'99 Tacoma Lower control arm bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matermax, Jun 5, 2017.
  1. Jun 5, 2017 at 9:48 AM
    Matermax
    Matermax [OP] Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    My mechanic replaced the LCA bushings 2 years ago, less than 10k on them, and now one is bad and the others not looking so good. Any sugestions on after market replacements? Sorry to start a new thread, there is probaly one already started but I couldn't find much. Heard some mention of Energy Suspension or White Line, unfamiliar with both.
  2. Jun 5, 2017 at 10:10 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  3. Jun 5, 2017 at 12:31 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Your mechanic changed them with OEM or aftermarket? I'm asking cause OEM should last way more than 2yrs.
  4. Jun 5, 2017 at 12:58 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I just did energy suspension a few months back and I am happy with them so far. They were pretty easy once I did the drivers side for practice.
  5. Jun 5, 2017 at 9:00 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I suggest you buy Whiteline poly bushings and use the video my buddy Sean and I made for this job. Good Luck and Happy Wrenching!
    <iframe width="560" height="315" src="https://www.youtube.com/embed/kmaZNBp1gZM" frameborder="0" allowfullscreen></iframe>
    970btu, tony2018, COMAtized99 and 3 others like this.
  6. Jun 6, 2017 at 4:52 AM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    Thanks every body, much appreciated.
  7. Sep 2, 2017 at 10:53 AM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    On the LCA bushings, Toyota lists 2 different part numbers, one for the forward and one for the rear bushing does anybody know the difference and why? I'm considering the White Line but they look the same for both.
  8. Sep 2, 2017 at 12:12 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    This should pretty much cover it.
    https://www.tacomaworld.com/threads/lca-tips.479978/#post-14617055
    Dalandser likes this.
  9. Sep 2, 2017 at 3:21 PM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    That makes sense. My next question is, If they are installed wrong would that make them wear (fail) faster?
  10. Sep 3, 2017 at 8:49 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    If they aren't preloaded they can wear quickly.
  11. Sep 3, 2017 at 9:10 AM
    tony2018
    tony2018 Well-Known Member
    You're awesome.
  12. Sep 3, 2017 at 9:42 AM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    I hope I don't sound too ignorant but I'm not sure what you mean by preloaded.
  13. Sep 3, 2017 at 6:36 PM
    Ngneer
    Ngneer Well-Known Member
    Would like to know this as well
  14. Sep 10, 2017 at 7:31 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    Preloading is when you leave the end nuts a little loose and put the weight of the vehicle back on the control arm (I used to put a couple block of wood under the control arm and then lower the vehicle) and then tighten the end nuts. This puts the bushing in the position it will operate in before you wrench them down.
    drr and boostedka like this.
  15. Sep 10, 2017 at 7:44 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    All suspension components should be tightened to their final torque value when the vehicle is sitting on its own weight at ride height.
  16. Sep 10, 2017 at 7:53 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    If you install poly bushings it don't matter since they have zero bind.
    My polys are so loud now. After few years of washing out I kind of wish I went OEM.
  17. Sep 10, 2017 at 3:27 PM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    Ah! That makes sense.
