9mm platform
Discussion in 'Guns & Hunting' started by scifidelity, Feb 28, 2020.
  1. Feb 28, 2020 at 12:52 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I have the High Tower Armory MBS-95. (It requires a sacrificial Hi-Point for the upper action :anonymous:) Its a surprisingly well balanced and fun to shoot plinker. Downside is that I had to install the rubber talon grips everywhere, because I hate gripping hard plastic.
    scifidelity[OP] likes this.
  2. Feb 28, 2020 at 12:55 PM
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    I know you asked about 9mm but .22 probably is cheaper yet and this thing is a lot of fun to shoot
    https://palmettostatearmory.com/s-w...aign=Daily+Deal+Email&utm_content=12:00+Email
  3. Feb 28, 2020 at 12:56 PM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Where can you find a parts kit and receiver for less the a clone? Asking for a friend.
  4. Feb 28, 2020 at 12:58 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I have a New Frontier C-5 rifle but they also sell PDW pistols. Its been a very good firearm for me. I use it for 3-gun matches
  5. Feb 28, 2020 at 1:02 PM
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    CMMG makes converted mag inserts too. I like that idea. Theirs run on any AR lower with carbine buffer & spring, but will they run on *any* 9mm upper? Just says it runs on cmmg uppers. Wonder if they made it proprietary?
  6. Feb 28, 2020 at 1:02 PM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    $900 can buy a lot of .223/5.56 with current prices being at or under $0.25/round, vs $900 for a new gun and 9mm being at $0.15/round
    Sig45, jeff b and Gunshot-6A like this.
  7. Feb 28, 2020 at 1:08 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Where on earth are you finding 5.56 that cheap regularly (that isn't steel wolf)? Seems like 28.x cents/rnd is about as low as I can find after tax+shipping is considered. I say that after searching for several afternoons before buying my last stockpile.
    I agree with your sentiment though. Add to existing capability for maximum benefit.
  8. Feb 28, 2020 at 1:13 PM
    Gunshot-6A
    Conner
    Everett, WA
    looks like prices went up a little since I last checked. but 1500 for a parts kit still isn't bad and you get HK parts, not *shudders* PSA parts.
  9. Feb 28, 2020 at 1:14 PM
    MadRussian
    Metrowest MA
    2010 TRD OR AC
    If you dig into it, the CMMG mags are rebranded EndoMag version for the CMMG Radial Delayed Blowback design. The CMMG-EndoMag doesn't have a built in ejector, the standard EndoMag does.
  10. Feb 28, 2020 at 1:17 PM
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Well, with a budget of $900 1/2 of the choices you listed are already out.
    I would suggest anything but an AR-9 unless it's a high end factory built pistol (which will be above your budget).
    All AR9's are direct blowback (other than CMMG's radial blowback, which is above your budget), due to this they all recoil more than a 5.56 rifle. They are also much less reliable, and if you plan to suppress them they are very loud to the shooters ear (lots of ejection port noise from direct blowback).
    I currently own everything on your list but the Scorpion, which I have minimal experience with. But of those options it would be the best choice for you. They can be had for around $800. After that you'll still need a brace, which will be between $100-300. I suggest the SB Tactical SBTEVO. The Scorpion has a horrible trigger and grip, but those can be upgraded down the road. Be mindful when you buy that you pick one up with 1/2x28 muzzle threads. There's some early models with strange threads that make it very difficult to change muzzle devices or suppress.
    I've had nearly a dozen AR-9's. All but the high end ones have been very unreliable.
    Also take a look at the Stribog, a lot of people have been having very good luck with it. It is direct blowback and suffers the problems associated with that but from the looks of things they're reliable, and pretty neat in general and within your budget. The Sub 2000 is another option, although I think you'd be happier with something else.
    EDIT: The MPX is my favorite "9mm sub-gun" on the market, mine has tens of thousands of rounds through it. The APC-9 is also amazing, but isn't nearly as quiet or soft recoiling as the MPX. I just picked up the newly released H&K SP5, mainly for cool factor. They're very quiet and soft recoiling but have a sub-par manual of arms, weight and cost.
    GATacoRookie, jeff b and Gunshot-6A like this.
  11. Feb 28, 2020 at 2:20 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I really love my MPX... It’s been real reliable!8207F599-B45D-48FF-BBCE-D5568C351921.jpg
  12. Feb 28, 2020 at 2:26 PM
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    Same
  13. Feb 28, 2020 at 2:26 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Out of those the best one for your budget/quality would be the scorpion. The cheapest would be the AR-9 with a glock lower. The problem with the AR platform is that it is designed for rifle rounds, but adapted to pistol calibers. The scorpion is designed around the 9mm. Although, if you want something to replicate your AR15 for drills etc you should go for the AR-9. Just make sure to get a glock lower, if you dont you'll need a conversion block and it'll 1: cost more, 2: decrease reliability.
  14. Feb 28, 2020 at 2:26 PM
    Wixo
    Hank
    Tint, LED interior
    I have it and its awesome.
  15. Feb 28, 2020 at 2:28 PM
    #35
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    MP5 MP5 MP5
  16. Feb 28, 2020 at 2:35 PM
    #36
    BDSKJChris
    Albany, NY
    Targetsportsusa, atm i believe wolf brass is $0.27, if you are a prime member you get an 8% discount and free shipping bringing it to just under 25 cpr, but they run a lot of federal ammo sales too, which is currently sitting at 30cpr but routinely can be had for 25cpr before the discounts or mail in rebates
    Gunshot-6A[QUOTED] likes this.
  17. Feb 28, 2020 at 3:10 PM
    #37
    scifidelity
    scifidelity [OP] Well-Known Member
    Man that MPX is sexy. Awesome advice so far guys, thank you. I am kind of getting the sense that an AR 9 is just a Frankenstein, not ideal. I like the idea of a platform completely designed for the 9mm. Scorpion seems to be the best value option. That wilson is insanely sexy, but way too much cheddar. The Angstadts seem like a good compromise.
    jeff b likes this.
  18. Feb 28, 2020 at 8:36 PM
    #38
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    I have 2 Angstadt’s. They’ve been very reliable and are built well. Direct blowback recoil and noise are there, but reliability is good. But, unless you’re willing to wait for a good used one to pop up they are also out of your budget.
  19. Feb 29, 2020 at 11:33 PM
    #39
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    May I ask why the budget can't exceed $900? Personally, I'd say save your money and buy a Sig MPX, which is better than a Scorpion in pretty much every way.
  20. Mar 1, 2020 at 12:11 AM
    #40
    scifidelity
    No, you may not ask why. From the research I’ve done since I started this thread I’ve read too many negatives about the MPX to consider it anymore. Apparently the barrel shoulder has some stupid proprietary thread pattern so you have to use their muzzle devices, cans, etc. that’s BS. No respect for companies that do that. Some companies like Midwest make adapters, but they make the gun widely inaccurate. It’s overly greedy. Also, I’d rather deal with recoil than have an unnecessarily complicated system. Meaning I’m pretty set on a direct blow back.
    dand likes this.
