9mm platform
Discussion in 'Guns & Hunting' started by scifidelity, Feb 28, 2020.
  1. Mar 1, 2020 at 1:28 AM
    #41
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    Uh, ok then. Just trying to help you out man, although I'm not sure why you'd even mention MPX, MP5 etc. if you refuse to budge over $900. I also think you're getting a bit too hung up on the barrel threading, considering you have more customization options in every other category ie. grip, stock, triggers, etc. not to mention way better ergos. Nothing complicated about MPX either - it's basically an AR, but if you're set on a Scorpion have at it. Not my 1st choice but still perfectly decent sub gun.
  2. Mar 1, 2020 at 5:18 AM
    #42
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I wouldn't use "recoil" in the same sentence with "9mm carbine." There just isn't much recoil in any of these options.
  3. Mar 1, 2020 at 6:33 AM
    #43
    scifidelity
    scifidelity [OP] Well-Known Member
    Totally, that’s my feeling as well, but people seem to get all worked up about the recoil of direct blow back 9mm PCCs. I shoot high caliber rounds regularly.
    EdgemanVA[QUOTED] likes this.
  4. Mar 1, 2020 at 10:53 AM
    #44
    p1smo
    Because smoother recoil impulse = faster follow up shots.
  5. Mar 1, 2020 at 11:42 AM
    #45
    scifidelity
    Valid point. Thanks for that.
  6. Mar 2, 2020 at 3:36 PM
    #46
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    ALL 9mm blowback AR's recoil MORE than 5.56 AR's. Not an opinion, this is factual. Inherent to the direct blowback system.
    But we're not referring to recoil as you would the recoil of a magnum caliber that causes pain... more recoil from the 9mm blowback is referenced so often because it limits how quickly you can shoot the platform accurately. You can stay on target much easier and shoot much faster with a 5.56 chambered AR.
    The barrel threading is irritating, I had my barrel chopped and re-threaded. ZR tactical does a great job for $100.
    But your other point of a "complicated system" I'm confused by. It's literally a couple of op-rods with springs on them for a recoil system. No more complex than any AR.
    If it's not for you it's not for you, but as I said before the MPX is by far my favorite PCC and I've had them all. I think the only thing that will touch it will be the MP5 but I admit that will probably be more from cool factor than actual performance.
  7. Mar 2, 2020 at 4:16 PM
    #47
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I'd you looked at it somewhat scientifically, the 223 has about 3x more recoil energy then 9mm (energy=1/2 bullet mass x velocity ^2 /rifle mass). But comparing them side by side the recoil impulses are different.
    223 has most of the felt recoil from the bullet launching because of the locked bolt. 9mm has the felt recoil from the bolt assembly knocking into the end of the buffer tube. So the felt recoil on an AR9 will be very mild because it's going right into the shoulder.
    On dedicated 9mm guns (mpx, cz, etc) the bolt stops just above the pistol grip so the felt recoil impose is different.
    Playing with bullet weights, buffer weigh, springs and muzzle devices will effect felt recoil.
  8. Mar 2, 2020 at 4:17 PM
    #48
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude, NSFW NSFW NSFW!!! You can't be posting hot ass gun porn like that on here. Check the forum rules.
    With that being said, this picture was not my proudest fap.
    rmepilot, jeff b and GATacoRookie like this.
  9. Mar 2, 2020 at 4:25 PM
    #49
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    I disagree, nearly 100%. The AR9 has much more felt recoil.
    The combination of the drastically heavier carrier, and the most rudimentary of operating systems equate to much more recoil. I've own over 100 AR's, nearly a dozen AR9's. Unless you have a more sophisticated operation (gas operated MPX, roller delayed blowback MP5) perceived and felt recoil of the 9mm AR platform will always be more than its 5.56 counterpart.
  10. Mar 2, 2020 at 4:26 PM
    #50
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    Ha! Checkout my Instagram for more, just make sure your wife isn't around... @pnw_pew
  11. Mar 2, 2020 at 4:41 PM
    #51
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't worry. Still single. ;)
    And if the girlfriend gets mad, well I'll just break up with her. I don't need that sort of negativity in my life.
  12. Mar 3, 2020 at 7:45 AM
    #52
    scifidelity
    agreed that it's no more complicated than any AR, that being said, simpler and less parts is usually better in my mind.
  13. Mar 3, 2020 at 11:00 AM
    #53
    Realoldfatguy
    Realoldfatguy Well-Known Member
    Bob
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    RokBlokz Rally Flaps Toyota running boards
  14. Mar 3, 2020 at 6:20 PM
    #54
    Realoldfatguy
    Bob
    Iowa
    Have you actually seen one? Held it? Fired it?
  15. Mar 3, 2020 at 8:19 PM
    #55
    Realoldfatguy
    Bob
    Iowa
    It is quite accurate with just the iron sites.
    Not any more “bulky” than others mentioned here.
    Plus, it’s a take down, so it can be stored and transported in a smaller case.
    The base version can be found for under $500. Considerably less that most of the others mentioned.
    MFTAF13 and jeff b[QUOTED] like this.
  16. Mar 5, 2020 at 6:20 PM
    #56
    RyanFMD
    RyanFMD Well-Known Member
    2018 Quicksand TRD Off-Road
    If there are any other Aero Precision fans I'm pretty excited for their new AR9 to be released, I like the bolt hold open feature that it has over some of the other brands and it won't break the bank
  17. Mar 5, 2020 at 6:33 PM
    #57
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Ok @scifidelity , I am going to throw you for a real loop. And it is under $900, and extremely reliable. A full size S&W M&P 2.0 9mm with a Micro conversion Kit. This is mine and you can add a red dot on the top, it is very accurate and stupidly comfortable, and breaks down for easy storage and hand use. Btw, it sits solid in the frame when put in. Doesn't budge a mm.20180815_065219.jpg20191205_185600.jpg
  18. Mar 5, 2020 at 6:34 PM
    #58
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    :popcorn:
    I ducking love Aero so... cant wait!
  19. Mar 5, 2020 at 7:54 PM
    #59
    scifidelity
    OK that thing is AMAZING. looking into the details now, but wow.
  20. Mar 5, 2020 at 8:00 PM
    #60
    crashngiggles
    Jared
