99 Tacoma shaking at HW speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dubdaddy86, Jul 10, 2020.
  1. Jul 10, 2020 at 10:07 AM
    Dubdaddy86
    Dubdaddy86 [OP] Well-Known Member
    Recently my truck began shaking very bad... I thought it was due to severely cupped MTs that I’d just rotated. This was at any speed honestly.
    Since then I’ve replaced both axles, all ball joints, etc. new tires, alignment, blah blah.
    now it rides just fine cruising back roads but if I get above 60mph the rattle comes back. Anyone know where to start?
  2. Jul 10, 2020 at 11:58 AM
    phambino
    phambino Member
    Eric
    Cypress, TX
    2001 Silver Tacoma PreRunner
    New tires but have you checked if your wheels are warped?
  3. Jul 10, 2020 at 12:37 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you get the shaking on every road above 60mph?? Does it go away as you keep speeding up??
    Sometimes it is stacked tolerance of every rotating part just vibrate at a certain rpm or speed
    I have been on sections of road that look fine it feels like the wheels are about to fall off
    The first few times I pulled over thinking I was about to have a major failure
    TacomaJunkie8691 and cruiserguy like this.
  4. Jul 10, 2020 at 12:47 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    You changed ball joints but how do the bushings in the control arms look and feel? If they're worn out the stacked tolerances @Wyoming09 mentioned would translate into the frame more readily and could cause vibrations
    TacomaJunkie8691 likes this.
  5. Jul 10, 2020 at 6:15 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    I got mine up to 95 somehow and it felt like a dream driving. I’m not sure how I didn’t die or break anything
    TacomaJunkie8691 and Kevins60 like this.
  6. Jul 10, 2020 at 7:08 PM
    Harryhood87
    Harryhood87 Well-Known Member
    Harry
    New England
    2004 Xtra Cab 4x4 Lunar Mist 260k+
    265/75/16, Yak Q towers
    I did 101 and it also felt pretty good at that speed.
  7. Jul 10, 2020 at 7:21 PM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Yeah I don’t know why, I’ve been in numerous cars that shake when they go like 75+ lol
  8. Jul 11, 2020 at 2:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Would you know if you were dead??
  9. Jul 11, 2020 at 6:27 AM
    Kevins60
    Kevins60 Well-Known Member
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    Aftermarket Cruise Westin step bars Lund tonneau Jensen HU
    I had a bad shaking that seemed to start randomly at speeds over 60. Had tires rotated and rebalanced and replaced center bearing but it finally turned out to be my OEM rear shocks were completely shot and the wind buffeting on the tonneau would start the truck bouncing and shaking so hard I thought I would lose control. The old shocks were so beat that once the were off the truck they would slowly collapse under their own weight.
  10. Jul 11, 2020 at 6:44 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    U joints? A lock up one will shake like crazy at speed.
  11. Jul 11, 2020 at 6:52 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Oxford county PD friend of mine radar clocked a 96 Tacoma at 104 really nice long straight away he spent the night in jail. Don't know how it went in court but I'm guessing he was walking for a long time that's considered criminal speed.
  12. Jul 11, 2020 at 10:19 AM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    atleast give the man a break! He was trying to go as fast as he possibly could! And 104 is pretty fast for a Tacoma on a straight away! lol!
  13. Jul 11, 2020 at 2:21 PM
    Harryhood87
    Harry
    New England
    Yeah certainly is. Heading north from Boston at 1130pm I hated doing the speed limit. Took 20 minutes on the T just to get to the parking garage, then 1.5hr drive home. I'd use the Waze app and it was better than any radar detector.
  14. Jul 12, 2020 at 9:50 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Spacer lift, 33" BFG km3, Yaesu dual band radio, bi-xenon headlights, ARB bumper and 9.5k winch.
    Take a look at your lower control arm bushings. Do you also have a wobble while braking? Mine did that with new rotors that were properly bedded. My bushings were torn and it had a ton of play.
