99 Tacoma ABS and SRS lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tashier, Apr 1, 2012.
  1. Apr 1, 2012 at 10:01 AM
    Tashier
    Tashier [OP] Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    Hi all. I have a 99 Tacoma 4x4 Limited V6 and have had the SRS light on for over 10 years. Now the ABS light is on as well intermittently. I finally took it to the dealer who amazingly tried to read the codes for free. He did get a code on the SRS though I have it written down at work and not with me. The ABS however just would not communicate with his computer. The ABS will work on and off intermittently, or rather, the ABS light is on and off intermittently. When starting the truck it will be off and the ABS works fine, then at some random point the ABS light comes on and the ABS no longer works. The dealer wants minimum $165 for diagnoses and I thought maybe I would just buy a Toyota scanner instead. I'm thinking the SRS may just reset, possibly something I did installing a radio. The ABS I'm pretty sure has something wrong if the ABS computer is not communicating. Any recommendations on a scanner that would read Toyota ABS and SRS codes? I was looking at a Toyota T605 such as this:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310230815273
    Any help is appreciated.
    Sean
  2. Apr 2, 2012 at 3:28 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Not feeling the love...
  3. Apr 2, 2012 at 5:19 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    That scan tool should work with the specs i see. Its a Can bus so it should work and get the info you need.
    I cant comment on it the one you posted( never used one like that).
    i have only used the snap on ones in the like 4000 buck range.
  4. Apr 3, 2012 at 8:11 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Any suggestions on the ABS computer? If the dealers computer could not communicate with it, would that suggest a bad ABS computer?
  5. Apr 3, 2012 at 5:42 PM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    My ABS system has been acting up for a while now and currently the ABS light is always on. The dealer wants about $250 per sensor which is crazy to me. I will be disconnecting the ABS system in the near future. :D
  6. Apr 4, 2012 at 9:49 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Want to sell me your ABS computer then?
  7. Apr 4, 2012 at 10:23 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    I'm really surprised that no one has much to comment on this as I find this problem a lot elsewhere on the net. Here is one guy's reply:
    I'm new to the forum and got an account specifically so I could post my findings. I was recently faced with the same ABS light issue and found a solution! I, probably like most of you, scoured the Web looking for a fix and found lots of others in the same boat but no solution so I vowed to post my fix here. I have a 99 Tacoma Pre-Runner V6 TRD, and about a week ago, had a funny banging and grinding noise under the passenger firewall when I stopped followed by the ABS light. I googled the issue and found how to short the diagnosis plug to have the ABS light flash the stored codes. For me, like most folks I think, I got 32 and 44. I cleaned the wheel sensors which were really not that bad, re-installed, cleared the codes, test drove, and no joy. Before I spent big money replacing the deceleration sensor or wheel sensor, I decided to look into the electrical side of the ABS system. Thanks to this Web site: , I was able to use the guides posted to troubleshoot the ABS electrical circuits with my digital multimeter. I checked resistance and continuity at each circuit and all was good. The key finding using this testing was when checking voltage at each wheel sensor connector from the ECU. Do the following to test this:
    1) Unplug all 4 of the wheel sensors at the electrical connector
    2) Turn the key in the ignition to the "ON" position
    3) Select DC voltage on the multimeter
    4) Connect the hot lead from the multimeter to one pin of the unplugged connector (the circuit that leads to the ECU)
    5) Connect the other lead of the multimeter to body ground (find a nice, clean, unpainted chassis ground)
    6) Read the DC voltage
    * Be careful when the key is on not to short the hot side of the connector to ground!
    Depending on which side of the two-pin connector you are reading, you will get a small (mV range) reading or a 2.8XX Volt reading (that was my truck anyway.) If you get the mV range, try the other pin on the connector. Try all 4 connectors for each wheel. You should see a pattern... (2.8XX V on all but the front left sensor connector for me, which read intermittent and I assume why I was getting code 32.)
    When you find an anomalous connector (front left for me) check the wiring all the way back to the ECU. In my case, I found when I pressed the wiring harness (the big connector with the orange key to keep it seated) into the ECU with my left hand while reading voltage on the meter connected to the front left sensor connector, my intermittent reading would stabilize at a nice 2.8XX volts like the other wheel sensor circuits. HINT: alligator clips can be used to hold the chassis ground lead on your multimeter so you have a free hand to wiggle the connector. Translation: Bad connection in the wiring harness at the ECU!
