec 10, 2019 at 6:31 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    You just have to get it at the right angle, even going back in it seems like it will never fit and somehow it slips back in
  3. Dec 10, 2019 at 6:48 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Rotate it forward. The rear mounting point is a stud, and has to clear the transmission bellhousing.
  4. Dec 10, 2019 at 6:58 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I had to unbolt the driver side motor mount and jack the engine up a couple inches to get enough room to pull mine out.
  5. Dec 10, 2019 at 7:05 PM
    kdwellssr
    Kelly
    Arkansas
    When I try to rotate it the driveshaft sleeve hits the bell housing.
  6. Dec 10, 2019 at 7:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yup. That's what will happen. You have to rotate it very deliberately to get it to clear the bellhousing. Two people helps.
  7. Dec 10, 2019 at 7:31 PM
    kdwellssr
    Kelly
    Arkansas
    No way am I going to get someone to help. I gotta do it myself or hire someone. I'll get it.. just looking to see if someone found a easy way to get er done.
  8. Dec 10, 2019 at 7:33 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Easiest way is to just remove an engine mount and jack up the drivetrain. I did it in 5 minutes with two people without removing the engine mount by rotating it forward.
  9. Dec 12, 2019 at 3:11 PM
    kdwellssr
    Kelly
    Arkansas
    Got it out ... lifted it as far as I could then used a pry bar and applied some up press at the rear mount. Once that stud cleared the hole it went fairly easy. Getting it back in has been a whole new ball game. I actually had that rear mount stud in the hole real soon but when I applied some pressure to lift the transmission a bit and get that bolt to go deeper in that hole... well. didn't work. it slipped and all came apart. Haven't been able to get it back in right position since. I'll get it just may take a couple weeks..lol.
    Wulf and frenchee like this.
  10. Dec 12, 2019 at 6:11 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Sounds sexual :eek:
  11. Dec 13, 2019 at 2:50 PM
    kdwellssr
    Kelly
    Arkansas
    Maybe it sounds like it but it isn't near as much fun.