    Be careful that you turn off the ignition for anything other than the voltage test at the wheel sensor as shorting out the ECU will more than likely cost you a replacement! I removed the connector and found no visible signs of a bad connection - no corrosion, or bent pins, etc. I mated/re-mated it several times checking the voltage each time. Every time I checked it after re-mating the plug, it was still intermittent. (WITH THE KEY OFF,) I finally decided to SLIGHTLY bend the two male pins inside of the connector in the ECU plug so they would fit tightly (on my truck it was the top two pins in the connector towards the front that were the hot/ground for the front left wheel sensor) then re-mated the connector. SUCCESS!!! 2.8XX Volts constant at the left front wheel sensor without me holding it in! I cleared the codes and have been driving for a week now with no more issues.
    COST FOR THIS REPAIR: $0!!!!
    I guess after time, the harness (with lots of wires bundled in it) gets fatigued by gravity and perhaps the rough ride with these trucks and the connections in the plug start to wiggle their way loose. In my opinion, it's a bit goofy the way the wires are led into this harnesss then bent over at a 90 degree angle. Seems that it is a failure waiting to happen on older trucks.
    Well I hope this helps someone fix their problem. Like I said, this was MY truck's issue - no guarantees it will fix yours.
    Best of luck to you!
  8. Apr 4, 2012 at 10:24 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    The only problem with the above issue not relating to me is that my ABS computer does not respond or give any codes at all. And I have checked the ECU connection and cleaned it.
  9. Apr 7, 2012 at 6:22 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    Could someone point me to a forum where people provide real information on Toyota Tacomas? I would actually like to get this fixed.
  10. Jun 14, 2012 at 12:28 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Stop being a dochebag and it might help :notsure:
    We aren't here to just help you and do so instantly.
  11. Jun 14, 2012 at 12:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    If the ABS is always on and it won't communicate then the ABS ECU is bad. And do you happen to remember the SRS code?
  12. Jun 14, 2012 at 12:49 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    Well put.
  13. Jun 14, 2012 at 12:55 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Is anyone even on this forum?
  14. Jun 14, 2012 at 1:06 PM
    trmarshall1
    Tim
    San Jose, CA
    :rofl:
  15. Jun 14, 2012 at 1:11 PM
    trmarshall1
    Tim
    San Jose, CA
    Question for the OP. Why on Earth would you drive around with an indicator light on for ten years? Seems kind of derp to me. Mine come on, I fix that shit pronto. Good luck with your issue, but I'd say you lost all hope getting a response from this forum, because nobody is on it.
  16. Jun 14, 2012 at 1:17 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    He can wait 10 years, but it's inconceivable to wait 2.5 months for the answer he wants to hear. :confused:
  17. Jun 14, 2012 at 1:47 PM
    MowTaco
    Kansas
    2.5 months? He barely waited a day before getting all pissy that nobody replied...
  18. Jun 14, 2012 at 2:33 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    I believe it was 6 days before I became frustrated to be exact. I waited 10 years on the airbag because I was 99% sure it was the airbag switch, (which it is). The ABS light was more of an issue because it presented an immediate problem braking, as in, sometimes I can't. The ABS light has been on for almost a year now with noone being able to provide any solutions, including the dealer. I'm not willing to throw $600 parts at it in hopes it may or may not fix the problem. From others' experiences its a good thing I didn't spend any money on sensors or actuators. Was hoping that someone here would have had same experience.
    And I have no clue what derp is. First time on dozens of forums I've heard that one.
  19. Jun 14, 2012 at 2:41 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    I did have the dealer diagnose both issues. According to them the SRS issue is the keyswitch (which I already assumed it was). The ABS light is code 32 and 44, same as everybody else with a 98-00 Tacoma with the ABS light on. The light is not always on, only intermittently. I've cleaned the sensor, reseated the actuator harness several times and cleaned the wheel sensor connector as was suggested by many elsewhere. Light still pops on here and there and the ABS activates randomly as well. It's pretty irritating. Some have yanked the fuse but being that we have snow occasionally ABS is pretty useful here.
  20. Jun 14, 2012 at 6:29 PM
    trmarshall1
    Tim
    San Jose, CA
    Obviously those dozens of other forums have been just as helpful, or maybe nobody is on those either, because you still have the problem.
